Review: EMM Labs CDSA SE Stereo SACD Player
Κώστας Φ.
"I'm going to say upfront that this machine is capable of the best digital sound it has been my pleasure to hear, the best by some margin. It will open your eyes to the stunning potential of SACD, so often hidden by mediocre implementations, and can go head to head with exotic vinyl spinners for ultimate fidelity. There is no aural sugar coating, artificial warmth or hyped up dynamics designed to impress in the showroom. This is the real McCoy, a machine dedicated to extracting the maximum accuracy from a two channel SACD signal."
"The CDSA SE has to be in very front rank of CD Players regardless of cost. It will do wonders for detail retrieval, imaging and accuracy complete with a fully realized bottom end and open top on the best Redbook recordings. Its failings are those of the medium itself. As to SACD, this is as good as digital gets, and far better than any Redbook CD you will ever hear.
Not a mass market product, but clearly an exceptional achievement and a challenge to vinyl lovers everywhere. Meet my new reference digital source."
Specs:
Type: Digital disc player and transport
Disc Formats: Redbook CD, Stereo SACD, MP3
Digital Outputs: AES / EBU - PCM
DACs: Proprietary Dual Differential DAC Circuit
Analog Output: Unbalanced (RCA), Balanced (XLR) - Pin 2 hot
Output Impedance: 50 ohms (RCA), 100 ohms (XLR)
Output Level (low): 4V (XLR), 2V (RCA)
Output Level (high): 7.2V (XLR), 3.6V (RCA)
CD upsampling: MDAT technology converts to 5.6MHz DSD
System Connections: Infrared remote and RS232
Software Upgrades: Via rear USB port
Power Cable: Kimber Kable PK14 (6ft) included
Dimensions: 17.1 x 15.7 x 5.5 (WxDxH in inches)
Weight: 26.5 lbs
Warranty: 5 yrs (except drive - 1 yr), original owner
Price: $9,995
Full review στο enjoythemusic.com.
Κώστας Φ.
Απάντηση: Review: EMM Labs CDSA SE Stereo SACD Player
Άλλο ένα review του EMM Labs, αυτή τη φορά απο το Positive Feedback.
"The EMM Labs CDSA SE one-box SACD/CD player. This is the latest and greatest from digital/audio brainiac genius Ed Meitner. Featuring all that he knows to date with respect to how to get the bits to sound like music, the CDSA SE features the best of his two-box machines in one easy to use unit. I remember many a CES where I would ask Ed to please make a one-box machine that sounds like his two-box units with none of the stuff that a typical guy needs—the preamp, switching, clocks, and whatnot. Ed, make us guys a simple version that sounds just as good… and do it for less money. Ed would smile and say he would think about it… well the day has come…
The CDSA takes Redbook CDs (the 44.1kHz signal) and upsamples to 5.6448MHz. This is accomplished by Meitner Digital Audio Translator (MDAT) signal processing technology. To paraphrase from the EMM site …"The MDAT addresses the digital signal as a series of sine waves—as is standard convention—the MDAT-equipped CDSA SE processes (and upsamples CD audio to DSD for conversion to analog) by dynamically adapting to the transient nature of the musical signal. In this way, the CDSA SE is utterly unique and singularly able to preserve the phase, frequency and dynamic integrity of the original signal."
CDSA SE also features Ed's own discrete dual differential D-to-A conversion circuit. Nothing off the shelf for EMM, their stuff is pretty much built by them from the ground up. Well, except perhaps the choice of a Phillips drive assembly and various other parts (caps, resistors and such), but even with that, they use their own aerospace-grade composite laminate circuit boards, featuring:
- Copper traces are microscopically smooth on top and bottom, significantly reducing skin effect issues
- Naturally damped sandwich construction offers superior strength and vibration resistance
- Lower dielectric losses and superior heat conduction ensure a more uniform temperature gradient across the circuitry, increasing stability and longevity.
Could I live with the EMM CDSA SE? Oh, most definitely. Am I going to sell the Cary 306? Uh…no. Like 'em both too much let either of them go. Both are too right in their own way… just a different right. Best to say that the EMM is like the best of solid-state and that the Cary is like the best of tube. Not that this is to be a 306 versus the CDSA SE review (easy to compare as they are both wonderful and similarly priced at the top), nor is this a "what is the best player for me to buy" sort of thing. Each is a stellar machine with their own unique features; the 306 allows for user-selected upsampling—both inputs and outputs—and offers HDCD. The CDSA SE does not allow for user-selected upsampling as it takes Redbook and runs the gaboogers out of it (up to the nether regions of to 5.6448MHz) and is a straightforward machine—plop in a disc and hit play. Both play SACD. Both feature…. Ahhh, get the EMM—or the Cary if you lean that way—and enjoy your music. Highly, HIGHLY highly, highly recommended. The EMM CDSA SE is a killer machine with little, if anything—like nadda, zilch—to deter the music lover from being happy!"
