Media Player Classic Home Cinema
1.7.4 http://mpc-hc.org/
1.7.4 - 16 April 2014
  • New:
    • New Bengali and Tatar translations
    • Support for opening “icyx://” stream URLs
    • Ticket #2348/#3583, Automatically refresh the information bar and title bar so that the correct information is always shown for streaming (e.g. online radios)
    • Ticket #4043, Statistic: Show playback rate for audio files
  • Changed:
    • If MPC-HC is configured to override the splitter choice when doing the initial track selection, tracks selected at splitter level will be preferred in case more than one tracks match the criteria
    • The “Jump to” menu has been split in several smaller submenus displayed in the “Navigate” menu depending on the media currently playing
    • The internal LAV Splitter will now be used by default to demux AviSynth scripts instead of using the old VFW interface. Note that AviSynth is still required even if LAV Splitter is used
    • Cleaned up WebUI’s Javascript code
  • Updated:
    • SoundTouch to v1.8.0
    • Little CMS to v2.6 (git 40300b1)
    • Unrar to v5.1.2
    • MediaInfoLib to v0.7.68
    • ZenLib to v0.4.29 r446
    • LAV Filters to stable version 0.61.2:
      • LAV Audio: Improve error recovery on slightly corrupted audio streams
      • LAV Video: Fix a rare crash that could occur for high resolutions
      • LAV Video: Fix artifacts on some H264 streams with both software and DXVA decoding
      • LAV Splitter: Support ShoutCast metadata
      • LAV Video: Various improvements for DXVA support (native and copy-back)
      • LAV Splitter: Fix the opening of some Blu-ray discs which would take several minutes and could hang the player
      • Ticket #4035, LAV Video: Some frames were dropped when playing RealVideo files
      • Ticket #4057, LAV Splitter: Some WAV files were incorrectly detected as DTS
    • Armenian, Basque, British English, Catalan, Simplified and Traditional Chinese, Croatian, Czech, French, Galician, German, Greek, Hebrew, Hungarian, Italian, Japanese, Korean, Malay, Polish, Portuguese (Brazil), Romanian, Russian, Slovenian, Slovak, Spanish, Swedish, Turkish, Ukrainian and Vietnamese translations
  • Fixed:
    • Properties dialog: Some tracks could have been missing from the streams list
    • Fix incorrectly displayed OSD in case the message contained the character ‘&’. Also make top-left and top-right OSD size consistent and improve the behavior when the text is too big to be displayed entirely
    • VMR-7 renderless: subtitles were not displayed except in fullscreen
    • Ensure dynamic menus dependent on the currently playing media are updated when the media changes while a menu is opened
    • DVB subtitles: Subtitles were sometimes only partially rendered with some parts disappearing immediately
    • DVB and PGS subtitles: Subtitles were sometimes one frame late. This was invisible most of the time, but it could produce blinking in some cases
    • ISR: Crop PGS and DVB subtitles if they don’t fit into the video frame
    • ISR/VSFilter: Use correct colorimetry information for PGS and DVB subtitles
    • ISR: Subtitles could be partially rendered when using no subtitle queue
    • ISR: Text subtitles were incorrectly displayed after switching from PGS/DVB subtitles
    • PGS subtitles: Subtitles being displayed just after seeking could be wrong
    • Ticket #1814, Vobsub: Support animated subtitles (with fade in/out)
    • Ticket #2588, Subtitle renderer: The subtitles’ shadow was not drawn when their border was very thin
    • Ticket #2773, Subtitle renderer: Fix possible artifacts when using karaoke effects
    • Ticket #2994, Fix toolbar separators not being properly painted
    • Ticket #3296, Fix WebUI controls.html error due to unescaped file path
    • Ticket #3437, Audio Switcher: Support fallback to another media type. For example, this allows audio decoders to fallback to normal decoding if bitstreaming isn’t supported
    • Ticket #3544, Prevent the low-merit fall-back on internal LAV Splitter to demux raw subtitle formats
    • Ticket #3691, PGS subtitle timings were sometimes wrong (subtitles started or ended too late)
    • Ticket #3763, VMR-9 renderless and EVR-CP: The displayed subtitle was not updated when seeking while playback was paused
    • Ticket #3775, “Play -> Subtitles” menu could be mistakenly disabled when the internal subtitle renderer was unavailable
    • Ticket #3980/#4037, Exiting fullscreen sometimes produced visual artifacts
