Δοκιμή του Dune Prime 3.0
Απάντηση: Δοκιμή του Dune Prime 3.0
Δες εδώ:
USB WiFi adapters based on RALink RT2770/RT2870 chipset (for all Dune player models):
WiFi driver: RALink RT2870 version 2.3.0.0.
USB IDs recognized by the WiFi driver and Dune firmware:
0411:00e8 Buffalo WLI-UC-G300N
0471:200f Philips
04e8:2018 samsung linkstick2
050d:8053 Belkin
050d:805c
050d:815c
050d:815c Belkin F5D8053
0586:3416 Zyxel
0789:0162 Logitec 2870
0789:0163 Logitec 2870
0789:0164 Logitec 2870
07aa:002f Corega
07aa:003c Corega
07aa:003f Corega
07b8:2770 AboCom
07b8:2870 AboCom
--- 07d1:3c09 D-Link DWA-140 B1 --- REPORTED TO WORK OK (THE MOST TESTED ONE)
07d1:3c11 D-Link DWA-160
083a:6618 Accton
083a:7512 Arcadyan 2770
083a:7522 Arcadyan
083a:8522 Arcadyan
083a:a618 SMC
083a:b522 SMC
--- 0b05:1731 Asus WL-160N --- REPORTED TO WORK OK
0b05:1732 Asus
0b05:1742 Asus
0cde:0022 ZCOM
0cde:0025 Zyxel
0db0:6899
0df6:0017 Sitecom
0df6:002b Sitecom
0df6:002c Sitecom
0df6:002d Sitecom
0df6:0039 Sitecom 2770
0df6:003f Sitecom 2770
0e66:0001 Hawking
0e66:0003 Hawking
100d:9031 Motorola 2770
1044:800b Gigabyte
129b:1828 Siemens
13d3:3247 AzureWave
1482:3c09 Abocom
--- 148f:2770 Ralink, Trendnet TEW-644UB --- REPORTED TO WORK OK
--- 148f:2870 Ralink, Trendnet TEW-624UB --- REPORTED TO WORK OK
14b2:3c06 Conceptronic
14b2:3c07 AL
14b2:3c09 Alpha
14b2:3c23 Airlink
14b2:3c25 Draytek
14b2:3c27 Airlink
14b2:3c28 Conceptronic
157e:300e U-Media
15a9:0006 Sparklan
15c5:0008 Amit
1690:0740 Askey
1737:0070 Linksys WUSB100
1737:0071 Linksys WUSB600N
1740:9701 EnGenius
1740:9702 EnGenius
177f:0302 lsusb
2019:ed06 Planex Communications, Inc.
5a57:0280 Zinwell
5a57:0282 Zinwell
7392:7717
7392:7718
USB WiFi adapters based on RALink RT3070 chipset (only for Dune player models based on Sigma Designs 864x platform):
WiFi driver: RALink RT3070 version 2.1.2.0.
04bb:0945 I-O DATA 3072
07b8:3070 AboCom 3070
07b8:3071 AboCom 3071
07b8:3072 Abocom 3072
--- 07d1:3c0a D-Link 3072 = DWA-140 B2 --- REPORTED TO WORK OK
07d1:3c0d D-Link 3070
07d1:3c0e D-Link 3070
07d1:3c0f D-Link 3070
083a:7511 Arcadyan 3070
0db0:3820 Ralink 3070
0df6:003e Sitecom 3070
0df6:0042 Sitecom 3072
1044:800d Gigabyte GN-WB32L 3070
13d3:3273 AzureWave 3070
148f:3070 Ralink 3070
148f:3071 Ralink 3071
148f:3072 Ralink 3072
14b2:3c12 AL 3070
1740:9703 EnGenius 3070
1740:9705 EnGenius 3071
1740:9706 EnGenius 3072
18c5:0012 Corega 3070
1a32:0304 Quanta 3070
1d4d:000c Pegatron Corporation 3070
1d4d:000e Pegatron Corporation 3070
1eda:2310 AirTies 3070
2019:ab25 Planex Communications:Inc. RT3070
203d:1480 Encore 3070
5a57:0283 Zinwell 3072
5a57:5257 Zinwell 3070
7392:7711 Edimax 3070
Re: Απάντηση: Δοκιμή του Dune Prime 3.0
χθες συνδεσα για πρωτη φορα το dune με δικτυο και εκανα streaming mkv 720p (ολα καλα) 1080p (σε 2 που δοκιμασα δεν ειχα προβλημα) και σε bluray (οπου ειχε κολληματα)
παρατηρησα ομως μια αλλοίωση στα χρωματα σε ολα...το εχει παρατηρηση κανενας αλλος;
Όχι!!
Τα χρώματα του Dune είναι πραγματικά ΑΨΟΓΑ.
Μήπως (λέω τώρα..) φταίει το καλώδιο HDMI? Δεν δοκιμάζεις και με κάποιο άλλο?
Αλήθεια, όταν λες streaming σε bluray, εννοείς αντίγραφο .iso?
