Δοκιμή των Dune HD Max & Smart B1-D1-H1,Duo
NOTE: Includes also all changes from 120127_2115 (see below).
* Added "Soft Reset" function:
- Now the "Reset Settings" function proposes two choices: full reset to factory defaults (the same as took place in previous firmware versions), and so called "soft reset".​
- The soft reset clears the settings only partially and is more convenient in cases when the user does not need full factory reset.​
- The following things are cleared by the soft reset:​
- All settings from Setup menu.​
- All plugins settings.​
- All cached data and data stored by the player for its own needs.​
- All bookmarks (remembered playback positions).​
- The following things (which may be hard to reconfigure from the scratch) are kept by the soft reset:​
- All configured network folders.​
- All favorites configured in the main menu.​
- All installed plugins.​
* Improvements for the users of big remote controls:
- Added the setting allowing to choose the behavior POP UP MENU RC button: toggle playlist/TV menu (as took place in previous firmware versions), or toggle the new functions menu (introduced in the latest firmware version) (this is the default behavior). The old behavior (toggle playlist/TV menu) can be convenient for the users used to it. Enabling the old behavior makes the functions menu unavailable (and thus it may be reasonable only for users of big remote controls, which have dedicated buttons allowing to trigger various playback functions w/o the need to use the functions menu). The setting: 'Playback / Preferences / POP UP MENU button'.​
- On the models which are shipped by default with big remote control, LEFT/RIGHT RC buttons during playback now trigger the time seek function (as took place in previous firmware versions), rather then the volume function (as was introduced in the latest firmware verion).​
* Tvigle.ru application improvements:
- Added setting allowing to manually control if the application is shown or not on the main screen: 'Setup / Applications / Tvigle / Shown on the main screen'.​
* Minor other improvements and fixes.
Changes in 120127_2115
* Improved handling of deinterlacing settings:
- Deinterlacing mode choice is now remembered (for file/IPTV playback). The remembering can be disabled via a new setting: 'Save deinterlacing mode settings'.​
- A warning is shown in some cases when BOB deinterlacing mode can give better results but is not selected.​
- BOB deinterlacing mode is forced automatically for DVD playback when it is needed (in interlaced video modes).​
* Improved ZOOM settings (for file/DVD/IPTV playback):
- Two new full screen ZOOM modes added:​
- Full screen with preserved proportions (if video aspect ratio is not the same as TV aspect ratio, some parts of the picture is cropped).​
- Full screen without preserved proportions (if video aspect ratio is not the same as TV aspect ration, the picture is stretched to fill the screen).​
- The rest of ZOOM modes are rearranged, better names given to some modes.​
* Plugins improvements:
- Plugins installed into flash memory storage are kept on firmware upgrade by default now. All other content of flash memory storage is also preserved. The old behavior (disabling flash memory storage and reinstalling optional firmware components) can be forced via a new setting.​
- Bugfix: after plugin is deinstalled, some plugin data could be kept.​
- Bugfix: Scrolling movie description of movie page using PREV/NEXT RC buttons did not work for plugins.​
* Improved initial video mode configuration for all models:
- The following features are now available on all models (previously they were implemented for Dune HD TV-101 model only):​
- Showing picture on both HDMI and Composite video outputs on first boot.​
- Initial video mode setup wizard.​
* Other improvements and fixes:
- Added support for "rtp://@" syntax for media URLs pointing to multicast streams. (The new syntax is handled the same way as "udp://@" syntax, including autodetection of RTP and raw-UDP.) The new syntax can be used in playlist files, applications, etc.​
- Bufgix: navigation through dune_folder.txt-based applications was very slow in some cases (caused by slow loading of AAI image files). (The problem was introduced in the previous firmware version.)​
- Bugfix: Playback of MMS streams were broken. (The problem was introduced in the previous firmware version.)​
- Bugfix: WiFi scan worked wrongly in some cases.​
- Bugfix: FlashLite API support for persistent data storage did not work properly on Dune HD TV-101 and Dune HD Lite 53D.​
- Minor other improvements and fixes.​
Απάντηση: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Σωστά το έβαλες!Το οποίο ήταν private beta κι όχι public!
Σχετικά με την αναπαραγωγή blu ray,κάποιο δισκάκι που δεν έπαιζε πριν με το νέο firmware παίζει?Το δοκίμασε κανείς?