    • Ticket #3987, Entering fullscreen when MPC-HC window occupied the whole monitor produced visual artifacts
    • Ticket #3999, Work around a crash in the math library for x64 builds
    • Ticket #4004, Fullscreen/windowed transition was not as smooth as in 1.7.1 and prior
    • Ticket #4011, Fix image saving for streams with characters not supported in path names
    • Ticket #4013, Subtitle renderer: Fix a crash on malformed animated transforms (\t tags with no parameters)
    • Ticket #4020, Update dialog: Fix incorrect version info when using Belarusian, Slovenian or Russian translations
    • Ticket #4050, MPC-HC could crash when loading invalid DVB channel settings
    • Ticket #4070, Restore compatibility with KatMouse
    • Ticket #4079, The “Save image/thumbnails” path was cut off in the status bar
    • Ticket #4082, Fullscreen window was misplaced sometimes after monitor mode autochange
    • Ticket #4116, “Snap to desktop edges” option wasn’t working correctly
    • Ticket #4128, Moving mouse over tooltips in fullscreen hid the toolbar under some circumstances
    • Ticket #4141, Subtitles were incorrectly displayed in DVD and DVB mode when using the internal subtitle renderer and madVR
    • Ticket #4141, DVD subtitles were always re-enabled when clicking on a menu entry related to external subtitles
    • Ticket #4163, Shaders option page: the buttons’ icons were missing on Windows XP
    • Ticket #4173, ASS/SSA subtitles: Fix a possible infinite loop during parsing
1.7.5. http://mpc-hc.org/
  • Fixed:
  • Ticket #3691, PGS subtitles: Some lines stayed visible for too long when using the queue
  • Ticket #4231, Don’t prevent the users from using the ISR if they choose not to block VSFilter like filters
  • Ticket #4240, Crashes could randomly occur when playing files with PGS subtitles (mostly when seeking quickly)
  • Updated:
    • Catalan, Croatian, Dutch, German, Japanese, Slovenian, Spanish, Ukrainian and Vietnamese translations
gkontoletas
trouble in my brain
1.7.6 (5-7-2014)
  • New:
    • ISR: Add an option to control subtitle renderer behavior regarding anamorphic video
    • ISR: Add an option to render subtitles at the source video resolution like VSFilter.
    • VSFilter: Display more informative names for external subtitles (similar to what is done with the internal subtitle renderer)
    • Add a “Copy to clipboard” feature to the “Play > Filters” menu so that the list of currently loaded filters can be copied easily
    • Add an option in the “Save Subtitle” dialog to control the export of the default style as an external “.style” file
    • Ticket #1411, Internal Subtitle Renderer/VSFilter: Support loading external PGS subtitles
  • Changed:
    • Don’t use auto-zoom feature when the window was positioned using the Aero Snap
    • Don’t exit fullscreen when loosing focus to a window on the same monitor
    • Text subtitles: When rendering to the video frame, clip subtitles that go out of the frame
    • Text subtitles: Faster subtitle parsing (around 20%)
    • Ticket #4144, Move the user interface language selection to the Options dialog and remove the “Language” menu. The increasing number of translations had reduced the usability of the menu
    • Ticket #3739, Make error reporting less verbose when some non-critical DVD hooks fail
  • Updated:
    • Little CMS to v2.6 (git 4da8703)
    • Unrar to v5.1.6
    • MediaInfoLib to v0.7.69
    • ZenLib to v0.4.29 r458
    • LAV Filters to stable version 0.62.0:
      • LAV Video: Support VP7 video
      • LAV Video: Use the MediaFoundation WMV decoder on Windows 7+ instead of the DMO WMV decoder
      • Ticket #3575, LAV Splitter: Alternate audio support for HLS
      • Ticket #4032, LAV Video: Fix some issues with DVD subtitles (flashing, overlapping and generally all kind of timing issues)
      • Ticket #4326, LAV Splitter: No subtitles were displayed when using the special “Forced subtitles” track created for PGS subtitles
      • Ticket #4357, LAV Video: Fix some performance regressions introduced in v0.61 (mostly visible on old operating systems like Windows XP)
    • Armenian, Basque, Belarusian, Bengali, British English, Catalan, Chinese (simplified and traditional), Croatian, Czech, Dutch, French, Galician, German, Greek, Hebrew, Hungarian, Italian, Japanese, Korean, Malay, Polish, Portuguese (Brazil), Romanian, Russian, Slovak, Slovenian, Spanish, Swedish, Tatar, Turkish, Ukrainian and Vietnamese translations
  • Fixed:
    • The dockable bars were not updated when changing the UI language
    • Statusbar: Fixed occasional flickering of text and media type icon
    • D3D Fullscreen last state was inverted and wasn’t properly restored with “Remember last window size and position” option
    • D3D Fullscreen produced invisible window for audio-only files
    • Ticket #34, VSFilter/ISR: Override placement feature was not working even if enabled
    • Ticket #1574/#4171, ISR: Subtitle positioning was wrong when using default style override
    • Ticket #2244, ISR: Changes in subresync bar were lost after changing style
    • Ticket #2671, VSFilter: Video frames were not marked as interlaced
    • Ticket #3036, Fix drag-and-drop from some applications. Drag-and-dropping a downloaded file from Chrome failed for example
    • Ticket #3701, Subtitle outline was too thick when using default style override
    • Ticket #4213, Fix a deadlock when starting MPC-HC in D3D fullscreen and auto-changing the monitor mode
    • Ticket #4213, Fix auto-changing the monitor mode when starting in D3D fullscreen with “play 0 time” option or the auto-change delay greater than 0s
    • Ticket #4213, D3D fullscreen: Obey “Apply default monitor mode on fullscreen exit” option
    • Ticket #4214, Fix monitor mode flickering when auto-changing the monitor mode
    • Ticket #4284, Auto-zoom feature didn’t work properly when the taskbar was docked at the left or the top of the screen
    • Ticket #4285, Fix a freeze when opening some files when EVR-CP or Sync renderer are selected
    • Ticket #4285, EVR-CP and Sync renderers: Properly set the aspect ratio
    • Ticket #4288, Changing the zoom level when in fullscreen mode did nothing
    • Ticket #4298, The auto-change fullscreen mode monitor settings could be randomly corrupted or missing
    • Ticket #4299, Frame stepping was not working for DVD
    • Ticket #4307, ANSI subtitles files with Unix line endings could crash MPC-HC
    • Ticket #4408, Remember window position: Ensure the window can’t be completely hidden after restoring it
gkontoletas
trouble in my brain
v. 1.7.7 (5-10-2014)
Διόρθωσαν το πρόβλημα με τον ήχο του TrueHD που περιέχει Atmos
1.7.7 - 05 October 2014
  • New:
    • Accept loading more than one subtitle file at a time using the “Load subtitle” dialog or drag-and-drop
    • Add advanced settings page
    • Add Arabic and Thai translations
    • Completely reworked subtitle queue:
      • The queue should be quite faster than the older one for a similar number of buffered subpictures. It should also work much better when the number of subpictures becomes important
      • Subtitle animation can now be disabled even when using no buffering
      • Add the ability to choose at which state (in percentage of the full animation) an animated subtitle will be rendered when the animation is turned off
      • Add the ability to control the rate of the animation (in percentage of the movie frame rate)
      • Add the ability to control whether the subtitle queue is allowed to drop some subpictures in case subtitle rendering is too slow
    • Add option to set jpg quality when saving images (default quality is increased from 75% to 90%)
    • Ticket #353, Allow to control minimum file duration for remember position feature
    • Ticket #1287, Add after playback command to turn off the monitor.
    • Ticket #1407/#2425, Add an advanced option to control the number of recent files. Those files are shown
    • in the “Recent Files” menu. It is also the files for which a position is potentially saved
    • Ticket #1531, Show cover-art while playing audio files
    • Ticket #2194, Show drive label when playing DVD
    • Ticket #3393, Allow to disable remember position feature for audio files
    • Ticket #4345, Text subtitles: Add a mode that automatically chooses the rendering target based on the
    • subtitle type, ASS/SSA subtitles will be rendered on the video frame while other text subtitles will
    • be rendered on the full window
    • Ticket #4690, Internal filters: Support v210/v410 raw video formats
  • Changed:
    • Text subtitles: Faster subtitle parsing (up to 4 times faster for ASS/SSA subtitles)
    • Text subtitles: Improved subtitle renderer for faster rendering of complex subtitle scripts (often twice faster or more)
    • Text subtitles: Much faster subtitle opening in the Subresync bar
    • Ticket #325, Move after playback commands to options and add an option to close and restore logo.
