Teufel 5.1-Design-System Motiv 10 test
Ουάου! 10 αστέρια!
Έχει ξαναπάρει τόσα αστέρια κάποιο ηχείο; :111:
(Σιγά μη δεν πήγαινα να δω :138:)
Απάντηση: Teufel 5.1-Design-System Motiv 10 test
επειδη οπως δεν ξερετε εχω σχεσεις με το σαιτ του λουκα
αν θελετε ανεβαζω το μειλ οταν τους ρωτησα τι να διαλεξω μεταξυ jamo-teufel
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Και δεν το ανεβαζεις?Περιμενεις και αδεια?:126:
Dear Anargiros
I am assuming that you are referring to the setup menu where you enter a distance for the subwoofer and main speakers. The reason for entering this distance is so that you get good imaging for all of your speakers. Most people can not have all the speakers at an equal distance from the listening position, so this feature makes sure that the sound from each speaker arrives to the listening position at the same time even if some speakers are further away from you than others.
So please enter the distance from the subwoofer and your other speakers to your primary listening seat.
Ultra2 systems are designed for a listening distance of about 12 feet (approx 3.6 meters). If your subwoofer is more than 9 meters (30 feet) then this must be a very big room with a very big screen. If you are in some kind of hall or conference room then maybe you need a more professional kind of system.
If this is a home theater then I can not really make a recommendation of the two speaker systems. They are both excellent but the Teufel products are newer, if this is important to you. Teufel also gives you more choices for the subwoofer. Teufel has single Ultra2 subwoofers that meets our requirements including some very big ones. If the room really is very big then you should think about getting as good a subwoofer as you can afford for your budget. The D7 Jamo system needs two subwoofers to meet our required Ultra2 levels. Again, if this really is a very big room then you will probably need at least two.
Good luck.
George
THX Ltd
10+1 αστέρια; :111:
Ξανά ουάου! :204:
Και μετά πάει ο κατασκευαστής και λέει στον τάδε αντιπρόσωπο της Χ χώρας:
Ορίστε τα... βραβεία μας. Ιδού τα προϊόντα μας, έχουν βραβευτεί παγκοσμίως!!!! :143::138:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Παντως Αργυρη, δεν ξερω εαν το θυμασαι η το ειχες δει, στο
site της ΤΗΧ πριν 8-9 χρονια εγραφε τις αγαπημενες του σειρες
ηχειων και αναμεσα απο τις 2-3 που ελεγε(δεν θυμαμαι ακριβως)
η πρωτη ηταν η Teufel.
σιγουρα ειναι καλα ηχεια εξαιρετικα θα ελεγα
αυτο που αναφερει ο τζορτζ(οχι ο λουκας) ο Mansfield ειναι το επιθετο.
ειναι οτι ειναι πιο νεα εταιρια σε σχεση με τη γιαμο
Αν αυτο μου λεει κατι ,οπως αναφερει.
η γιαμο αν θυμασαι το 1992 ηταν η πρωτη που παρουσιασε ηχειο thx και μαλιστα διαρουμενο
ιν δι αδερ χεντ η τεου, ειναι τρελλη κομπανια.
Και αν αναλογιστουμε την αυξηση που εκανε η jamo
πανε γυρω στα 1050 το τεμαχιο
οχι λιγα .
Sυντομα θα εχω μια ευκαιρια για ενα σωστο Α-Β των
jamo D7- klipsch
για να δουμε τι θα ακουσουμε
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
H πλακα ειναι πως ο κοσμος διαβαζει ολα αυτα που γραφουμε για
την Teufel και μετα μου τηλεφωνουν και μου στελνουν πμ απαιτωντας:
"Αυτα θελω να μου βρεις!"
Παιδια, για ακομα μια φορα, η Teufel δεν διαθετει δικτυο αντιπροσωπων σε καμια χωρα του κοσμου και πουλαει μονο απ'ευθειας
απο το εργοστασιο.
Ειναι ο μονος τροπος να τα αποκτησει κανεις, με οτι αυτο συνεπαγεται:126:
κριμα
αλλιως πιστευω οτι θα ειχαν κανει πολλους αντιπροσωπους να χασουν τον υπνο τους
να και κατι απο τοτε
http://www.hifi-forum.de/viewthread-171-962.html
jamo παντα
Κώστας Φ.
Και ο Γιώργης Teufel προτείνει λοιπόν.
