Ο Βασιλιάς πέθανε....Ζήτω ο Βασιλιάς!
themiloc
Έτσι κάτι προκαταρκτικό για να κόψω τη φόρα και να δημιουργήσω φαντασιώσεις.
__________________________________________________
The MEDEA with the latest re-design of the analog section has
once again reached State Of The Art performance.
All Medea units are upgradeable with this new analog section.
In addition a built-in FireWire interface is available which
connects the Medea to computers for audio file playback.
The FireWire input can be remote controlled via a IR remote
control (level and absolute phase).
An ST type glass fiber input (optional) allows to connect the
Medea to the Weiss Jason CD transport via a non-compromise
glass fiber link.
The MEDEA is built to be immune to jitter down to subsonic
jitter frequencies. Using the same algorithms as our
professional audio product range, we incorporated upsampling
in a dedicated DSP chip.
A powerful non-switching power supply is used. All sensitive voltages have their own regulators which are separated between left and right channels. The power switch only switches at zero crossings of the mains voltage, assuring a glitch free power switching.
The MEDEA employs a twin metal frame.
The inner chassis is made of steel for effective shielding
against electrostatic and electromagnetic radiation. The outer
frame is individually made to our exacting standards from
massive anodized aluminium for additional shielding, heat
convection - and of course stunning looks.
One power switch. Four switches with
corresponding blue LEDs are used for selecting one out of four
input sources.
The new analog section with eight discrete operation amplifiers (the Weiss OP1-BP) and an eight channel 32 bit State Of The Art D/A converter chip.
Απάντηση: Ο Βασιλιάς πέθανε....Ζήτω ο Βασιλιάς!
Η δημιουργία εντυπώσεων μόνο κακό σας κάνει.
Απάντηση: Re: Ο Βασιλιάς πέθανε....Ζήτω ο Βασιλιάς!
καποιοι λενε οτι παιζει κοντα στα επιπεδα του Orpheus Heritage το οποιο τυχαινει και το εχουν δυο γνωστοι....
θα είναι οι ιδιοι που λένε ότι παίζουν και τα Tidal, άρα μιλάμε για πολύ "ασφαλή" συμπεράσματα και διορθώστε με αν κάνω λάθος
vlasis
Φωτογράφος!
Βρε παιδια και παπαδες και μητροπολιτες Πασων των Ρωσιων να παιζει.......20000 ειναι τρελλα λεφτα για μια πλακετα που λιγο πολυ ξερουμε πως ειναι.....τι να πω ....εκτος και αν ειμαι νυχτομενος αλλου!!!!!!
Δεν ξερω....βρισκω τα χρηματα υπερβολικα και 200 κιλα να ειναι ....τι στα διαλα ...κονβερτορας ειναι ρε πουστη μου.......:141:
οι Κινεζοι του Audioexotics το λενε δε το λεω εγω... Τωρα εαν εχουν δικιο η αδικο δε μπορω να ξερω.... Προσωπικα αμφιβαλλω παρα πολυ για το εαν αυτο το DAC παιζει καλυτερα απο το Heritage....
παντως εχεις δικιο, ολοι αυτοι Tidal εχουν...
εαν τα 20 χιλιαρικα σου φαινονται πολλα για κονβερτορα , σκεψου πως θα σου φανουν τα 40 χιλιαρικα που κανουν αλλα!!!!
Kotsidis John
Photography
Μηπως η οθονη αναμεσα απ τα ηχεια θελει λιγο καλιμπραρισμα??
Γιατι ματζεντιζει λιγο μου φαινεται...!!!:142::142::137:
VLASSIS-S
Sιγμοειδής Νέμεσις
esoteric - dcs εχετε ακουσει?
Όλο κάτι τέτχοια λες, και γι' αυτό σε μπάναραν στο χαζομάγαζο... :114:
γιατι το Vekian το εχουμε ακουσει?
(εκτος απο κανα δυωρο περυσι στο Μοναχο)
Τοση ωρα συνολικα ακουσα και το Scarlatti....
Re: Απάντηση: Ο Βασιλιάς πέθανε....Ζήτω ο Βασιλιάς!
υπάρχουν:
-πορτοφολάκιας
-τσαντάκιας
-κλεφτρόνια
-απατεώνες
-ριφιφίδες
(ωραίο επιχείρημα πάντως)
Η απάντηση του gkar είναι "απόσταγμα" 30 ημερών...
Και με τόσο μικρή "εμπειρεία" τολμά να έχει άποψη για το hi end? :114:
VLASSIS-S
Sιγμοειδής Νέμεσις
τελικα το αποφασισα. αναλογα με τον αντιπροσωπο θα παιζει .
κι αμα ο αντιπρόσωπος είναι χονδρός ;
θα παίζει το σύστημα με φουσκωμένο χαμηλό ; :114:
VLASSIS-S
Sιγμοειδής Νέμεσις
@g.kar αφου σου τα εχω πει. ο ονγκος κοβει το χαμηλο. λειτουργει ωσαν μπασοπαγιδα.
καλα ας αξιωθει να το φερει κανενας (γενναιος ) χριστιανος και μετα θα δουμε αν παιζει η οχι και αν αξιζει τα λεφτα που ζηταει...
anquan
