Media Player Classic Home Cinema
gkontoletas
trouble in my brain
Από την δημοσκόπηση παρατηρώ ότι είναι το ποιο δημοφιλές πρόγραμμα αναπαραγωγής, έτσι αποφάσισα να ανοίξω ένα νέο νήμα παίρνοντας αφορμή και από την νέα έκδοση.
MPC-HC v1.4.2499
http://mpc-hc.sourceforge.net/
Changelog v1.4.2499.0 7/9/2010 (Είναι αρκετά μεγάλο οπότε το έβαλα στο spoiler)
v1.4.2499.0 - 7 September 2010
NEW : Seamless playback support for multi files BRD
NEW : Support for Windows 7 taskbar and thumbnails features
NEW : Added Catalan, Dutch and Japanese translations
NEW : VSFilter x64 is available
NEW : Added internal VP8 Decoder
NEW : MPC-HC can be compiled with MSVC2010 and Intel C++ Compiler
NEW : Support for MCE remote control (values added in AppCommand column in
"Options/Player/Keys")
NEW : Support of Broadcom Video decoder for VC1, H.264 and MPEG-2
(hardware acceleration)
NEW : Support for DVB subtitles
NEW : Open files to Recent Documents
NEW : AUTO HDMI MODE 1080p/24 support for fullscreen mode
NEW : Ticket #46, add number to AudioDevice list
NEW : Sync Renderer dialogs
NEW : Real Video decoder in MPCVideoDecoder
NEW : Support interlaced mode in fullscreen resolution list
NEW : Auto change fullscreen resolution for different video content
NEW : Fullscreen Options page
NEW : Video decoder, options for DXVA Compatibility check
NEW : Support for MPEG-2 bitstreaming in the DXVA decoder
NEW : Full screen resolution - support for native 23.976 and 29.97 mode
(Vista and above only)
NEW : Auto resolution change for DVD
NEW : Always Exit after playback option
NEW : Support for SRM7500 remote control
NEW : New panel for switching DVB channels, audio and tuner scan
accessible through View-->Navigation menu when in Capture mode
NEW : Automatically play next files in a folder
NEW : Implemented 'Quick add favorite' shortcut (default: Shift + Q)
will use current settings from 'Add Favorite' dialog
NEW : Select D3D device for render, including DXVA if two or more video
adapters are in the system (EVR Custom & VMR9-Renderless only)
NEW : Statistics - added render device
NEW : Ability to select OSD font & size
NEW : Option "Don't use 'search in folder' on commands 'Skip back/forward'
when only one item in playlist"
NEW : H.264 L5.1 DXVA support for ATI cards with drivers > v8.14.1.6105
(Catalyst 10.4)
NEW : MPCVideoDecoder, disable DXVA (H.264) for SD video (width < 1280)
NEW : Improved DXVA compatibility check
NEW : Implemented drag and drop folders with sub-folders
NEW : Support for MPEG-1/Layer1 audio stream in the Matroska splitter
NEW : Command to switch video frame mode (key 'P')
NEW : Video frame options like in TV: Zoom 1 and Zoom 2
NEW : Auto saving position every 30 seconds
NEW : Added internal filters context menu (disable/enable)
NEW : Command to reopen file (Ctrl+E)
NEW : Support for PGS in Matroska
NEW : Open root BD movie from command line & shell context menu
NEW : OSD messages added when switching audio stream or subtitles
NEW : OSD on Jump Forward/Backward (keyframe)
NEW : OSD when open DVD/BD
NEW : OSD for jump to chapter in file
NEW : Detect system UI language and set interface language at first run
NEW : Full ICC color management (Little CMS v2.1a library added)
NEW : Full floating point processing (FP16 temporary textures)
NEW : High-quality dithering (color management, full floating point
processing, 10-bit -> 8-bit)
NEW : Option to force 10-bit EVR mixer input (probably hackish,
but in many cases it seems to work)
NEW : Added MediaInfoLib (v0.7.35) (no need for MediaInfo.dll anymore)
NEW : Added support for MPEG-2_VLD DXVA for Intel G31/33
