41Hz.com: Truepath
Κώστας Φ.
Νέο kit απο το 41Hz.com, βασισμένο στο Tripath TA3020 αυτή τη φορά. Στα 97 ευρώ.
"A new design based on the Tripath TA3020 chip, in the same power range as AMP2, ie. up to 2x300W at +/-60V supply.
Truepath was designed to have better optimized board layout, compared to the Tripath TK3020 reference boards.
Truepath was designed by Benn Frisk, in cooperation with another audio enthusiast, Ola Hesselvall. Benn has worked professionally more than 20 years with advanced PCB designs. Ola has for over 20 years worked with mechanical CAD, and is a tube amplifier aficionado.
Some features of the Truepath design:
Greatly enhanced supression of electromagnetic interference
Optimized lead pattern with very short switching leads, to reduce loop areas
Matched impedance gate drive leads
Well separated power- and low-level signal sections.
Completely separated analogue and digital power-domains
4-layer PCB and double weight copper allows, well shielded, heavy duty traces to deliver high currents at lower temperature
The board is 100mm wide and 110mm deep.
The kit includes all components on board, board connector headers, toroids, litz wire to wind the toroids, silica insulators for the FETs.
The board needs a main supply of up between +/-35 and +/-63V, a well stabilized +5V of about 50mA and a 10V gate voltage, 200mA, referentced to the negative rail (10V above the negative voltage)."
Κλικ χίαρ φορ μορ!
Ποιός τυχερός θα αναλάβει να μου φτιάξει έναν τέτοιο τελικούλη το καλοκαιράκι?! :mrgreen:
Πάει... το έχουν ξεφτυλίσει τελείως το θέμα ενισχυτής.....
Σε λίγα χρόνια θα το δίνει το Ελέκτορ μαζί με το περιοδικό δώρο!
Κώστας Φ.
Απάντηση: 41Hz.com: Truepath
Πλέον προσφέρουν και τα αντίστοιχα PSU boards...
  • PSU1-SS Soft Start Board (Soft start and Mains HF filter)
  • PSU1-PS Power Supply Board (Rectifiers and Bulk capacitors)
  • PSU1-VR Voltage Regulator Board (Dual voltage regulators, for V5 and VN10 or similar)
Tιμή περίπου 150 ευρώ όλα μαζί...
Με άλλα λόγια, με 350-400 ευρώ φτιάχνεις τον Truepath σου κομπλέ. :cool_4:
Κώστας Φ.
Απάντηση: Re: 41Hz.com: Truepath
E οχι και "φτιαξει".
Μαλλον "μονταρει"
Αρα τον βλεπεις καθημερινα .... στον καθρεφτη :crazy_3:
Yes !
Why not ?
Aυτές οι μικρές αντιστασούλες και το chip με φρενάρουν... Αν και έχω σταθερό χέρι (βλ. έκανα μοντελισμό παλιότερα και έβαφα κάτι μικροσκοπικά ανθρωπάκια), ε, είναι κάπως δύσκολο. Οι κερατάδες δεν μπορούσαν να τα έχουν pre-mounted τουλάχιστον αυτά?
Το καλό είναι πως έχω βρει που θα κάνω προπόνηση... "happy_1"
Πάντως μας έχει ακόμη στο περίμενε ο Στέφανος με τα UcD του οπότε δε βιάζομαι. (Ακούς Στέφανε?! Φανταστικέ φίλε?! Τελείωνε!!!)
πολύ εύκολα κολιούνται οι smd οι αντιστάσεις, με ένα τσιμπιδάκι για τα φρύδια είσαι αρχηγός
ή με δύο οδοντογλυφίδες, όπως τρως κινέζικο ρύζι.
Bliaxxx....
Καμμια σχεση με το φραι-ραις που πουλανε εδω.
Εχω δοκιμασει σε καποιο ταξιδι απο περιεργεια και για να μην προσβαλλω τον καπετανιο... Ψηνεται στον ατμο και θεωρειται πετυχημενο μονο οταν κολλανε οι κοκκοι.
Ενας τρωει - δεκα πεθαινουν.
Στην ιδια περισταση, δωσαμε στον Κινεζο μαγειρα να δοκιμασει τυρι φετα που ειχε στην καβαντζα (μαζι με ψωμι και ελιες) ενας συναδελφος, που το ειχε δει το εργο απο παλια και κουβαλαγε μαζι του καποια δικα μας τροφιμα. Ο κινεζος δεν το αντεξε και ετρεξε αμεσως στην τουαλεττα να το βγαλει.
Μιλαμε για σκηνικο Ιντιανα Τζοουνς και κρυα μυαλα πιθηκου.
Οχι τιποτε αλλο, αλλα για να ξερεις απο ποιους αγορασες :crazy_3: :crazy_3: :crazy_3:
Κώστας Φ.
