Twisted Pear Buffalo (ESS Sabre DAC)
Κώστας Φ.
Έφτασαν τα πρώτα kit.
We will have 20 Buffalo DAC modules available from the first run of boards, and we are planning another order which will arrive shortly to meet expected demand. We also have tweaked the component values for the IVY kit (I/V stage) for optimum performance with the Buffalo. there are two minor errors on the silk screen labeling for these boards, but I will include a printed correction.
Pricing for the first 20 modules will be as follows:
Buffalo DAC Module, fully assembled: $129
Buffalo DAC Module + Dual Power Supply Kit (LCDPS): $169
Buffalo DAC Module + Dual Power Supply Kit (LCDPS) + IVY I/V Stage Kit + Bipolar Power Supply Kit (LCBPS): $275
These will include the standard compliment of mounting hardware and terminal blocks for making the connections (unmounted). The IVY comes as a kit which requires assembly (see Opus page for details).
Once we have more boards in stock, we will offer them bare, and with just the DAC chip mounted. Pricing for the next board run will depend on how many we order, but will likely be the same (or at least close) to these prices. The price increase over the other DAC modules is based mainly on the cost of the ES9008 DAC chips, but also the need for micro-controller programming, etc.
I have no plans at this time to offer the DAC chips by themselves.
I plan to start shipping these modules on Monday, May 5th, assuming all the parts arrive on time. I will begin taking orders for them on Saturday, April 26th at 10PM EST. Check for the new Buffalo page to appear.
Έχει βουήξει ο κόσμος για το συγκεκριμένο chip και οι πρώτες εντυπώσεις είναι θετικότατες.
Mία σχετική αναφορά στο Stereophile:
It can provide eight channels of high-quaity surround sound or two channels of exceptionally high quality stereo sound. "Each time you double-up the channels, you drop S/N," Mallinson said. "So you gain a 6dB drop in noise running this in stereo mode, giving us a measured 134dB dynamic range, -118dB THD from 44.1kHz to 192kHz sample rates
και technical details: Click (pdf)
Γενικώς έχει ψωμί η υπόθεση...
Stay tuned. :144:
Αντί να γυρίζεις τη σούβλα, τριγυρίζεις στο δίκτυο...
Να σε δω τι θα κάνεις σε δυο βδομάδες από τώρα,
όπου το μόνο dac που θα ακούς θα είναι από dakota :138:
Κώστας Φ.
:144:
Κώστας Φ.
DIY George - αν και στην ουσία μόνο συναρμολόγηση χρειάζεται (πουλάνε έτοιμα τα boards).
Click
Κώστας Φ.
Φυσικά το Heraklion Team του AVSite παρακολουθεί από την πρώτη μέρα το σχετικό thread στο diyaudio.com και κάποια μέλη του ακούν με τον προκάτοχό του εδώ και 4 μήνες.
Περισσότερα σε σχετικό thread γιατί από αυτά που βλέπω έχει μείνει πίσω το DIY community και ψωνίζει ακόμα κάτι τελειωμένα diy kit DACs από κινέζους και είναι κρίμα. :144:
Η πρώτη (;) εμπορική συσκευή που χρησιμοποιεί το Sabre είναι το McIntosh MCD 500 player των 8000 ευρώ. Το δοκιμάζουν στο γερμανικό Stereoplay Φεβρουαρίου.
The review sais that McIntosh uses an OPA2134 after the DAC, followed by some NE5532 as line output drivers for both balanced and unbalanced outputs.
Ερασιτέχνες...
Το δικό μας θα είναι full διακριτό στην έξοδο. :144:
Περισσότερα στο σχετικό thread του diyaudio.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: Twisted Pear Buffalo (ESS Sabre DAC)
Ερασιτέχνες...
όλο μέλι, μέλι και τηγανίτα τίποτε...
Άντε γιατί άρχισα να ψήνομαι για κατασκευή dac...
Κώστας Φ.
Σύντομα θα ανοίξουν οι παραγγελίες για το νέο Buffalo που θα βασίζεται στο νέο DAC της ESS, το Sabre32.
Ψωρο-μετρήσεις εδώ κι εδώ.
Απάντηση: Twisted Pear Buffalo (ESS Sabre DAC)
παρήγγειλες ή ακόμα?
πάρε καβάντζα καμιά 10-αριά, δε θα παν χαμένα, όλο και κάποιοι θα τα φροντίσουν σα "παιδιά" τους....
Κώστας Φ.
Re: Απάντηση: Twisted Pear Buffalo (ESS Sabre DAC)
Mέσα στη βδομάδα θα ανοίξουν τα pre-orders λογικά.
:144:
Κώστας Φ.
Τι έγινε ρε παιδιά;.. Ακούω ότι τα κάτι made in Heraklion Buffalos έχουν ανέβει Αθήνα και ζορίζουν (για να το θέσω ευγενικά) άλλα, ακριβότερα και πολύ ακριβότερα, DAC σε κοντρίτσες.. :144:
Για πείτε, για πείτε... :126:
Σε μια συγκριτικη ακροαση που καναμε συγκρινοντας το Buffalo ESS με ενα Orpheus DAC One (παλια σειρα) το αποτελεσμα ηταν συντριπτικο υπερ του Orpheus σε ρεαλιστικοτητα και αληθοφανεια. Το Buffalo ακουστηκε λεπτοηχο και μειωμενα σωματα πραγμα που οδηγουσε στην εντυπωση της υψηλης αναλυσης (οπως περιπου και το Benchmark ισως με μεγαλυτερη αναλυση και αναδειξη λεπτομερειων). Η ακροαση εγινε με 4-5 κομματια πολυ απλα με πιανο, φωνες και ακουστικη κιθαρα και παροντες ηταν 3 και καποια στιγμη ηρθε και τεταρτος ακροατης.
