Ηχεία Yamaha NS-333
nikforever
Σαν καινούργια, άριστη κατάσταση εμφανισιακά και λειτουργικά, ελάχιστη χρήση, αγορασμένα πρώτο χέρι από Νάκα. Είναι τρέχον μοντέλο (τιμή καινούργιων 308 ευρώ).
Τιμή πώλησης: 180 ευρώ
2-Way Acoustic Suspension Speaker System. The EF (Elliptical Form) Series feature Waveguide horns, PMD (Polymer-injected Mica Diaphragm) woofers and highest quality internal Monster Cable wiring for total enjoyment of digital movie sound and music sources, plus elegant Yamaha traditional piano finish cabinets.
High sensitivity and wide dynamic range for contemporary digital sources
Waveguide horn allows the sound field to be shaped and controlled for optimal spatial expression in home theater environments
PMD (Polymer-injected Mica Diaphragm) cone woofer combines high-performance materials and design for extreme accuracy
Highest quality internal Monster Cable wiring
High frequency response dome tweeter delivers clear, natural highs
Beautiful Yamaha piano finish with elegant elliptical form
Specifications
Type 2-Way Bass-ReflexSpeaker System
Woofers 13cm PMD cone
Tweeter 2.5cm aluminium dome with Waveguide horn
Frequency Response 60 Hz-35 kHz
Nominal Input Power 60 W
Maximum Input Power 150 W
Sensitivity 87 dB/2.83 V/1 m
Crossover Frequencies 3 kHz
Impedance 6 ohms
Dimensions (W x H x D) 200 x 320 x 213 mm
Weight 5.5 kg/unit
c72e263b6c4ba3e16e0d38fa2bcd9207161fe9c0_xl.jpg d941219d862d5a1f29268b6d1dd7f3e0fb0192c1_xl.jpg 0f344f26add2b846aa9d219ff735a9c96ec7d077_xl.jpg ea7bcc73e1a25a8a66279071bc95a249326a7eab_xl.jpg
nikforever
Ανανέωση αγγελίας στα 160 ευρώ, τελική τιμή. Υπάρχουν 2 ζεύγη.
intergrale
