Δοκιμή του Dune Prime 3.0
Απάντηση: Δοκιμή του Dune Prime 3.0
Να και οι πληροφορίες για το Dune DVB-T TV Stick.
DVB-T USB dongle for Dune media players based on Sigma Designs 864x platform (currently Dune HD Base 3.0 and Dune BD Prime 3.0) with antenna and USB extension cable.
Specification:
* Compatible with Dune media players based on Sigma Designs 864x platform
* USB 2.0 Standard (USB Type B Female Connector)
* DVB-T Compliant (SD and HD channels)
* Input Terminal: 75 Ohm IEC (DIN) Connector
* Receiving Frequency: 48.25..863.25 MHz
* Bandwidth: 6/7/8 MHz Auto Select
Requirements:
* Dune media player based on Sigma Designs 864x platform
* UHF/VHF Antenna for DVB-T Terrestrial TV (included)
Contents:
* USB dongle
* Compact size antenna
* USB extension cable (1.8m or 2.0m)
Notes:
* Dual-dongle supported: compatible models of Dune players (see above) can work with two Dune DVB-T dongles at the same time. In such a case for example one of the dongles can be used for writing contents from some channel to HDD, another one at the same time is used for watching any other available channel.
* This product doesn't contain any software.
* All the needed software for operating the included USB dongle and working with DVB-T channels is a part of the firmware of the compatible Dune players (see above).
* The first version of Dune firmware supporting DVB-T will include basic work with DVB-T channels (inc. TV programs recording to HDD), but supporting EPG will be included into the future versions of the firmware.
* You can use this equipment with a PC on your own risk. No support for such use is provided.
MSRP:
* EU, with VAT: 59 EUR
http://dune-hd.com/uploads/posts/2010-06/1276077082_dvb-t_800_01.jpg
http://dune-hd.com/uploads/posts/2010-06/1276077144_dvb-t_800_02.jpg
http://dune-hd.com/uploads/posts/2010-06/1276077101_dvb-t_800_03.jpg
http://dune-hd.com/uploads/posts/2010-06/1276077113_dvb-t_800_04.jpg
http://dune-hd.com/uploads/posts/2010-06/1276078554_dvb-t_800_05.jpg
Δηλαδη με τα παλαιοτερα Dune δεν "παιζει"?
Μάλλον το ξεχνάς.
Παρτο απόφαση πρέπει να αναβαθμιστείς!
Ασε τα ΔΝΤ & παραγγειλε το.
Νομίζω οτι ξέρω τον αντιπρόσωπο & εαν του μιλήσω θα σου κάνει καλύτερη τιμή :105:
Αν του πεις οτι είσαι & βάζελος :619:
Δεν ήξερα να του πω ότι είμαι κι εγώ βάζελος!!!
Σύνδεσα χθες ενα σκληρό μέσω e-sata αλλα δεν μπορώ να τον δώ στο menu του Dune. Χρειάζεται καμία ρύθμιση?
Αλλη μια ερώτηση, ενα adapter σαν αυτό της Netgear ( http://www.netgear.com/Products/Adapters/RangeMaxWirelessNAdapters/WNDA3100.aspx ) πως μπορούμε να βεβαιωθούμε οτι συνεργάζεται με το Dune μας?
Διότι μεν η HDI δηλώνει τα chipset των adapters με τα οποία συνεργάζεται αλλά η Netgear δεν αναφέρει κάτι σχετικό.
Οσον αφορά το netgear wnda 3100 έχει το Atheros AR-9001U(-2NX) άρα δεν υποστηρίζεται από το Dune.
Ο σκληρός που σύνδεσες σε τι format είναι?
O δίσκος ειναι 2ΤΒ σε NTFS εντός θήκης Fantec ( http://www.plaisio.gr/Peripherals/P...-Sata-to-USB2-0-eSata-Black-FB-35US2-1396.htm).
Edit: Μόλις διάβασα στο manual οτι πρέπει να ανοίξεις πρώτα τη συσκευη e-sata και μετα το Dune. To δοκίμασα αλλα κολλάει στο loading. Δηλαδη γράφει loading (δεν μετρα 123) σταματάει ξανακάνει loading κλπ.
Κανονικά θα πρέπει να τον βλέπει,περίεργο.Αν τον συνδέσεις με usb τον βλέπει?
Me usb δουλευει κανονικά. Ισως με το νεο firmwire!
Δοκίμασε να το δοκιμάσεις με άλλο καλώδιο e-sata,μήπως φταίει το καλώδιο.
Που την βρήκες την πληροφορία για να μη σε ρωτάω για καθε ένα που βρίσκω (όπως αυτό http://www.netgear.com/Products/WirelessRouter/WirelessRoutersforWorkandPlay/DGNB2100.aspx)?
Βαλε στο google wnda 3100 chipset και θα το βρεις.
Re: Απάντηση: Δοκιμή του Dune Prime 3.0
Σε μένα πάλι έχει τύχει με 2 WD (ένα 2 και ένα 1 TB) να μην λειτουργεί η σύνδεση e-sata. To διαπίστωσα σε 2 υπολογιστές και δεν ξαναπήρα σκληρό με e-sata.
Εγώ στο δικό μου είχα δοκιμάσει με seagate σκληρό και no name κουτί και δούλευε μια χαρά η e-sata.
ρε παιδιά το DVB-T TV Stick δουλεύει τελικά, να το παραγείλουμε ή να πάρουμε αποκωδικοποιητή όπως οι παπούδες; 2 μέρες μείνανε!
Δεν κυκλοφόρησε ακόμη ούτε αυτό ούτε το νέο firmware.
Σ' εμένα ένας 500ρης WD δεν δουλεύει με σύνδεση e-sata και αναγκαστικά τον συνδέω μέσω usb.
Αντίθετα ένας g-drive στο 1Τ δουλεύει άψογα μέσω e-sata
Εχει παρατηρήσει κανεις πρόβλημα overscan στο dune;
Εδώ και μερικούς μηνες εχει αναφερθεί και στο AVS αλλα και στο MPC , πρόβλημα χαμένων πιξελ δεξια και στο κατω μερος της οθονης…
Μετα από δοκιμή που εκανα στο δικο μου player ειδα πως oντως παρουσιάζει το ιδιο προβλημα ( δηλαδή χαμενα πιξελ δεξια και στο κατω μερος της οθονης)
Αν θέλετε μπορείτε να τεστάρετε και το dune σας με κάποια πατερνακια σαν το παρακάτω αλλα εχετε υπόψη πως το προβλημα εμφανίζετε μονο από bluray τιτλο ( είτε είναι δισκος ειτε είναι iso file) και όχι από snapshot pattern.
Στο avs μάλιστα σε συγκριτικό με το popcorn αναφέρθηκε η διαφορα ευκρίνειας υπερ το popcorn προφανώς για τον λόγω που περιγράφω…
Ας ελπίσουμε πως θα το διορθώσουν σύντομα…
Το είχα διαβάσει κι εγώ στο mpcclub,έχουν δίκιο το δοκίμασα με blu ray.Νομίζω στο επόμενο firmware θα το φτιάξουν!
stavros.vatistas