Το μηχανημα που ακουσαμε ομως ηταν εντελως αστρωτο και σιγουρα πρεπει να επαναλαβουμε την ακροαση με καποιο στρωμενο για να μη καταληξουμε σε λαθος συμπερασματα. Εαν ο Κωστας φερει καποιο στρωμενο μηχανημα εχω κανονισει να επαναλαβουμε την ακροαση με την παρουσια και ενος Weiss Medea....
ε οχι και στην εντυπωση της υψηλης αναλυσης γιωργο.
δεν εχω ακουση το orpheus και δεν μπορω να εκφερω γνωμη
αλλα για να δουμε τι θα πουν και τα παιδια που το ακουσαν
χτες το βραδυ.
εμαθα οτι ηταν και ενας ηχοληπτης μαζι.
χτες το βραδυ.
με παρεξηγησες δεν εννοω οτι δεν εχει υψηλη αναλυση απλα δεν μπορω να πω με βεβαιοτητα εαν και ποσο αυτη η εντυπωση που αποκτα ο ακροατης οφειλεται μονο και μονο στις αναλυτικες δυνατοτητες του DAC η στο γεγονος οτι τα σωματα ειναι λιγο μειωμενα.... Πρεπει να ζησεις λιγο μαζι του για να βγαλεις συμπερασματα εμεις ακουσαμε 5 κομματια ολα και ολα...
Κώστας Φ.
H αλήθεια είναι δεν ήμουν καθόλου σίγουρος για το αποτέλεσμα της δοκιμής. Τo Orpheus είναι ένα πολύ καλό επαγγελματικό DAC στα $4800.
Έλα όμως που, τουλάχιστον ένας από τους συνακροατές σου, σχημάτισε τελείως διαφορετική άποψη από τη δική σου.. :126:
Επίσης εχτές έγινε μία ακόμη δοκιμή - με άλλον αντίπαλο αυτή τη φορά..
Για να δούμε πώς τα πήγε κι εκεί το Buffalo... :144:
Θα υπάρχει ένα στο περίπτερο του AVSite.
Απάντηση: Re: Απάντηση: Twisted Pear Buffalo (ESS Sabre DAC)
Κωστα το μονο που μπορω να σου πω ειναι οτι ενας απο τους συνακροατες ηρθε για να το ακουσει για να το ΑΓΟΡΑΣΕΙ (ψαχνεται για DAC) αλλα τελικα αποφασισε να μην το προχωρησει το θεμα εκτος εαν κατι αλλαξε απο τοτε και δεν το ξερω...
Πόσο κοστίζει το buffalo της δοκιμής (σασί, κουμπιά, καλώδια όλα μέσα, χωρίς εργατικά φυσικά)?
Κώστας Φ.
Re: Απάντηση: Re: Απάντηση: Twisted Pear Buffalo (ESS Sabre DAC)
Μάλλον δεν λέμε τον ίδιο.. :126:
Παντως εαν λαβουμε το κοστος των υλικων του Buffalo θα πρεπει να το δοκιμαζετε απεναντι σε μηχανηματα τουλαχιστον 4000-5000 Ευρω αφου εαν εβγαινε στην παραγωγη φανταζομαι οτι καπου τοσο θα πουλιοταν στη λιανικη... Για αυτο ειναι καλο να το ακουσετε διπλα σε τετοια ακριβα μηχανηματα για να δειτε τι ψαρια πιανει. Η προσκληση να το ακουσεις και διπλα στο Medea του Diabolical φυσικα ισχυει...
Κώστας Φ.
Παντως εαν λαβουμε το κοστος των υλικων του Buffalo θα πρεπει να το δοκιμαζετε απεναντι σε μηχανηματα τουλαχιστον 4000-5000 Ευρω αφου εαν εβγαινε στην παραγωγη φανταζομαι οτι καπου τοσο θα πουλιοταν στη λιανικη... Για αυτο ειναι καλο να το ακουσεται διπλα σε τετοια ακριβα μηχανηματα για να δειτε τι ψαρια πιανει.
Αυτό θα είχε νόημα αν ήταν δική μας σχεδίαση και θέλαμε να το πουλήσουμε λιανική...
Ο χομπίστας που θέλει να δώσει ένα Χ ποσό και να πάρει όσο το δυνατόν περισσότερα με αυτό το ποσό αρκεί να ξέρει ότι υπάρχει ένα DAC κάτω (εώς αρκετά κάτω) από χιλιάρικο και το οποίο είναι δύο-τρεις κλάσεις επάνω από αντίστοιχα εμπορικά DAC του χιλιάρικου και το οποίο κοντράρει στα ίσια πολύ πολύ ακριβότερα DACs.
stavros.vatistas
