Κώστας Φ.
A high-end two-way transmission line floor standing loudspeaker. The cabinet design resulted from extensive measurements and listening tests with various internal partitions and cross-sections of the line.
The tweeter
The Scanspeak R2904-7000 is a 1" ring radiator, featuring, SD-2 neodymium motor, non-resonant aluminium chamber, multiple chamber low compression design, machined aluminium faceplate and phase plug. It is a 4-ohm driver with a high sensitivity and an upper frequency limit above 40 kHz.
The mid-woofer
The Scanspeak 18W4531G00 features a non-resonant cone and dust cap structure, dynamic linear suspension, SD-1 patented magnet system, and “Grasshopper" chassis for maximized airflow, and anti-resonance mounting system. Also being a 4-ohm driver it should match the tweeter well.
Περισσότερα: Click