(and maybe other Intel) chipset
CHANGED: Updated UnrarDll. It is now possible to use the 64bit UnrarDll
with the 64bit MPC-HC
CHANGED: Updated Detours to v2.1 build 216
CHANGED: Updated Bento4 to v1.2.3.0
CHANGED: Updated libpng to v1.4.3
CHANGED: Updated SoundTouch to v1.5.0
CHANGED: Updated zlib to v1.2.5
CHANGED: Updated LibOgg to v1.2.0
CHANGED: Updated LibVorbis to v1.3.1
CHANGED: Updated PNGDIB to v3.1.0
CHANGED: Updated sizecbar to v2.45
CHANGED: Better support for madVR
CHANGED: Updated Hungarian, Russian, Polish, Slovak, Portuguese, Ukrainian,
Spanish, Swedish, Czech, Traditional Chinese, German, Italian, Turkish
and Hungarian translations
CHANGED: Updated FFmpeg
CHANGED: Updated installer script
CHANGED: "DirectShow Audio" label on playback->output now says "Audio Renderer"
CHANGED: Ticket #27: Allow screensaver to activate when audio only
(sleep is still stopped)
CHANGED: Add open file to Recent Document only if "Keep history of recently
opened files" is checked
CHANGED: Select and change resolution for selected fullscreen monitor
CHANGED: Improve options for fullscreen monitor and resolution
CHANGED: Open DVD root folder (include VIDEO_TS) from explorer context menu
CHANGED: Many internal code improvements for more stability
CHANGED: Improved playlist
CHANGED: Improved subtitle handling
CHANGED: Rewritten DVXA check for better readability
CHANGED: Disabled internal H.264 (AVC) decoder for interlaced files
(bad supported by FFmpeg)
CHANGED: Show filename in OSD at open, instead "Pause/Play"
CHANGED: Add 'x64' suffix in Title and in the About dialog for the x64 build
CHANGED: OSD file name at open show delay up to 3 sec.
CHANGED: Core rendering code in the DX9AllocatorPresenter class is moved
to a new class: DX9RenderingEngine
CHANGED: "10 bit RGB" option changed to "10-bit RGB Output", does not affect
internal processing anymore
CHANGED: Removed unnecessary temporary texture allocations
CHANGED: Removed old player logos and added a new one
FIXED : Name of MPC-HC in title bar (Bug #2826963)
FIXED : Web interface status.html not showing status/media state when
Status bar is turned off (Bug #2025675)
FIXED : Ticket #12, crash/hang after standby, hibernate, UAC or CTRL+ALT+DEL
FIXED : Ticket #74, [MP4] AAC sound stops playing
FIXED : Ticket #116, issue with some MPEG (mono) audio playback
FIXED : Ticket #120, Inner PCM inside QT .mov is supported now
FIXED : Ticket #150, issue with playback AMR sound
FIXED : Ticket #161 and #414, "no audio capture device"
FIXED : Ticket #163, Crash with RealMedia
FIXED : Ticket #237, DVB channels are all saved as number 0 when tuning
FIXED : Ticket #242, No PCM sowt audio in MOV
FIXED : Ticket #258, speaker configuration in Audio Switcher isn't stored
FIXED : Ticket #281, [CAPTURE] No video decoding when capturing from DVB-T
card with internal MPEG2 DVXA Decoder enabled
FIXED : Ticket #282, Auto-zoom function problem
FIXED : Ticket #295, SSA/ASS and other save subtitle formats problem
FIXED : Ticket #300, Regression when hiding Caption and Menubar
FIXED : Ticket #333, Missing tracks when playing a TS file
FIXED : Ticket #363, #563, Can't open some mp3
FIXED : Ticket #385, no chapters with MP4Splitter
FIXED : Ticket #455, Bug with PGS subtitles
FIXED : Ticket #456, Problem with auto-loading subtitles fixed
FIXED : Ticket #465, MPEG/TS splitter can't recognize some video track
FIXED : Ticket #477, Internal audio switcher
FIXED : Ticket #489, MPC-HC API improvements
FIXED : Ticket #502, Problem with D3D9Ex
FIXED : Ticket #513, .rmvb interlaced decoding
