Ποιά LCD τηλεόραση 1920X1080 προτιμάτε για power-buy? Βenq 3750 ή Amoi Lc37af1e;
NLS
ε οκ, όποιοι είναι, αρκεί να ξέρουν από αυτά και να είναι και να υπάρχει και after-sales service
NLS
λίγα νέα ακόμα, σας μεταφέρω το transcript (με κάποια κοψίματα ραψίματα) για να βγάλετε μόνοι σας κάποια συμπεράσματα...
(βάζω κάποια σημαντικά σε αστεράκια)
Ο χρήστης NLS λέει:
let me explain things
there are two problems...
1) one problem has to do with 4:3 resizing - they are waiting for a new firmware for that
2) the other problem is the ability to show ALL 1920x1080 pixels through DVI/HDMI WITHOUT loosing any image outside the TV edges - in other words "map" all computer pixels on the LCD panel pixels 1:1
clear up to here?
now, about #2... this user, has created a monitor "profile" that can display all 1920x0180 1:1 but only through VGA connection and at very low Hz
so he needs help (and can help if you tell him what to try) to make it work with DVI/HDMI again 1:1 and at more Hz
that is all
[έχει καταλάβει αλλά προσπαθεί να μου πει ότι θέλει να ορίσει ποιός πρέπει να το αναλάβει... η SPB λογικά]
Ο χρήστης NLS λέει:
you probably mean...
"determine who has the responsibility to handle this"?
Από Amoi Κίνας λένε:
yes, You know my meaning exactly
Ο χρήστης NLS λέει:
my opinion is that Amoi should handle this instead of SPB...
because it is a problem that will help your TV
not just a small bug
your technicians need to see this directly
anyway, your call
*We've already solved it. SPB got the updated software and solution*
Ο χρήστης NLS λέει:
ah nice
for both problems?
yes
Ο χρήστης NLS λέει:
you told me that the user will not need to send TV back to SPB for the new software... is this true? how will the new software be installed?
hehe,I meant SPB could send service man to the customer's location
Maybe it is not effective. Anyway I will contact SPB first
Ο χρήστης NLS λέει:
anyway, there are no Greek customers yet so I don't care much - I care more if the problem is solved already
yes, It will be better and better
Ο χρήστης NLS λέει:
good
Frankly I am proud of this model
Ο χρήστης NLS λέει:
good
both good or double good
Ο χρήστης NLS λέει:
hehehe
ok I have a direct question for your techicians, because I am confused with all these
about this 1:1
the answer is simple, IF they know it
can you ask them?
hehe, OK.
Ο χρήστης NLS λέει:
ok here is the question:
*WHAT is the maximum frequency (Hz) that this TV can use for 1920x1080 PROGRESSIVE through DVI/HDMI?*
[αναμονή 1-2 λεπτά...]
50/60Hz
I called them just now
Ο χρήστης NLS λέει:
really!? - if this is true, then it is great
yes
...αν λοιπόν ότι λένε αληθεύει και μάλιστα αν δούμε εδώ και καταλάβουμε ότι και 50/60 ΠΟΛΛΑ είναι... τότε μιλάμε για πολύ καλά νέα
πάντως δεν παίρνω κανέναν στο λαιμό μου - απλά μεταφέρω
φυσικά όποιος έχει ΠΟΛΛΑ λεφτά κοιτάει και εδώ:
http://www.frontniche.com/products/tft/46inch_tft.htm
:oops:
Να τα βλεπαμε κιολας.. Γιατι αλλο να το ακους και αλλο να το βλεπεις η να το πιανεις 8)
Τελικα ειναι η εταιρεια του Νασου αυτη που θα τη φερει η οι αλλοι; γιατι τα κινεζα μας μπερδεψαν λιγο
Και ενα Update τιμων..
http://www.idealo.de/preisvergleich/OffersOfProduct/326660_-dv3750-benq.html
http://www.idealo.de/preisvergleich/OffersOfProduct/337834_-at3705w-mg-acer-computer.html
http://www.idealo.de/preisvergleich/OffersOfProduct/340529_-lc37af1e-amoi-electronics.html
NLS, αν έχεις και πάλι "επαφή" με Κίνα, μήπως θα μπορούσες να ρωτήσεις αν υπάρχει δυνατότητα ρύθμισης του Backlight μέσω των μενού;
Πιστεύω ότι μετά από το ΒΑΣΙΚΟΤΑΤΟ θέμα του 1:1 50/60 Hz pixel mapping μέσω DVI/HDMI, η δυνατότητα ρύθμισης του backlight είναι αυτο που θα μπορούσε να κάνει αρκετή διαφορά στην εικόνα, κυρίως σε πολλαπλές συνθήκες χρήσης.
Εάν υπάρχει και αυτή η δυνατότητα... τότε μέχρι να γίνουνε τα LED backlights mainstream ή να πάμε σε μη LCD τεχνολογίες... θα είμαστε μιά χαρά με την Αmoi :D
NLS
οκ όταν μάθω θα σου πω
...πάντως στο manual βλέπω brightness, contrast αλλά και color temperature (μεταξύ άλλων) - πιθανό κάτι από αυτά να επιρρεάζει το backlight
...μπορούμε πάντα να ελπίζουμε και στο service menu :wink: ...αρκεί ο Κινέζος να μας δώσει κάνα θετικό hint! :roll:
NLS
από ότι μου είπε ναι ρυθμίζεται
απλά μου είπε (χεχεχε ξέρετε τώρα) "όχι από τον user" (προφανώς ακριβώς εννοεί το service menu)
...αν ισχύσουν ολα όπως τα λέει ο κινέζος, θα είναι συνοπτικότατη η διαδικασία επιλογής... :D
Απλά όταν έρθει το demo να είμαστε βέβαιοι οτι έχει το τελευταίο firmware, ή αλλιώς να έχουμε μάθει από πρίν πώς την "φλασάρουμε" μόνοι μας :wink:
NLS
το τελευταίο θα έχει - μια και το έχει ήδη και μια και αυτές που θα έρθουν δεν έχουν φύγει ακόμα από Κίνα (εντωμεταξύ έρχεται και η Κινέζικη πρωτοχρονιά...)
το φλασάρισμα από εμάς αν κατάλαβα ΔΕΝ θα το αφήσουν να γίνει (δηλ. από αυτούς χλωμό να διαρρεύσει firmware ή το σχέδιο του service port)
τέσπα κοντός (ή όχι τόσο κοντός) ψαλμός αληλούια
ΓΕΝΙΚΕΕΕΕΕΕ............ ΣΟΥ ΑΝΟΙΞΕ Η ΟΡΕΞΗ ΜΕΤΑ ΤΟ ΔΩΡΟ ΠΟΥ ΚΕΡΔΙΣΕΣ ΣΤΟ ΝΟDUS???????
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :lol: :lol: :lol: :lol: :lol:
Manosahead
