Νέο Sony Ericsson P 950
Αναμένεται γύρω στις γιορτές με χαρακτηριστικά:
Designation:
P950i
SPECIFICATIONS
Dimensions:
5.5 x 10.5 x 2.0 cm
(P910 is: 5.8 x 11.5 x 2.6 cm)
Colour (probable):
Silver on the flip and edges (top and bottom).
Darl grey in the main body and behind the keyboard.
(On the spy pictures you can see it's gold. Gold, it seems, means it's a prototype in the final stage of development)
Screen:
Type: TFT LCD, touchscreen (source)
Dimensions: 4.5 x 6.0 cm
(P910 is: 4.2 x 6.4 cm)
Resolution: 240 x 320 pixels (QVGA), 262 K colours
Full Specifications
Network:
UMTS
Tri-band GSM (GSM 900 / GSM 1800 / GSM 1900)
GPRS
Wi-Fi
Camera:
Front camera for videophone (probably)
Back camera with 2 MegaPixels resolution (1632 x 1224 pixels), CCD (probably)
Autofocus, Macro (probably)
The back of the phone, it seems it's closer to the W800 than the K750.
Note: Info on the back is still very scarce and unconfirmed.
Input:
Flip closed, there's a 5-way button and 2 rocker buttons. Top portion is for virtual keys (displayed on screen), bottom left is return (U arrow sideways) and right is C. Like the the previous models, the flip can be opened and dismantled.
Flip open, touchscreen plus a qwerty keyboard in the body of the phone, similar to the P910 keyboard but with larger keys.
The qwerty keyboard:
• The keyboard has 4 rows of keys. Compared with the P910, there are two extra buttons in the last row. Shift on the left side, and ALT on the right side.
• The keys are larger than the P910's, and are in translucent white plastic. The text is black, and ALT text is blue.
• Keyboard is backlighted (probably).
The jog-dial is smaller than the P910's.
Processor:
Philips Nexperia™ Mobile Multimedia Processor PNX4008 (source)
208 MHz speed (probably)
Processor specifications - NOT phone specifications
Full specifications (PDF)
Key features
• Unique architecture for unprecedented multimedia performance
- ARM9 processor in 90-nm CMOS technology running at 208 MHz
- Dedicated accelerators for video, audio, graphics, and security
subsystems to provide optimized performance and reduce power
consumption
• High-resolution imaging
- Still image capture up to 4 MegaPixels
• Video record/playback
- Simultaneous H.263, MPEG-4 encode/decode of streams up to
CIF resolution at 30 fps
• Video telephony
- Full-duplex, low-latency video encode/decode mode
• Enhanced audio/music
- Dedicated DSP for all audio activities
- Integrated stereo DACs and ADCs
• 3D gaming
- OpenGL-ES compliant 3D graphics accelerator
• Security
- PKI, Symmetric and Hash Coprocessors
- Random Number Generator with fuses for key generation
• Space-saving LFBGA320 package
Operating System:
Symbian OS 9.1
UIQ 3.0
Synchronization:
New ActiveSync system like, licensed from Microsoft.
Applications:
Hermione will not run UIQ 2.1 software out of the box (at least at first). UIQ 2.1 programs will have to be recompiled so that they can be run on UIQ 3.0.
Inside opinion is that a simple application could be made so that all are 2.1 software would work (any developers out there reading?)
Also, it seems that developers now need to purchase a compiler license to create programs.
Symbian Signed:
Symbian Signed Whitepaper (PDF) states:
Platform Security – Symbian OS v9.1 provides a proactive defence mechanism against malware. The platform security infrastructure uses a capability based model which ensures that sensitive operations (for example modifying user data, making calls, using network connections) can only be accessed by applications which have been certified by an appropriate signing authority.
BUT applications don't need to be Symbian Signed !
If an application isn't signed, it means that the user will have to hit a button to "Yes, Connect" or "Yes, Send" a text and so on.
WHEN WILL YOU SEE IT?
Πρώτη επίσημη παρουσίαση στο:
The Smartphone Show
11-12 October 2005
Excel Centre, London
Πηγή:http://hermione.cogia.net
Φιλικά
Γιάννης
Την "spy picture" την έβγαλε στο site της η Orange οπότε μάλλον αληθινή είναι.
Αναμονή μέχρι την επίσημη παρουσίαση.
Να δούμε πότε θα έρθει στην Ελλάδα για να το χτυπήσω, μιας και είμαι πιστός fun της σειράς: P800, P900 και τώρα P910i.
Φιλικά
Γιάννης
Και έγώ έχω δει μια φωτογραφία αλλά δεν ξέρω αν είναι αληθινή. Πάντως το Ρ900 δεν το αλλάζω προς το παρόν. Μετά το Ρ800 που είχα, το θεωρώ κορυφαίο.
Για να δούμε και το καινούργιο.!!
Η μόνη σοβαρή προσθήκη φαίνεται να είναι η υποστήριξη 3G (γιατί δεν βάζουν και Wi-Fi ήθελα να ήξερα). Το νέο UIQ 3.0 δε ξέρω τι παίζει, αλλά αν δεν υποστηρίζει τις παλαιότερες εφαρμογές (UIQ 2.1) θα έλεγα ότι πάλι να μας τα πάρουν θέλουν...
intergrale