FIXED : Ticket #511, Subtitle renderer crash fixed
FIXED : Ticket #528, Unable to scan for dvb-t
FIXED : Ticket #536, [MKV] Default values of the specification should be
strictly followed
FIXED : Ticket #576, Next AR Preset Issue
FIXED : Ticket #578, VSFilter crash fix with certain malformed drawing lines
FIXED : Ticket #599, ignores /audiorender option
FIXED : Ticket #601, BD movie length detect wrong
FIXED : Ticket #660, Pressing left arrow under Options->Logo causes right
arrow to disappear
FIXED : Ticket #661, Ctrl+C / File->Close form size discrepancy
FIXED : Ticket #672, DVB-T - image problems after changing from tv channel
to radio & back
FIXED : Ticket #677, Wrong colors using Color Management
FIXED : Ticket #679, add color management status in EVR CP graph settings
FIXED : Ticket #680, "Don't hide controls in full screen" does not work
unless you move the mouse
FIXED : Ticket #694, DLL preloading vulnerability
FIXED : Ticket #696, [GUI] use options dialog causes main window elements
to disappear
FIXED : Ticket #714, MPEG2 detected as H264
FIXED : Opening multiple files via Explorer context menu
FIXED : Memory leak in libavcodec
FIXED : Memory leak in DXVA decoder
FIXED : Playback of some broken avi files
FIXED : Fix VCD playback
FIXED : Better detection of "Used For Reference Flags" (fixes some broken
DXVA samples)
FIXED : Screensaver activating during video playback on XP
FIXED : Audio language detection for HDMV (broken by seamless playback feature)
FIXED : Bug with prevent sleep mode
FIXED : Bug in "Open File" dialog & "Add to Playlist" checked
FIXED : Default (center) window position after file close
FIXED : Issue with a switch to fullscreen mode
FIXED : FavoriteAdd dialog
FIXED : Possible buffer overflows
FIXED : Bug with launch in fullscreen
FIXED : Incorrect decoding with MPEG-2 bitstream decoder on video with
alternative scan
FIXED : Seeking problem with MPEG files
FIXED : Don't show OSD message when auto play is disabled
FIXED : Checking for duplicates in display modes
FIXED : Correct state when done playback (rewind fix)
FIXED : Incorrect minimal window height calculation when caption is on
FIXED : Search in dir function
FIXED : Play video from network share
FIXED : Incorrect position (desktop) after fullscreen when playing multiple
files on multi-monitor systems
FIXED : Playback issue for some H.264 media files captured from digital cameras
FIXED : Various DVB-T fixes
FIXED : DXVA regression: black video with some files
FIXED : Crash in Matroska splitter with unknown streams
FIXED : OSD shown wrong (previous) audio stream on change
FIXED : Improved DVD resume
FIXED : Crash with some VOB subtitles
FIXED : Undetected H.264 video streams in MPEG splitter
FIXED : Incorrect identification of the video stream in MPEG splitter
(H.264 instead of MPEG-2)
FIXED : Logical/numeric sorting in Playlist, "Play next in the folder"
FIXED : OSD on open BD
FIXED : MPEGSplitter - could not read some MPEG files
FIXED : Crashes with MSVC2010 builds
FIXED : The EVR mixer output media subtype matches the surface format
(as a consequence, it's always RGB)
FIXED : Incorrect lenght detection of MPEG, DVD (.ifo)
Απάντηση: Media Player Classic Home Cinema
Ουάου!
Ένα χρόνο είχε να κάνει, για να δούμε!
Απάντηση: Re: Media Player Classic Home Cinema
Ενα χρονο?! Εδω: http://www.xvidvideo.ru/ και εδω:http://xhmikosr.1f0.de/index.php?folder=bXBjLWhjX21zdmMyMDEw καθε μερα και καινουργια εκδοση :105:
Άλλο πράγμα είναι τα svn builds (beta δηλαδή) και άλλο η σταθερή έκδοση από το επίσημο site.... Επίσημο release είχαμε πράγματι να δούμε πάρα πολύ καιρό....