Κάνουν μία ωραία φουστιά στον 6κάναλο...
Διαβάστε αυτό:
True balanced operation
in mono mode.
At the push of a button, the eVo module converts
channels to run in “anti-phase” and produce a true
balanced mono-block design with all the benefits of
hefty power and lower distortion.
Είχα διαβάσει το κόλπο και στο forum της 41hz.
Είναι πολύ απλό (αντιγράφω post του μέλους thomaseliot):
I saw it in some ev-board Tripath datasheet, one simple methode to bridge the amp. Take a balanced signal from a source (i.e. one balanced DAC or a balanced line driver) then feed one channel with the HOT wire, the other with the COLD wire. This way you get an elegant balanced input bridged mono amp.
Κώστας Φ.
Διαβάστε αυτό:
in mono mode.
Κώστας Φ.
H πίσω όψη του ενισχυτή επιβεβαιώνει αυτό που σας έλεγα.
Προσέξτε τις μπόρνες των ηχείων (stereo-mono)...
H ισχύς εκτοξεύεται:
Stereo Pair 120w/8 Ohms, 200w/4 Ohms
Bridged 400w/8Ohms, 600w/4Ohms 800w peak
THD: < 1%
Δείτε και τις μετρήσεις που δημοσιεύει η BelCanto...
Σίγουρα θα μπορεί να γίνει κάτι αντίστοιχο και στον Truepath. :happy_6:
THD: < 1%
Με το ιδιο τροφοδοτικο συμβαινουν αυτα ?
Κώστας Φ.
Mιχάλη, νομίζω ναι, αλλά οι μετρήσεις δεν προέρχονται από το 6κάναλο. Είναι από τον αντίστοιχο 2κάναλο ενισχυτή (που έχει το ίδιο "κόλπο" αλλά περιέχει μία μοντούλα μέσα και όχι τρεις όπως ο πολυκάναλος).
Υπόψην το μέγιστο που μπορεί να βγάλει το 3020 σε δικάναλο είναι 2x300 στα 4Ω, σύμφωνα με τα datasheet τουλάχιστον.
Ξέρουμε και οι δύο το λόγο που δεν δημοσιεύουν τα αντίστοιχα νούμερα για τον πολυκάναλο (with all channels driven ofc). Βέβαια ο toroid νομίζω είναι 1500VA αλλά και πάλι...
Κώστας Φ.
Btw, κι ο eVo2 (απ'όπου και οι παραπάνω μετρήσεις) έχει έναν 1500VA μέσα.
Φυσικά οι ενισχυτές αυτοί είναι τώρα discontinued. Η Bel Canto χρησιμοποιεί ICEpower modules πλέον.
Ποιο κολπο μωρε Κωστα ?
Αυτος ειναι ο στανταρ τροπος για να γεφυρωσεις δυο ιδιους Ενισχυτες. (Πχ δυο καναλια ενος στερεο Ενισχυτη)
Τα χουμε πει τοσες φορες εδω μεσα.
Θελεις δυο ισα και Αντιφατικα σηματα με αναφορα σε ενα common τα οποια εφαρμοζεις στα δυο ακρα ενος μεγαφωνου. Εαν λειπει το common δεν κλεινει το κυκλωμα. Που βρισκεις δυο αντιφατικα σηματα για να τα ενισχυσεις ?
Δινεις το ιδιο σημα εισοδου στα αντιδιαμετρικα ακρα των balanced Εισοδων των δυο καναλιων (εφοσον υπαρχουν)
Αν δεν υπαρχουν Balanced εισοδοι ... δημιουργεις Αντιφατικο σημα για τον ενα μονο Ενισχυτη απλα αναστρεφοντας την φαση του αρχικου σηματος με μια βαθμιδα Phase Inverter.
Τριχες στην πραγματικοτητα, αφου αυτη την βαθμιδα αναστροφης φασης την εχεις ηδη stand by στον διαφορικο ενισχυτη που διαθετουν ολες οι μοντουλες αφου ολες εχουν στην εισοδο τουλαχιστον εναν Op-amp
ετσι εχεις ανα πασα στιγμη την διπλασια ταση στο ιδιο φορτιο και αρα την τετραπλασια Ισχυ.
Πρεπει ομως να μπορει να την παρεχει και το τροφοδοτικο, και να εχει και την διπλασια ικανοτητα ψυξης το ψυκτικο της βαθμιδας Εξοδου.
Αυτοι ξαναανακαλυπτουν τα Ηλεκτρονικα !!!
Η πρακτικη αυτη χρησιμοποιειται απο Ιδρυσεως Ηλεκτρονικης επιστημης. (Απο τοτε που ο Λη ντε Φορέ εισηγαγε το οδηγο πλεγμα στην διοδο και εφτιαξε την τριοδο)
  • rose.athens
jimacid
