Volent Paragon VL-4
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Frequency Response: 20 Hz ~ 100,000 Hz
Power Handling: 350W(RMS)
Sensitivity: 88 dB (2.83/1M)
Impedance: 8 Ohm (min: 5 Ohm)
Crossover Point: 230, 1,100 , 5,800 Hertz
Dimension: 409 (W) x 1202(H) x 725(D) mm
Weight: 150Kg (net weight per pcs)
  185Kg (gross weight per pcs)
With mind of pursuiting the purest music,Paragon VL-4,property the best loudspeaker system in the world was born. It dives from 20Hz and climbs to 100Hz with excellent dynamic and detailed resolution, namely the brightest instrument for all kind of music performance.
Volent's Patented super tweeter and Air Motion Transducer give greatest details
Paragon VL-4 equipped with proprietary patented Twin-Ribbon super tweeter and special selected Air Motion Transducer. Treble's performance is maximixed with greatest details and definition.
7"sandwich cone drive unit gives unbelieb\vable detailed midrange
7"midrange unit's cone is made of latest technology. Inner layer is made of syntactic Polymer Hardfoam, outer layer is Graphite with Titanium ionized and sprayed on its surface. Graphite's elasticity and Titanium's stiffness and with specially designed copper Faraday Ring, Counter-electromotive force is minimized and gives the fastest and highest dynamic midrange.
12"woofer wquipped with Nomex Hexcone gives highest dynamic bass
12" Hexcone woofer performs with the most dynamic bass with fastest impulse response. The woofer cone is made of Kelver and Nomex material
http://www.volent.com.hk/product-page/productpage-vl4.htm
Κώστας Φ.
Δεν ξέρω πως παίζει αυτό το "Air Motion Transducer" αλλά ρίχνει στα τάρταρα το WAF (ή τέλος πάντων ό,τι WAF μπορεί να έχει ένα ηχείο με 12ιντσο)!
Ενδιαφέρον ηχείο πάντως.
Gebreselassie
Μαύρος!
Τι απόκριση είναι αυτή ρε? Σε home cinema νυχτερίδων θα παίξει? Και τι διάολο έχει μέσα και είναι 150 κιλά έκαστο? Αυτό το Twin-Ribbon Super Tweeter ακούγεται εξαιρετικά ενδιαφέρον αλλά το site τους είναι πολύ φτωχό σε πληροφορίες.
Gio
Ντακς ρε Ανδρεα, θα σας πω την γνωμη μου για το ηχειο.
Μεχρι τωρα δεν εχω κρατησει τον λογο που σου εχω δωσει, και εχω αφησει αρκετες δουλειες που εχουν σχεση με reviews, παρουσιασεις, γνωμες, προτασεις που μου εχεις ζητησει να κανω στο AVSite στη μεση, αλλα αυτη τη φορα θα
Gebreselassie
Μαύρος!
Μπουαχαχαχαχαχαχαχαχαχχα!!! Θα... τι βρε?
Μπουαχαχαχαχαχαχαχαχα... :cool_11::cool_11::cool_11::cool_11:
Gebreselassie
Μαύρος!
Σας παρακαλώ παιδιά, όχι τόσο γρήγορα θα πέσει ο server με τον Gio μέσα...
:cool_11: :cool_11: :cool_11:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Φανταζεσαι τωρα να μπει και ο Παχης?
Το κλαψαμε το site for good:cool_11: :cool_11:
Θα παρει φωτια ο σερβερ και τα πληκτρα"happy_1"
Gebreselassie
Μαύρος!
Μπαααα, ο Παχής ψάχνει εφημερεύοντα φαρμακεία για να αγοράσει αλοιφή για τους κάλους. Μπουαχαχαχα!! :cool_11::cool_11::cool_11:
Gio
Γιατι δεν κοιμαστε τετοια ωρα, μπορειτε να μου πειτε?
Και στο φιναλε αν δεν νυσταζετε εσεις, καντε λιγο ησυχια να ξεκουραστει κανενας αλλος.Αντε μεσημεριατικα.
argiristheo
