Δοκιμή του Dune Prime 3.0
Απάντηση: Δοκιμή του Dune Prime 3.0
Και εγω το ελπίζω γιατι εχουν περάσει ήδη δυο μηνες από τοτε που εγινε αντιληπτό το προβλημα και ενώ εχουν δώσει πρόσφατα νέο firmware το πρόβλημα δεν διορθώθηκε…
Κατι λέγεται για το επόμενο ( το καλο που περιμένουμε) …
Αντε να δούμε.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Να και οι πληροφορίες για το Dune DVB-T TV Stick.
DVB-T USB dongle for Dune media players based on Sigma Designs 864x platform (currently Dune HD Base 3.0 and Dune BD Prime 3.0) with antenna and USB extension cable.
Specification:
* Compatible with Dune media players based on Sigma Designs 864x platform
* USB 2.0 Standard (USB Type B Female Connector)
* DVB-T Compliant (SD and HD channels)
* Input Terminal: 75 Ohm IEC (DIN) Connector
* Receiving Frequency: 48.25..863.25 MHz
* Bandwidth: 6/7/8 MHz Auto Select
Requirements:
* Dune media player based on Sigma Designs 864x platform
* UHF/VHF Antenna for DVB-T Terrestrial TV (included)
Contents:
* USB dongle
* Compact size antenna
* USB extension cable (1.8m or 2.0m)
Notes:
* Dual-dongle supported: compatible models of Dune players (see above) can work with two Dune DVB-T dongles at the same time. In such a case for example one of the dongles can be used for writing contents from some channel to HDD, another one at the same time is used for watching any other available channel.
* This product doesn't contain any software.
* All the needed software for operating the included USB dongle and working with DVB-T channels is a part of the firmware of the compatible Dune players (see above).
* The first version of Dune firmware supporting DVB-T will include basic work with DVB-T channels (inc. TV programs recording to HDD), but supporting EPG will be included into the future versions of the firmware.
* You can use this equipment with a PC on your own risk. No support for such use is provided.
MSRP:
* EU, with VAT: 59 EUR
http://dune-hd.com/uploads/posts/2010-06/1276077082_dvb-t_800_01.jpg
http://dune-hd.com/uploads/posts/2010-06/1276077144_dvb-t_800_02.jpg
http://dune-hd.com/uploads/posts/2010-06/1276077101_dvb-t_800_03.jpg
http://dune-hd.com/uploads/posts/2010-06/1276077113_dvb-t_800_04.jpg
http://dune-hd.com/uploads/posts/2010-06/1276078554_dvb-t_800_05.jpg
Ερχονται, μαλλον αρχες της επομενης εβδομαδας.
Αληθεια ξερετε οτι μπορειτε να βαλετε και 2 stickακια επανω
σε καθε συσκευη?:121:
Το γιατι το αφηνω να το μαντεψετε...
Εγώ που έχω κάνει... σκονάκι, μπορώ να απαντήσω?:123:
Αν και το γράφει παραπάνω:
Έκανα edit στο post που έγραψα παραπάνω.
Έχω δίκιο????
Η πλάκα είναι πως όταν πήρα το Dune αναρρωτιόμουν τι στο καλό χρειάζονται 3 υποδοχές usb. Τώρα σκέφτομαι αν φτάνουν...:121:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Απάντηση: Re: Δοκιμή του Dune Prime 3.0
Έχω δίκιο????
Ναι, τωρα το ειδα πως το εκανες edit.
Ωραια στα "σφυριξε" ο Λαμπρου, ε?:136:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Μήπως έχεις και πληροφορίες για το πολυαναμενόμενο firmwire?
Τιμή μπορείς να πεις?
Firmware οσονουπω.
Τιμη, πανω κατω η ιδια θα παιζει παντου ...
Τι εννοειται ...τιμη? Για το firmware θα πληρωσουμε?:140:
Re: Απάντηση: Re: Δοκιμή του Dune Prime 3.0
Ωραίος φίλος είσαι!!!:138:
Τον έδωσες στεγνά!!!
Ανδρέα για όλους εμάς που έχουμε το prime 2.0, θα γίνει κάποια προσπάθεια για συμβατότητα;
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Αχιλλεα, ειμαι στην ιδια βαρκα μαζι σας.
Και εγω το Center εχω...
Μια απλή ερώτηση γιατί όσο και να έψαξα δεν βρήκα πληροφορίες. Στην οθόνη του dune μπορείς να δεις το filename που πρόκειται να παίξει; Τ ρωτάω για χρήση σε μουσική όπου δε θες να ανάψεις το προβόλι για να βρεις το κομμάτι που θελεις να παίξεις. Ευχαριστώ προκαταβολικά.
στα +50€ ειναι και τα μεταφορικα για να στειλεις και να σου ξαναστειλουν το Dune σου;
DAMBO