Αντρέα, υπάρχει ενδεχόμενο ο Prime να γίνει, με κάποια προσθήκη ψηφιακού δέκτη, και δέκτης - εγγραφέας της ψηφιακής TV?
To ρωτάω γιατί καμμία από τις λύσεις των ψηφιακών δεκτών δεν καλύπτει όλες τις ανάγκες σε λήψη ψηφιακών καναλιών, εγγραφή αλλά και χρήση σαν media player. Bέβαια υπάρχει και ο Ellion, αλλά δεν λέει να δώσει κανείς άλλα 270 ευρώ για media player - MPEG4 tuner όταν στον τομέα του media player το Dune είναι κορυφαίο.
Αυτό περιμένουμε εναγωνιώς ως την κύρια αναβάθμιση του επόμενου firmware.Θα δίνεται usb stick με ψηφιακό δέκτη.
Μάλλον είναι σε beta testing αυτή την στιγμή.
Απάντηση: Re: Απάντηση: Δοκιμή του Dune Prime 3.0
Όχι!!
Τα χρώματα του Dune είναι πραγματικά ΑΨΟΓΑ. Μονο μεσω lan ειδα διαφορετικα χρωματα.και γιαυτο εχω μια επιφυλαψη θα το ξαναδοκιμασω και θα αναφερω. πρεπει να παρω ενα μεγαλο καλωδιο ethernet γιατι τωρα πρεπει να μετακινω το router μου.
Μήπως (λέω τώρα..) φταίει το καλώδιο HDMI? ειχα το ιδιο καλωδιο, ενα ακριβο ultralink. Δεν δοκιμάζεις και με κάποιο άλλο?
Αλήθεια, όταν λες streaming σε bluray, εννοείς αντίγραφο .iso? αντίγραφο bluray αλλα σε folder
Επειδή είμαι νέος στον χώρο, θέλω να πάρω κάποια απλά ηχεία 5.1 γύρω στα 200€, χωρίς να αγοράσω κάποιον ακριβό ενισχυτή που κάνει την αποκωδικοποίηση HD Audio κλπ.
Μπορεί το Dune 3.0 Prime να κάνει την αποκωδικοποίηση και απλά να συνδέω τον μικρό, απλό ενισχυτή πάνω στο Dune με pass-through και να παίζει έτσι?
Ευχαριστώ πολύ.
Το Dune για να κάνει σωστά DVD upscaling, πρέπει να το υποστηρίζει και ο receiver ή το Dune θα περάσει το upscaled σήμα στον receiver χωρίς να υπάρχει ανάγκη ο receiver να κάνει upscale?
Δες εδώ:
0471:200f Philips
050d:8053 Belkin
050d:805c
050d:815c
0586:3416 Zyxel
07aa:002f Corega
07aa:003c Corega
07aa:003f Corega
07b8:2770 AboCom
07b8:2870 AboCom
083a:6618 Accton
083a:7522 Arcadyan
083a:8522 Arcadyan
083a:a618 SMC
083a:b522 SMC
0b05:1732 Asus
0b05:1742 Asus
0cde:0022 ZCOM
0cde:0025 Zyxel
0db0:6899
0df6:0017 Sitecom
0df6:002b Sitecom
0df6:002c Sitecom
0df6:002d Sitecom
0e66:0001 Hawking
0e66:0003 Hawking
1044:800b Gigabyte
129b:1828 Siemens
13d3:3247 AzureWave
1482:3c09 Abocom
14b2:3c07 AL
14b2:3c09 Alpha
14b2:3c23 Airlink
14b2:3c25 Draytek
14b2:3c27 Airlink
157e:300e U-Media
15a9:0006 Sparklan
15c5:0008 Amit
1690:0740 Askey
1740:9701 EnGenius
1740:9702 EnGenius
177f:0302 lsusb
5a57:0280 Zinwell
5a57:0282 Zinwell
7392:7717
7392:7718
14b2:3c12 AL 3070
Εσυ εχεις καποιο?Αν ναι ποιο και απο που το αγορασες?Επισης ποιο θα μου προτεινες για ποιο αξιοπιστο?
Εγώ έχω το 07d1:3c09 D-Link DWA-140 B1 --- REPORTED TO WORK OK (THE MOST TESTED ONE) το είχα πάρει από το e-shop αλλά τώρα είναι δύσκολο να το βρεις.Το dwa 140 B2 πρέπει να κυκλοφορεί τώρα.
Θα το φέρει όταν θα βγει το επόμενο firmware που θα το υποστηρίζει.Δεν αργεί,κοντά είναι...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
κ. Ανδρέα δείτε αυτό:
http://dune-hd.com/accessories/
Πότε θα μας το φέρετε???
Στην επομενη(αμεση) παραγγελια, αν σταματησεις να μου μιλας
στον πληθυντικο βεβαια:137:
Να ρωτησω κατι,
αναφερει πως
DVB-T USB dongle for Dune media players based on Sigma Designs 864x platform (currently Dune HD Base 3.0 and Dune BD Prime 3.0) with antenna and USB extension cable.
Δηλαδη με τα παλαιοτερα Dune δεν "παιζει"?
  • rose.athens
stavros.vatistas