Το ότι τα προϊόντα (products) είναι νεώτερα το θεωρεί θετικό.
Γι'αυτό και στην επόμενη πρόταση, όπου αναφέρει ότι η Teufel δίνει περισσότερες επιλογές σε sub, αναφέρει το "επίσης" (also). Διαφορετικά θα πέταγε κανένα "on the other hand"..
Άσε που λέει ξεκάθαρα ότι θέλεις δύο Jamo sub για να πιάσεις τα spec τους ενώ με την Teufel κάνεις δουλειά και με ένα.
Απάντηση: Re: Teufel 5.1-Design-System Motiv 10 test
ειναι πως βλεπει κανεις το ποτηρι
μισογεματο ή
μισοαδειο
η ιδια η jamo οπως και η klipch προτεινουν 2 σαμπ για την προδιαγραφη
εδω χανει πολυ η teu.
Αν δεν ξερεις το γιατι σου λεω,
οσο αφορα το οτι αναφερει οτι ειναι teu ειναι πιο νεα στο χωρο
αυτο σημαινει οτι η γιαμο εχει σχεδον 20 χρονια εμπειρια
ξερεις,
τοτε που καν η teu δεν υπηρχε
Γιαυτο λεω ειναι πως βλεπεις το ποτηρι
και εδω
http://thx.com/home/setup/speakers/sub.html
βλεπεις την θεση που προτεινει για
3
4
σαμπ
στην θεση 1 δηλαδη κατω απο το κεντρικο ειναι η θεση που το σαμπ προδιδει λιγοτερο την θεση του σε σχεση με οποιαδηποτε αλλη θεση
αυτο το βρηκα και μετα απο τρελλες δοκιμες
+ η θεση στη γωνια κανει το σαμπ να παιζει πιο δυνατα αλλα μεγευνθυνει και τα προβληματα του χωρου
αυτα
Κώστας Φ.
Re: Απάντηση: Re: Teufel 5.1-Design-System Motiv 10 test
μισογεματο ή
μισοαδειο
Βρε Αργύρη, το τι εννοεί ο ποιητής στο email δεν είναι θέμα άποψης, αλλά ορθής μετάφρασης.
Και ο ίδιος ο Γιώργος ο Λούκας λέει ότι 2 sub είναι καλύτερα από ένα, αλλά αυτό δεν είναι κάτι νέο και είναι γενικότερη παρατήρηση.
Αναφέρει όμως και σε προηγούμενη πρόταση ότι η Teufel μπορεί να πιάσει τις προδιαγραφές Ultra2 με ένα sub ενώ η Jamo χρειάζεται δύο! Φαντάζομαι για να το λέει θα τα έχουν μετρήσει, άρα πάλι δεν είναι θέμα άποψης αλλά ένα δεδομένο.
η προδιαγραφη του λουκα οριζει
115 db στους 20 κυκλους.
Aυτο πιανεται με 2 jamo,
και ενα teu .
Tα σαμπ της jamo δεν ειναι αναλογα με τα ηχεια της, σε καμμια περιπτωση
τα ηχεια φορανε επωνυμες σκανδιναβικες μοναδες
επιπεδου krell sonus faber.
Kαι το σαμπ μαλλον τσαινια,
οπως οι μοναδες τις teu.
Mε μια διαφορα οι μοναδες της teu παιζουν τρελλα
τα σαμπ των δανων οχι.
Τελος βαζοντας ενα σαμπ oπως το teu θα εχεις μια χαοτικη σκηνη
μπροστα , αλλα θα χανεις σε σχεση με το να βαλεις ενα σμαπ μπρος και ενα πισω,
εννοηται οχι jamo .
Βαλε ας πουμε ενα earthquake 15ιντσο
υπερκαλυπτει την προδιαγραφη του λουκα κατα μια οκταβα .
Kαι εχει μολις 1090 ευρω
αρα επι 2
= 2180 ευρω]
και εχεις 135 db επι 2 στο χωρο σου στους 20 κυκλους που οριζει
ο λουκας.
Και δεν συζηταμε που θα στησεις το ψυγειατο teu,
μπροστα το ξεχνας.
Eκτος αν το ξαπλωσεις
οπως ηταν το παλιο teu
Κώστας Φ.
Καλά εσύ τα ξέρεις καλύτερα αυτά - γι'αυτό και θα σε ρωτήσω όταν αγοράσω sub. :116:
Επί του email και μόνο σχολίασα.
agnooumenos
