Technics SL-1200 CLUB
Από Αγγλικά πώς πας;
24-bit precision gives you about 16.77 million values. Assuming a total groove width of 50 x 10^-6m, the maximum movement of the cutter is physically bounded at about half that. Much more and the cutter will be in the space for an adjacent groove. Thus, 50 microns width divided by 16.77 million gives us about 3 x 10^-12m, i.e. ~0.03 angstroms.
The diameter of a hydrogen atom is 1.0 angstroms (1 x 10^-10m). That would make the resolution of a 24-bit digital signal equivalent to an analog cutter whose resolution is just about 1/30 the width of a hydrogen atom. Sadly, this seems to be physically impossible, as none of the particles smaller than atoms are stable enough to be used in records.
Of course, records aren't made of hydrogen, they're made of the polymer pvc. One molecule of pvc is about 100,000 angstroms. This means that, if the cutters were actually removing single pvc molecules the vinyl records would have about 11 bits of resolution. Sadly, they don't get even that precise, though I'm not sure the actual precision. To get down to a record made of hydrogen atoms (possible under very low temp/very high pressure I suppose) one would need 19 bits. Anything beyond that is useless as long as the laws of physics hold.
Therefore, all other things being equal, digital is superior to vinyl. That said, mastering on CDs is often terrible while the mastering on records is often made somewhat better. This varies from CD to CD and record to record, and CDs are technologically far superior to records.
Πηγή
Απάντηση: Technics SL-1200 CLUB
Άρχοντα δεν μπορώ να πιστέψω ότι κάποιος σε στρίμωξε στα σκοινιά!!:109:
Γιά προχώρα στο παρασύνθημα, για προχώρα..:142:
Λάθος το θέτεις!
:107:
Ρε παιδιά εδώ είσαστε όλοι ακόμα και περιμένετε;
Δεν υπάρχει ματς σήμερα! Αύριο! Να φύγετε να πάτε αλλού!
(Κάνω μαθήματα Αγγλικών).
:142:
Ο φίλος ο Petros Dalipis το έθεσε αριστοτεχνικά και θέλει μελέτη!
(Σίγουρα πάντως θα γίνει ματς!)
:107:
Μόλις γύρισα σπίτι.
Ήμουν στο φίλο DIMPAS, που έχει και αυτός 1200 MK2 και ακούγαμε μουσικούλα στο background (μα καλά, κάθε λίγο και λιγάκι να αλλάζουμε πλευρά!!), κάνοντας ταυτόχρονα και δουλειά. Μετά πέσαν και κάτι μάσες παρέα με το βινύλιο της Belinda Carlisle και γουστάραμε.
Να το πικαπάκι του. Δίπλα στο B&W και δεν καταλαβαίνει τίποτα από κραδασμούς!
Φίλε caravelle, όταν παραθέτω κάτι στα Αγγλικά, πάντα ρωτάω αν ο συνομιλητής μου το κατανοεί. Μακάρι να ήμουν σπίτι και να είχα χρόνο να το μεταφράσω. Αφού το διάβασες όμως :444:
Μόλις γύρισα σπίτι.
QUOTE]
Πω πω ευλάβια με το βραχίονα!!!! Ωραίοςςςςςςς
Λοιπον για να δουμε τωρα πως θα το αλφαδιασουμεεεε!!!
Εχω στην κατοχη μου σημερα τα παρακατω αλφαδια,ποιο θα κανει την δουλεια σωστα?
Manos58
εγχειρισμένη
Ενα ψηφιακο,καλιμπραρισμενο,χωρις τζιττερ.
Απάντηση: Re: Technics SL-1200 CLUB
Ούτε θεωρητικά, λυπάμαι.
Το λοιπόν, όταν λέω θεωρητικά εννοώ αυτό ακριβώς:
Tώρα ότι στην πράξη, όπως λέει και το εντυπωσιακό άρθρο που παράθεσες, (άσχετα αν λίγο παρακάτω ανασκευάζει...ελαφρώς ο ίδιος), υπάρχουν περιορισμοί που καταλήγουν να λειτουργεί και το αναλογικό σαν...ψηφιακό, ε, αυτό είναι και ο λόγος που υπάρχουν και προοδεύουν τα ψηφιακά!
Πάντως η θέση η δική μου είναι πως η διαδικασία της εγγραφής, δυστυχώς, σπάνια εκμεταλλεύεται πλήρως όλες τις δυνατότητες του μέσου και έτσι υπάρχουν 24/192 εγγραφές με χειρότερη απόδοση από το 16/44 και βινύλια με καλύτερη η και χειρότερη απόδοση από τα προηγούμενα!
:107:
Παρών
Το στρόγλυλο δεν θα σε προβληματίσει.
Το ίσιο θα δείξει σωστότερα αλλά θέλει μία οριζοντίωση στην κάθετο και μία στην παράλληλο.
Οποιο και να βάλεις να είναι στο πάνω στο πλατώ εκεί που ακουμπά η βελόνα.
Αυτό που ίσως δυσκολεύει κάποιους να καταλάβουν, είναι ότι τα σκαλοπάτια από το ψηφιακό σήμα εξομαλύνονται από κυκλώματα και εκεί είναι η μαγκιά που κάποια DAC τα καταφέρνουν καλύτερα από άλλα (εκτός από τα αναλογικά του στάδια). Μαθηματικά είναι άλλωστε, με χειροπιαστό ανάλογο ---> Πάρε μια λίμα και φάε (εξομάλυνε) τις γωνίες στο ψηφιακό σήμα.
Γιάννη είχα γράψει για τις αεροστάθμες, τώρα που έχεις τη σωληνωτή στα χέρια σου, μέτρησε αν έχει σφάλμα με τον τρόπο που είχα περιγράψει.
pablonou