-- Dave Clark
Full Review
To cd απλα δεν παιζεται!!!
Πραγματικα απορεις αν ακους βινυλιο η cd!!!!Οσο περιεργο και αν ακουγεται αυτο ειναι η αληθεια 100%.
Εγω προσωπικα δεν εχω ξανακουσει τετοιο πραγμα!
Απιστευτες χροιες, δυναμικα, αναλυση, και μια απιστευτη ησυχια! Τα οργανα εχουν αποσταση μεταξυ τους τρομερη ακριβεια στη τοποθετηση σε ενα τεραστιο stage.
Ειναι η πρωτη φορα που ακουω τα cd μου απο την αρχη ως το τελος και μαλιστα cd που δεν ακουγα ποτε!!!
Δεν υπαρχει περιπτωση να σε ενοχλησει κατι η να ακουσεις ψηφιακιλα εστω και για λιγο!!Απλα απολαμβανεις τη μουσικουλα σου!
Πραγματικα δεν νομιζω οτι η αναπαραγωγη cd μπορει να γινει καλυτερη πολυ συντομα!
Κώστας Φ.
Kαλορίζικο το εργαλείο, Μιχάλη.
Αυτά για το βινύλιο μην τα λες, θα έχουμε αντιδράσεις από φανατικούς (και των δύο πλευρών)! :mrgreen:
Σοβαρά τώρα, εννοείται πως το player είναι κορυφαίο, αλλά το άκουσε κάποιος "ορκισμένος εχθρός των ψηφιακών" ή έστω κάποιος fan του βινυλίου να σου πει τη γνώμη του για τη σύγκριση αυτή;
Ευχαριστω πολυ Κωστα!
Το ακουσαν πολλοι!!!! Και κατεληξαν ολοι στο ιδιο συμπερασμα, οτι εχει ολα τα καλα του βινυλιου αλλα παραλληλα και του ψηφιακου. Πιστευω οτι σε ενα blind θα ειναι δυσκολο να πει καποιος ποιο ειναι ποιο!Ειμαι σιγουρος για αυτο.
Αυτη τη στιγμη το στρωνω και ειμαι στις 106.30 για cd και 22 για sacd...Μην γελατε τις μετραω. Η βελτιωση ειναι συνεχης. Λεγεται οτι χρειαζεται γυρω στις 300 ωρες.
Σιγά μη γνωρίζει ο τύπος να φτιάξει DAC. Άμα δεν ξέρει αυτός, ποιος ξέρει!!!
Έχει νόημα η αγορά του σήμερα ? Ή θεωρείται ξεπερασμένο? Κυκλοφορεί σε μεταχειρισμένο κοντά στα 3κ
Δεν αξίζει, αν θυμάμαι καλά δεν έχει ούτε ψηφιακή είσοδο.
Ποιος αγοραζει CD player για ψηφιακη εισοδο;
Μια ακροαση θα δειξει...Αν θες να το αναβαθμισεις απο κατι πολυ καινουριο που πιθανον να εχεις,ισως να μην αξιζει.Τα dac εχουν βελτιωθει παααρα πολυ τα τελευταια χρονια.
Αν μη τι άλλο θα έπρεπε να έχει μια είσοδο!
Βασικά ποιος αγοράζει γενικώς CD player αλλά ας μην το κάνουμε θέμα.
Αν θελεις εισοδους παιρνεις dac.Αν εχεις ποικιλια απο δισκακια,δεν σου χρειαζεται αλλη ψηφιακη πηγη.
Οσοι ξερουν να ακουνε και εχουν αναλυτικο συστημα ωστε να απολαμβανουν τις αρετες και την υπεροχη των CD εναντι του streaming,αγοραζουν ακομα και σημερα 8-)
Όχι. Αν δώσεις ένα σεβαστό ποσο για να πάρεις CD player σήμερα πρέπει να έχει αν μη τι άλλο μια είσοδο. Το CDSA το είχα αγοράσει καινούργιο το 2008 νομίζω, με τα σημερινά δεδομένα δεν αξίζει ηχητικά ποσο μάλλον χωρίς είσοδο.
Οχι. Ότι συλλογή και να έχεις είναι ένα πολύ μικρό ποσοστό της παγκόσμιας μουσικής.
Οχι. Βγάζοντας από το παιχνίδι τα μηχανικά σφάλματα ενός transport μπορείς πλέον να παίξεις πολύ καλύτερα απο stream.
Ακόμα και με την μεγάλη χρονική απόσταση
που μεσολάβησε
Έχω λίγο μπερδευτεί.
Έπαψαν να είναι ζητούμενα αυτα;
Σήμερα δεν αξίζει συγκρινόμενο με τι..
  • loggeo
DAMBO