    • Ticket #1663, Improved command line help dialog
    • Ticket #2834, Increase limit on subtitles override placement feature.
    • Ticket #4428, Improve the clarity of the error message when opening a subtitle file fails
    • Ticket #4687, Reworked “Formats” option page. It is now possible to clear all associations
    • Ticket #4865, Subtitles option page: Clarify the “Delay interval” setting
  • Updated:
    • Updated Little CMS to v2.6 (git 9c075b3)
    • Updated Unrar to v5.1.7
    • Updated MediaInfoLib to v0.7.70
    • Updated ZenLib to v0.4.29 r481
    • Updated LAV Filters to stable version 0.63.0:
      • LAV Video: HEVC decoding is up to 100% faster
      • LAV Video: Fix potential artifacts when decoding x264 lossless streams
      • LAV Splitter: Support for playing AES encrypted HLS streams
      • LAV Splitter: Advanced Subtitle selection allows selecting subtitles by a string match on the stream title
      • Ticket #3608, LAV Splitter: Fix stuttering with some (m2)ts files
      • Ticket #4322, LAV Audio: Improve the estimated duration for some MP3 files
      • Ticket #4539, LAV Video: Fix a crash with DVD subtitles on 64-bit builds when using software decoding
      • Ticket #4639, LAV Splitter: Fix incorrect colors for VobSub tracks in MP4
      • Ticket #4783, LAV Video: Experimental support for hardware (CUVID and DXVA2) assisted decoding of HEVC streams (disabled by default)
      • Ticket #4879, LAV Audio and LAV Splitter: Fix TrueHD streams with a Dolby Atmos sub-stream The full changelog can be found at https://raw.githubusercontent.com/Nevcairiel/LAVFilters/0.63/CHANGELOG.txt
    • Updated Armenian, Basque, Belarusian, Bengali, British English, Catalan, Chinese (Simplified and Traditional), Croatian, Czech, Dutch, French, Galician, German, Greek, Hebrew, Hungarian, Italian, Japanese, Korean, Malay, Polish, Portuguese (Brazil), Romanian, Russian, Slovak, Slovenian, Spanish, Swedish, Tatar, Turkish, Ukrainian and Vietnamese translations
  • Fixed:
    • Work around corrupted display with NVIDIA drivers v344.11 when using EVR, EVR-CP or Sync renderers
    • “Load subtitle” dialog: Fix the file filters on Windows Vista+
    • “Resources” tab: The resource saved wasn’t always matching the selection
    • Ticket #3930, Fix a possible crash with embedded subtitles when the subtitle queue is disabled
    • Ticket #4207, Taskbar preview wasn’t scaled correctly
    • Ticket #4504, ASS/SSA subtitles: Support floating point values in drawing commands
    • Ticket #4505, Embedded text subtitles: Fix a possible crash related to the Subresync bar
    • Ticket #4536, ASS/SSA subtitles: Fix the parsing of \fs tags when the value was negative
    • Ticket #4665, Ensure that the icon shown in the status bar and the property dialog matches the icon currently associated to the format
    • Ticket #4678/#4856, Use internal filters for GIF format
    • Ticket #4684, Clicking on the some parts of the volume slider had no effect
    • Ticket #4707, EVR-CP: Screenshots were corrupted when “Force 10-bit input” was used
    • Ticket #4730, MediaInfo: Ensure the MediaInfo tab gives the same information as the official GUI
    • Ticket #4744, Some subtitles could cause a crash or produce artifacts
    • Ticket #4752, Monitors connected to secondary graphic card were not detected
    • Ticket #4758, Adjust width of the groupbox headers to avoid empty space
    • Ticket #4778, Fix optical drive detection when its letter is A or B.
    • Ticket #4782, Backward frame step led to jumping to the wrong position in certain situations
    • Ticket #4825, Tracks matching a preferred language weren’t always selected correctly
    • Ticket #4827, Initial window size could be wrong for anamorphic video
    • Ticket #4831, Fix a rare issue with animated subtitles starting at timecode 0
    • Ticket #4857, The timings of some subtitles could be wrong when using Sync Renderer
    • Ticket #4863, MPC-HC could crash when opening a file through the QuickTime engine
1.7.8 http://mpc-hc.org/downloads/
1.7.8 - 25 January 2015
  • New:
    • DVB: Show current event time in the status bar
    • DVB: Add context menu to the navigation dialog
    • Add Finnish and Serbian translations
    • Ticket #907, Enable “Properties” dialog for DVD and DVB playback modes
    • Ticket #1091, Support MediaInfo analyse for DVD
    • Ticket #1494, Add tooltip in the “Organize Favorites” dialog with path of the item
    • Ticket #2438, Keep history of recently opened DVD directories
    • Ticket #3647, Internal LAV Video Decoder: Support Cinepack and QPEG in low-merit mode
    • Ticket #4941, Support embedded cover-art
  • Changed:
    • DVB: Improve channel switching speed
    • The “Properties” dialog should open faster being that the MediaInfo analysis is now done asynchronously
    • Make double-click tolerance consistent with system settings
    • Ticket #4978, Execute “once” after playback event when playlist ends, regardless of the loop count
    • Ticket #4991, Text subtitles: “opaque box” outlines will now always be drawn even if the border width is set to 0. The size of the text is independent of the border width so there is no reason not to draw that part
    • Ticket #5056, Position the text subtitles relative to the video frame by default
  • Updated:
    • MediaInfoLib to v0.7.71
    • ZenLib to v0.4.29 r498
    • SoundTouch to v1.8.0 r201
    • Little CMS to v2.7 (git 8174681)
    • Unrar to v5.2.3
    • LAV Filters to v0.63.0.52:
      • LAV Video Decoder: Fix a crash when the video height is not a multiple of 2
      • Ticket #3144, LAV Splitter: Support librtmp parameters for RTMP streams
      • Ticket #4407, LAV Video Decoder: Fix a rare crash when checking the compatibility with hardware decoding
      • Ticket #5030, LAV Video Decoder: The video timestamps could be wrong in some cases when using H264 DXVA decoding. This could lead to synchronization issue with the audio
      • Ticket #5047, LAV Splitter: Fix missing tracks in (m2)ts files
      • Ticket #5116, LAV Video Decoder: Fix aspect ratio for some MPEG2 streams
    • Arabic, Armenian, Basque, Belarusian, Bengali, British English, Catalan, Chinese (Simplified and Traditional), Croatian, Czech, Dutch, French, Galician, German, Greek, Hebrew, Hungarian, Italian, Japanese, Korean, Malay, Polish, Portuguese (Brazil), Romanian, Russian, Slovak, Slovenian, Spanish, Swedish, Tatar, Thai, Turkish, Ukrainian and Vietnamese translations
  • Fixed:
    • XySubFilter: Always preserve subtitle frame aspect ratio
    • Properties dialog: The creation time did not account for the local timezone
    • Properties dialog: More consistent UI for the “Resources” tab
    • PGSSub: Subtitles could have opaque background instead of transparent one
    • Audio CDROMs with extra content could not be played
    • Ticket #2420, Improve the reliability of the DirectShow hooks
    • Ticket #2626, Fix some rare crashes when another application prevents MPC-HC from rendering the video
    • Ticket #2953, DVB: Fix crash when closing window right after switching channel
    • Ticket #3324, Some applications could interfere with Skype API and prevent MPC-HC from running when “Display “Now Playing” information in Skype’s mood message” was enabled
    • Ticket #3666, DVB: Don’t clear the channel list on saving new scan result
    • Ticket #3742, Sync Renderer: Fix rare crashes when using Sync Renderer with “synchronize video to display” option enabled
    • Ticket #3864, Video renderers: Fix a possible crash caused by a race condition
    • Ticket #3991, Video renderers: Fix a possible crash when the D3D device cannot be created
    • Ticket #4029, Fix a rare crash when right-clicking on the playlist panel
    • Ticket #4436, DVB: Improve compatibility with certain tuners
    • Ticket #4551, Fix a possible crash when saving the current frame
    • Ticket #4721, Audio CD playback could hang and stutter with some drives
    • Ticket #4933, ASS/SSA subtitles: Fix a crash for elements with no horizontal border but a vertical one
    • Ticket #4937, Prevent showing black bars when window size after scale exceed current work area
    • Ticket #4938, Fix resetting the settings from the “Options” dialog: some settings were (randomly) not restored to their default value
    • Ticket #4954, Open dialog: Support quoted paths
    • Ticket #4956, Improve Play/Pause mouse click responsiveness
    • Ticket #4957/#4982, Do not adjust window width in audio mode if no cover-art/logo is loaded or its size is limited to zero
    • Ticket #4969, DVD playback could fail with an error related to copy protection on some systems
    • Ticket #4971, Bring back “Play next file in the folder” event in single time events menu
    • Ticket #4975, Unrelated images could be loaded as cover-art when no author information was available in the audio file
    • Ticket #4991, Text subtitles: “opaque box” outlines were scaled twice
    • Ticket #4992, DVB: Enabling the “Information” panel using the “Info” button on the “Navigation” dialog would reduce the size of the main window when hiding the panel from the “View” menu
    • Ticket #4993, DVB: The content of the “Information” panel was lost when changing the UI language
    • Ticket #4994, The “Channels” sub-menu was not translated
    • Ticket #4995, Some context menus weren’t properly positioned when opened by App key
    • Ticket #5010, Text subtitles: Fix a crash in case of memory allocation failure
    • Ticket #5055, True/False strings were not translated in value column on advanced page
    • Ticket #5067/#5203, Fix RealText subtitle parsing: the parser did not work at all and could even crash
    • Ticket #5127, Improve the behavior of MPC-HC when doing the MediaInfo analysis when playing from an optical drive. Playback will now be paused during the analysis to avoid concurrent accesses to the disk that might hang playback
    • Ticket #5130, Lock the player when the scan dialog is opened. Double-clicking on a media file will always open a new instance of MPC-HC in this case. This avoids interrupting the scan accidentally and fixes the issues which used to arise when doing that
    • Ticket #5130, Remove the information corresponding to the previously playing channel during the DVB scan
    • Ticket #5131, DVD playback could stutter on some systems
gkontoletas
trouble in my brain
mpc-hc v1.7.10
A few highlights of this release:
  • Completely new Internal Audio Renderer:
    • Uses sanear project as backend
    • Requires Windows Vista or newer
    • Outputs sound through WASAPI (shared or exclusive)
    • Employs automatic channel downmixing
    • Provides stereo crossfeed processing option (for headphones)
    • Tries to preserve signal pitch when playing at custom rate (time stretching)
    • Supports bitstreaming
    Note that you need to select the new renderer in options in order to use it
  • Windows 10 related fixes:
    • Improved mouse behavior
    • Fixed volume control with scroll wheel
    • Window snapping to desktop edges
  • Allow hardware decoding of UHD video with AMD cards
  • Big video rendering stability improvement
  • New Indonesian, Lithuanian and Punjabi translations. Remember that you can help us translating MPC-HC to your language.
Vakis2000
Κλιψ κλαψ
ίσως αφελείς ερώτηση, πρέπει να φορτώσω και τις ενδιάμεσες εκδόσεις, ή αν εγκαταστήσω την τελευταία είμαι ok??
Αγορασα νεο λαπτοπ με 16gb ram, i7 cpu και nvidia 1050 gpu.Δοκιμασα την αναπαραγωγη full hd ταινιων με το Mpc και μου παιζει καποια βαρια x264 λαγκαροντας σε ορισμενα σημεια οπως το παμπαλαιο λαπτοπ που ειχα. Απο την αλλη οταν το ιδιο αρχειο το παιζω σε ενα all-in-one HC της πλακας (samsung j5150) παιζει αψογα.Τι πρεπει να ρυθμισω στο λαπτοπ η εστω με ποιο player μπορω να δω smoothly blueray encodes?Δεν μπορω να πιστεψω οτι το HC εχει καλυτερο hardware για την αναπαραγωγη 1080p αρχειων :p
Quantic
