Θα μας τρελάνουν τελείως....Αυτό τώρα πώς δουλεύει; Sugar Cube Noise Filters.....
Κώστας Φ.
Aυτοί οι Marja & Henk του 6moons φαίνεται πως δεν την παλεύουν καθόλου.
Όχι ότι μου κάνει εντύπωση βέβαια:
Όπως φαίνεται, το ότι περνάνε ώρες παίζοντας με τα διάφορα HiEnd μαντζούνια είναι το λιγότερο....
Δείτε τώρα ένα ακόμη "καταπληκτικό" tweak που ανακάλυψαν...
Με μόλις 200 ευρώ αγοράζετε:
Αναλυτικότερα:
Each noise filter consists of a minuscule Indian rosewood cube. In the middle of one face of the cube, a 1mm hole is drilled all the way through to the other side. Two adjacent holes are drilled in the face perpendicular to the former, leaving two opposing faces unadorned. Each noise filter is attached to a wall or other surface with a tiny dot of tack on an unadorned face.
The product package consists of 17 noise filters, an ASI diffuser, some white tack and an instruction sheet. Considering the amount of work involved to cut, sand and drill out each sugar cube -- all done by hand -- the asking price of €10/per is very friendly. Add €30 for the handmade diffuser and the whole package sets you back €200 including tax.
Και έχει και οδηγίες (μην τα βάλεις λάθος και καταστρέψεις τον ήχο σου):
"The noise filter should be installed with two holes up. Start from the floor. The interval between the noise filters should be 70cm on each vertical line. If the room has too strong reflections, it can be 50cm between them. If the room is overdamped, go for 1 meter between them. You may need to install the noise filters with one hole up if your system generates stronger HF noise. We have four zones from bottom to top, vertical and horizontal."
Βγάλανε που λέτε κάδρα από τον τοίχο, μετακίνησαν τα μηχανήματα για να μην ενοχλούν, πήρανε τις μεζούρες και ξεκίνησαν....
Στην αρχή δεν τα έβαλαν καλά και η Marja είχε πονοκεφάλους.... :143:
We started out with the cubes' two holes pointing straight up. When the initial setup was completed with the help of the ruler and the weighted rope to align all cubes within 1mm offsets, we put the electronics back in places and connected them.
At this time Marja reported an unsettling pressure in the room not unlike the sort we had encountered at ASI's Paris headquarters when too many resonators were active. This pressure can lead to headaches and general discomfort. Mind you, ASI's stuff is powerful - experiment before you judge prematurely.
Μάλιστα.... "ASI's stuff is powerful".
Τώρα παίζει και "ASI" να είναι συνθηματικό για τον τύπο που τους προμηθεύει με χόρτο και χάπια. Δεν εξηγείται διαφορετικά. :116:
Λέτε να είναι Ζωνιανός;! :144:
Τέλος πάντων, με τα πολλά, βρήκαν τη σωστή θέση και κατέληξαν ότι:
At a budget-friendly price, the ASI sugar cubes are a very powerful room acoustic enhancer. It takes some effort to set up the grid but it gives the user unprecedented control over how the room responds as a major musical contributor.
...και:
The sugar cube noise filters can transform any room's acoustics and are indispensable for any serious music lover.
Εγώ μόνο να σας ξαναθυμήσω ότι μιλάμε πάντα γι'αυτές τις μικρές κουκίδες που βλέπετε πίσω από το ηχείο στην παρακάτω φωτογραφία:
Αν οπωσδήποτε θέλετε να διαβάσετε περισσότερα: 6moons.com
Αυτά. Πάω να βρω ένα τοίχο.
:623:
CostasD
Νταξ... Αν δεν πρόκειται για κάποιο κοινωνικό πείραμα οι άνθρωποι χρήζουν βοήθειας!
Ημίθεος
Δεν είναι ινδιάνικο ρε, Ινδικό είναι, ποτισμένο με πατσουλί.
Απάντηση: Θα μας τρελάνουν τελείως....Αυτό τώρα πώς δουλεύει; Sugar Cube Noise Filter
εκπληκτικο!... αν εχει κατω απο 300ευρω δε θα πουλησει... αν εχει πανω απο 3.000 θα γινει αναρπαστο!!! (χμ...)
Αυτοί οι ζαχαρόκυβοι δεν κάνουν τίποτα χωρίς τον ανεμιστήρα οροφής... (διάχυση των κυμάτων). Ναι κύριοι, μιλάμε (τώρα) και για ΣΥΣΤΗΜΑ οχι components...
Σημ. Είναι high-end ανεμιστήρας με ειδική σχεδίαση στα πτερύγια. Πάρτε τώρα τους ζαχαρόκυβους φτηνά (μήπως ξέχασαν κανένα μηδενικό;;;) αλλά μετά ...
(πίσω έχει η αχλάδα την ουρά...)
n_olympios
Μαντιναδόρος!
Re: Απάντηση: Θα μας τρελάνουν τελείως....Αυτό τώρα πώς δουλεύει; Sugar Cube Noise Fi
200€ λέμε ρε, μα καλά δεν προσέχεις? :121::136:
κριμα δεν κανουν για μενα εχω ερ-κοντισιομ. Ασε που οσο περναει ο καιρος ο ηχος απο αιχμηρος μαλακωνει
τα τρωνε οι μυγες.
A!!! Επιτέλους, τώρα κατάλαβα.... :138:
Αυτό είναι που λένε οι Audiophiles, "sweet spot" στον ήχο!!!! :135::135::135:
εγώ πιστεύω ότι οι ζαχαρόκυβοι κάνουν δουλειά. να πάτε να τους αγοράσετε και θα με θυμηθείτε!
Ναι ρε μανα'μ συμφωνω, μια χαρα δουλεια κανουν οι ζαχαροκυβοι. Αλλα εγω τον καφε μου τον πινω σε κουπα, οχι σε ηχειο :137:
αν δεν ειναι Harmonics οι κυβοι δε λεει...
αραγε δουλευει κι η φρουκτοζη σε περιπτωση σακχαροδιαβητικου ηχητικου αποτελεσματος;
Αν επιβιώσω από το εγκεφαλικό θα ζήσω πολλά ακόμα χρόνια.
:623::623::623:
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Ρε τι πίνουν τα παλικάρια και δεν μας δίνουν;
(σημείωση το ΥΠ. Υγείας προειδοποιεί: Η παρατεταμένη χρήση μπάφων καταστρέφει τα εγκεφαλικά κύτταρα)
Τετοια βαζω στον καφε μου ρε συ. Εχω παρει μερικα γραμμαρια στο σβερκο τελευταια. :137:
Εφόσον υπάρχουν σημαντικές - σύμφωνα με τους reviewers - μεταβολές στην ακουστική συμπεριφορά του χώρου θα πρέπει αυτές να είναι - θεωρητικά τουλάχιστον - μετρήσιμες.
Εγιναν κάποιες μετρήσεις απο το ζεύγος ;
tzino
