Κώστας Φ.
Νέο kit απο το 41Hz.com, βασισμένο στο Tripath TA3020 αυτή τη φορά. Στα 97 ευρώ.
"A new design based on the Tripath TA3020 chip, in the same power range as AMP2, ie. up to 2x300W at +/-60V supply.
Truepath was designed to have better optimized board layout, compared to the Tripath TK3020 reference boards.
Truepath was designed by Benn Frisk, in cooperation with another audio enthusiast, Ola Hesselvall. Benn has worked professionally more than 20 years with advanced PCB designs. Ola has for over 20 years worked with mechanical CAD, and is a tube amplifier aficionado.
Some features of the Truepath design:
Greatly enhanced supression of electromagnetic interference
Optimized lead pattern with very short switching leads, to reduce loop areas
Matched impedance gate drive leads
Well separated power- and low-level signal sections.
Completely separated analogue and digital power-domains
4-layer PCB and double weight copper allows, well shielded, heavy duty traces to deliver high currents at lower temperature
The board is 100mm wide and 110mm deep.
The kit includes all components on board, board connector headers, toroids, litz wire to wind the toroids, silica insulators for the FETs.
The board needs a main supply of up between +/-35 and +/-63V, a well stabilized +5V of about 50mA and a 10V gate voltage, 200mA, referentced to the negative rail (10V above the negative voltage)."
Κλικ χίαρ φορ μορ!
Ποιός τυχερός θα αναλάβει να μου φτιάξει έναν τέτοιο τελικούλη το καλοκαιράκι?! :mrgreen:
