Δοκιμάζουμε το DUNE HD Center
Βαγγέλης Λάμπρου
Απάντηση: Δοκιμάζουμε το DUNE HD Center
Τα καλύτερα για τέλος....
Ερώτηση-Σύσταση απο PSA
In Greece everyone is using ANSI on the srt subtitles but with DUNE we have to transcode it to utf8 as otherwise they are unreadable. This is essential and critical to be implemented as it is a key feature to avoid any PC interaction.
Απάντηση HDI
The next firmware version will very probably have this possibility.
So it will support Greek subtitles not only in UTF-8 encoding (as now), but also in CP1253 encoding.
Συμφωνούμε με την άνω κωδικοποίηση για να του απαντήσω καταφατικά;
Συμφωνούμε!Αυτό περιμένω να κάνουν με το encoding των υποτίτλων για να το παραγγείλω!
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Το γνωρίζατε οτι είναι και ως DVD αλλά και ως Bluray.....Region Free ????
Διαβάστε πιο κατω και δείτε τις 5 πρώτες λέξεις της εισαγωγής (χεχε)
Aντε να μιας φτιάξει και κανένα espresso να τελειώνουμε.....
Ιn the spirit of honesty where we believe as long as we can purchase foreign
DVD's and Blu-ray and import these, we should be allowed to play them on our
players as well and not be locked by decision of other companies who decided
to region lock your devices...
In such spirit, we release publicly a pacth that will allow your player to become
DVD Region Free and on top offers a region selection fro Blu-Ray... Here's
what you do with this patch (easy):
- This patch is only for firmware version "081226_1216". (current version)
- Copy the file to USB stick or external HDD.
- Connect your USB or HDD to the player
- Select the file from the browser and press "Enter" button.
- Eventually, "Success" should be shown on the screen.
- After that, it becomes possible to switch regions: on
the main screen: press "Mute" button 4 times and then
1 or 2 or 3 for Blu-ray region selection.
-You can use the current patch to select DVD region as well... Press mute 3X and enter the 01 / 02 / 03 etc... depending on the region you want. Initially this patch does not change region for DVD, only offers selection of it...
As always, use at your own risk.
http://www.mpcclub.com/modules/Downloads/tools/dune_service_region_switch.dsf
We will issue updates whenever updates apply to new firmware versions
undoing this patch however know this is not a standard service and should
be considered as extra option from the community.
Μολις το δοκιμασα.
Κατεβαινει αμεσα, σε 3-4'' περιπου και στο τελος σου βγαζει
"Sucess"
Το εκανα με την τελευταια αναβαθμιση.
Δοκιμασαμε ενα blu ray ζωνης 1(Broken arrow) οποτε πατας
4 φορες το κουμπι "Mute" και μετα τον αριθμο "1"
Το Dune σε ρωταει αν το δισκακι που θα παιξεις ειναι περιοχης 1
και πατας το ΟΚ
Παιζει αμεσως και....τζιτζι:126:
Προσοχη!
Σε περιπτωση DVD πατας το "Mute" μονο 3 φορες και μετα τον
αντιστοιχο αριθμο της περιοχης που θελεις.
Βαγγέλης Λάμπρου
Μολις το δοκιμασα.
"Sucess"
Sucess.....τύπου "σουξέ"....κοιτάξτε ανορθογραφία
Πως φαίνεταο ο Αγγλομαθής καιο διαμένων στο εξωτερικό....χεχε
Αλλη μια ξενερωτη ερωτηση απο εμενα :137:
Στα settings στο Mymovies εχει μια επιλογη "Dune Content Paths". Να θεωρησω οτι πρεπει να βαλουμε τους σκληρους που ειναι και οι ταινιες?
Ρωταω γιατι ηδη εχουμε δηλωσει που ειναι οι ρημαδες oι ταινιες με την επιλογη "Monitored folders".:118:
Καλημέρα σε όλους. Ναι πρέπει να το δηλώσουμε γιατί το Monitored folders είναι μόνο για το ίδιο το Mymovies. Μάλιστα αν έχεις προβλήματα με τις ταινίες που βρίσκει αυτόματα το Mymovies (ενοώ δεν είναι πραγματικά αυτές που έχεις στο σκληρό σου) τότε μπορείς να απενεργοποιήσεις το Monitored folders και να κρατήσεις μόνο "Dune Content Paths" επιλεγμένο. Για κάθε ταινία που θα προσθέτεις χειροκίνητα ο φάκελος της στο σκληρό σου θα ενημερώνεται κανονικά.
- Ανδρέα καλημέρα και σε εσένα. Το θέμα μου δεν λύθηκε ούτε με το τελευταίο firmware με ότι ρύθμιση και να έκανα και με κανένα είδους αρχείο ή δισκάκι.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Και εγω γιατι ειμαι εδω?:126:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Ιδου και η νεα αναβαθμιση:
Changes since 090313_1955_beta:
NOTE: This is a RELEASE CANDIDATE: a stable/recommended firmware version
will be released based on this beta version if no serious problems /
regressions found. New big features (new Sigma SDK, autoframerate etc) will
come into further beta versions.
- Includes also all changes from 081226_1216_update2, including:
- Support for emergency firmware recovery.
- Robustness improvements for Gigabit Ethernet module.
- Support for a new version of Gigabit Ethernet module.
- A solution for the problem with inability to bitstream audio when playing
certain Blu-ray disks (sending stereo-PCM to S/PDIF and multichannel PCM
to HDMI instead of bitstreaming original audiotrack).
- A new option "Blu-ray audio" introduced in Setup / Audio menu, with
possible values "Best quality" and "PiP support".
- When set to "Best quality" and "Digital audio output mode" set to
"bitstream", the primary audiotrack is sent to S/PDIF and HDMI as
bitstream not depending on the presence of secondary audiotrack;
secondary audio/video functions ("PiP") are disabled.
- When set to "PiP support", secondary audio/video functions are
enabled, and, to support these functions, the player is allowed to use
"decode" mode instead of "bitstream" mode on digital audio outputs (so
audio quality may suffer, e.g. stereo-PCM may be sent to S/PDIF
output, and S/PDIF, and multichannel-PCM may be sent to a HDMI
output).
- Various improvements/bugfixes for handling of HD audiotracks in files.
- Improved support for bitstreaming Dolby TrueHD and DD+ (EAC3)
audiotracks during file playback.
- More robust handling of DTS HD and DTS HD MA audiotracks during file
playback; some freezes fixed.
- Faster switching to DTS HD MA audiotracks during file playback.
- Bugfix: specific VBR HD audiotracks in MKV files could be handled
wrongly.
- Bugfix: specific files with HD audiotracks could cause no audio on
HDMI in bitstream mode when an external audiotrack was present.
- Some other minor bugfixes.
- Added emergency support for ejecting optical disk from the internal
optical disk drive in case when the player hangs up on an attempt to read
the disk. Instructions:
- Switch the player off (using the power button on the player).
- Switch the player on.
- Press and hold the EJECT button on the front panel of the player.
- Wait for the player to finish loading process (may take about 1
minute).
- The player should eject the disk in the end of the loading process.
- Improved firmware upgrade progress indication:
- Flash memory update phase is indicated as 0..100% (rather than 0..66%,
as previously).
- Extra applications installation phase is indicated explicitly.
- Added support for "primary" drive as a partitionsless drive (e.g. USB
flash drive formatted w/o a partition table).
- Added support for more encodings for subtitles and playlists files:
- CP1250, CP1253, CP1254, CP1256, CP1257, CP1258 (in addition to
previously supported UTF8, CP1251, CP1252, CP1255).
- (See Setup / Misc / Encodings.)
- Better support for Vietnamese language (some previously missing
characters added to fonts).
- Better support for Romanian langauge (some previously missing characters
added to fonts).
- Bugfix: certain hand-made DVD-Video disks violating DVD specifications
could cause playback crash.
Κατεβαζετε απο εδω
Το αγορασα και εγω χθες και μολις κατεβασα το νεο fw και δουλευει κανονικοτατα.
Οι πρωτες εντυπωσεις πολυ θετικες, ευκρινεστατη εικονα και πολυ καλη κινηση.
Αλλα αυτο που με εχει ενθουσιασει ειναι το region-free σε Blu Ray και DVD.
Βαγγέλης Λάμπρου
Τώρα που πήρες τρελόγιατρε και Dune να δω τι θα τα κάνεις τα WDTV.....
Ανδρέα δεν έχει άλλες επιστροφές. Τέλος
Βαγγέλης Λάμπρου
Από σήμερα λοιπόν και ANSI Ελληνικά όπως ζητήθηκαν.
Δοκιμάσθηκαν με ένα σκληρό με υλικό mkv του Πάνου Βογιατζάκη και έπαιξαν αμέσως.
Επομένως δεν χρειάζεται πλέον καμία αλλαγή στη γραμματοσειρά.
Kανενα συγκριτικο με ακριβοτερο-εξωτικο BR player κανατε?
Ετσι απο περιεργεια....
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
[reliops=DUNE HD Center][youtube]Vyhjwh_bYEo[/youtube][/reliops]
Δειτε και αυτο το βιντεακι(επιλεξτε HD)
Εκτός από τον εσωτερικό σκληρό που έγραψα σχετικά στην προηγούμενη σελίδα κάπου διάβασα και ότι το Optical Drive δίνει τα δεδομένα του σε θύρα USB και μπορεί να συνδεθεί με PC για Ripping των δίσκων......Μόλις το ξετρυπώσω θα το περάσω και αυτό μέσα.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Αυτό εδώ : http://www.lundman.net/wiki/index.php/Dune:NTFS δίνει τη δυνατότητα να συνδέσουμε σκληρούς με NTFS ως read/write οι οποιοι φυσιολογικά μπορούν να είναι μόνο read. Δεν το έχω δοκιμάσει ακόμα.
Μανο, καταλαβαινω την χρησιμοτητα της προσθηκης σκληρου στο
Prime αλλα ομολογω-λογω ασχετοσυνης- πως δεν μπορω να καταλαβω
την χρησιμοτητα του ως ανω...:118:
Re: Απάντηση: Δοκιμάζουμε το DUNE HD Center
Καλησπέρα και πάλι...Οσοι από εσάς έχετε συνδέσει το Dune με pc και έχετε αποθηκευμένα αρχεία κατεβάστε και δοκιμάστε αυτό το πρόγραμμα : http://www.mymovies.dk/media/My Movies-2.53PR2-DuneSpecial6-Server-Client-x86.zip
Δημιουργεί μέσα στο Dune μία απίστευτη οπτική βιβλιοθήκη. Φέρνει το μηχάνημα σε άλλη διάσταση.Σερφάρετε μέσα στο φάκελο Index που δημιουργεί το πρόγραμμα και θα εκπλαγείτε.
(Ανδρέα Καλησπέρα και σε εσένα. Εγώ με το πόνο μου.Σε παρακαλώ επικηνώνησε με hdi γιατί δοκίμασα και σε άλλο ενισχυτή τις αναλογικές 7.1 και δεν εξάγουν τίποτα. 99% φταίει το μηχάνημα εκτός αν μας δώσουν άλλη λύση.)
Να κανω μια ερωτηση σχετικα με το mymovies .Δουλευει και σε windows xp η μονο σε vista?
roberto_portale
