Καλωδια η κρεμαστρες?
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
I'm so sorry, but I do not buy into 90% of the hype brought to us audiophiles by the commercial sector of our hobby and the home entertainment industry at large. My brother, an audio engineering whiz kid has proven to me what is real and what is not. Let me rehearse with you an example of how he does this.
We gathered up a 5 of our audio buddies. We took my "old" Martin Logan SL-3 (not a bad speaker for accurate noise making) and hooked them up with Monster 1000 speaker cables (decent cables according to the audio press). We also rigged up 14 gauge, oxygen free Belden stranded copper wire with a simple PVC jacket. Both were 2 meters long. They were connected to an ABX switch box allowing blind fold testing. Volume levels were set at 75 Db at 1000K Hz. A high quality recording of smooth, trio, easy listening jazz was played (Piano, drums, bass). None of us had heard this group or CD before, therefore eliminating biases. The music was played. Of the 5 blind folded, only 2 guessed correctly which was the monster cable. (I was not one of them). This was done 7 times in a row! Keeping us blind folded, my brother switched out the Belden wire (are you ready for this) with simple coat hanger wire! Unknown to me and our 12 audiophile buddies, prior to the ABX blind test, he took apart four coat hangers, reconnectd them and twisted them into a pair of speaker cables. Connections were soldered. He stashed them in a closet within the testing room so we were not privy to what he was up to. This made for a pair of 2 meter cables, the exact length of the other wires. The test was conducted. After 5 tests, none could determine which was the Monster 1000 cable or the coat hanger wire. Further, when music was played through the coat hanger wire, we were asked if what we heard sounded good to us. All agreed that what was heard sounded excellent, however, when A-B tests occured, it was impossible to determine which sounded best the majority of the time and which wire was in use. Needless to say, after the blind folds came off and we saw what my brother did, we learned he was right...most of what manufactures have to say about their products is pure hype. It seems the more they charge, the more hyped it is.
So you see, my friend, that is why I have joined up with this site (audioholics) because their approach to good sound and education to acquire good sound and video is based on science, not hype, hypnotics, placebo effects or wishful
thinking.
My best regards;
Dr. Bob Dean
http://forums.audioholics.com/forums/showpost.php?p=15412&postcount=28
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Καλωδια η κρεμαστρες?
εξαρτάται την κρεμάστρα...
Μήπως ήτο χάι ένδ κραμάστρα;
Μήπως ήταν κατασκευασμένη από μπουρδοκλάνιο του τιτανίου;
Μήπως είχε λάστιχο ποτίσματος γύρω γύρω;
Μήπως την είχε ευλογήσει κανένας πατριάρχης Ιεροσολύμων;
melina
Cargo 200
Είναι ένωση του τιτανίου, δεν θα το βρεις στον περιοδικό πίνακα. :114:
μηπως ηταν κρεμαστρες που ηχαν υποστει κρυογεννηση;:105:
επισης πως καταλαβαν την κατευθυνση που θα επρεπε να ειχε η κρεμαστρα;
μας αφηνουν με πολλες αποριες....
giannis9494