"Support of Broadcom Video decoder" τι σημαίνει αυτό ; Λέτε να το δούμε σε κάνα DREAMBOX ή DUNE HD;
gkontoletas
trouble in my brain
Εξαρτάται από την κάρτα γραφικών που έχεις, ο CoreAVC υποστηρίζει hardware acceleration μόνο σε κάρτες γραφικών της nVidia που υποστηρίζουν Cuda.
Επίσης η εγκατάσταση του DirectVobSub δεν είναι απαραίτητη, μάλιστα δημιουργεί και θέμα με το hardware acceleration.
Απαραίτητη είναι η εγκατάσταση του τελευταίου DirectX(directx_Jun2010_redist)
gkontoletas
trouble in my brain
Αυτό το έχετε δοκιμάσει;
Η τελευταία επίσημη έκδοση του Media Player Classic Home Cinema, μπορεί να αναπαράγει τα αρχεία m2ts που περιέχει ένα Blu-Ray δίνοντας την δυνατότητα να επιλέξετε τον ήχο και τους υπότιτλους που θέλετε.
gkontoletas
trouble in my brain
MPC HC v. 1.5.0.2827
NEW : Added new options to always default to external subtitles, ignore embedded subtitles and to set the autoload subtitle paths
NEW : Added support for "in24", "fl64", 8-bit "sowt", "IMA4" and "NONE" audio (old QuickTime PCM)
NEW : Added support for "in24", "in32", "fl32", "fl64"(both big-endian and little-endian) in .mov files
NEW : Ticket #784, Enable ctrl+A in the MediaInfo window
NEW : [DVB] LCN support, added EPG current event information, offset parameter for scanning channels, added channel encryption detection for DVB-t during scan
NEW : Added ignore encrypted channels checkbox during DVB scan
NEW : Armenian translation
CHANGED: Updated MediaInfoLib to v0.7.39
CHANGED: Updated ZenLib to v0.4.17
CHANGED: Updated Little CMS to v2.1
CHANGED: Updated libpng to v1.4.5
CHANGED: Updated libogg to v1.2.2
CHANGED: Updated libvorbis to v1.3.2
CHANGED: Cleaned up and optimized code for QT PCM, small corrections in MP4Splitter
CHANGED: DVB: the current channel audio stream is memorized and selected by default each time the channel is switched back
CHANGED: Removed DSM Converter (use the legay branch if you need this feature)
CHANGED: Removed RoQ splitter/decoder (same as above)
Μάκης Ευμορφόπουλος
Αντιπρόεδρος ΕΒΒΕ
έχει κάποιος άλλος πρόβλημα με την τελευταία έκδοση του mpc, 1.5.1.2903? με το που κάνω launch ο υπολογιστής κάνει restart. Τι μπορεί να φταει?
Μάκης Ευμορφόπουλος
Αντιπρόεδρος ΕΒΒΕ
την δοκίμασα και αυτήν με τα ίδια αποτελέσματα. Η μόνη που μου παίζει σωστά είναι η 1.4.2499.
gkontoletas
trouble in my brain
Γράψε το error από τον event viewer για να βοηθήσουμε.
Τι λειτουργικό και κάρτα γραφικών χρησιμοποιείς;
gkontoletas
trouble in my brain
Δεξί κλικ στο my computer(ο υπολογιστής μου)-- manage(διαχείριση)--event viewer(προβολή συμβάντων)
Δες τα λάθη που υπάρχουν στα application(εφαρμογή) και system(σύστημα)
gkontoletas
trouble in my brain
Σώσε τα application και system με δεξί κλικ σε δυo αρχεία και στείλε τα στο e-mail που σου έχω στείλει με pm.
Τι CPU έχεις; Αυτό συνέβαινε σε υπολογιστές με CPUs που δεν υποστηρίζουν SSE2. Πριν κάποια revisions, το άλλαξα σε SSE. Οπότε δοκίμασε την τελευταία SVN build από το site μου.
intergrale