Καλημέρα LLLEFTERIS,
Από τον φάκελο των plugins έχεις δοκιμάσει τίποτε ?
Ξέρεις τι είναι όλα αυτά ? (εκτος του youtube)
Κάτι σαν IPTV μου φαίνονται, αλλά δουλεύουν ?
Ευχαριστώ.
L
LLLEFTERIS
Απάντηση: Re: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Ναι αυτο ειναι αλλα πρεπει αν μαθουμε Ρωσσικα.
Είναι για πάροχους iptv στην Ρωσία,δεν αφορούν εμάς εκτός αν έχετε συνδρομή σε κάποιον από αυτούς!
L
LLLEFTERIS
Παντως σημερα που το χαζευα εχει πολλα μεσα και πολλα παιδικα και η γυναικα μου χαρηκε για να τα βαζει στον γιο μου αλλα φοβαμαι μην καμια μερα τον δω με καμια βοτκα στο χερι και να μου λεει ντα!
L
LLLEFTERIS
Πηρα καινουρια τηλεοραση την 50GT30 και εχω βαλει να την στρωσω απο το Dune και μου δειχνει σε ολες τις ταινιες οτι εχω σημα 1080P 24 γιατι 24; αφου στις ρυθμισεις εχω βαλει 1080p 50 και 24/50/60
Γιατί οι ταινίες είναι γυρισμένες στα 24p.
Έχω δύο προβλήματα με το Dune HD B1.
1)To ERT HD δεν μου δουλεύει. Κάνει πράσινα σπασίματα ενώ τα άλλα λειτουργούν κανονικά.
2)Δεν μπορώ να δω το menu όταν το έχω πάνω στον Onkyo TX-NR609. Αν επιλέξω ταινία στα τυφλά μέσω της μικρής οθονούλας το παίζει κανονικά. Αν σταματήσω τίποτα. Σε απευθείας σύνδεση με την τηλεόραση δεν έχει πρόβλημα. Κάνει μπαμ ότι είναι θέμα HDMI handshaking. Αλλά έχω δοκιμάσει και με άλλο καλώδιο και σε άλλο Port και μόνο στο menu έχει θέμα. Καμια ιδέα ή λύση?
Να τονίσω ότι έχω δοκιμάσει να ανοίξω πρώτα το Dune και μετά τον Onkyo και το αντίστροφο.
Επίσης έχω συνδέσει απευθείας τον Onkyo στη TV παρακάμπτοντας το splitter.
Στον προηγούμενο δεν είχα θεμα.
Στις ρυθμίσεις video στο μενού του Dune τι έχεις βάλει?Αν θες γράψτα αναλυτικά γιατί κάτι από εκεί πρέπει να φταίει μάλλον!
Λεωνίδα, εμένα μου θυμίζει πρόβλημα handshake του Onkyo. Eίναι γνωστοί οι Onkyo γι' αυτά.
Για τους Onkyo δεν το ξέρω,αλλά από τα διάφορα Dune που είχα κατά καιρούς υπήρχαν τέτοια προβλήματα.Με τις ρυθμίσεις video στο μενού τους λυνόντουσαν!Γι αυτό θέλω να μου πει τι ρυθμίσεις έχει!
L
LLLEFTERIS
Γιατι στην 46G10 που ειχα μου εγραφε 1080/50 δεν ειχε αυτη 24;
ichaltou
Αλλαχτήρι
σε τι ανάλυση το είχες ? το μενού εαν θυμάμαι καλά είναι σε 1080/50...
Έχω βάλει 1080p 60Hz(έχω δοκιμάσει και με 24Hz), framerate 24/50/60 και στο advanced 8bit στο πρώτο λόγω TV και Auto στα υπόλοιπα.
Να σου πω την αλήθεια δεν ξέρω...Ίσως μου είχε μείνει από την ανάλυση του PC. Θα το δοκιμάσω το μεσημέρι που θα γυρίσω από τη δουλειά.
Λογικά πάντως ο ενισχυτής δεν θα έπρεπε να έχει θέμα.
L
LLLEFTERIS
Μπορω να δωσω μεσω ethernet απο το MAX ιντερνετ στην τηλεοραση; Panasonic 50GT30
Απο υπολογιστη σε υπολογιστη μπορεις να δωσεις με ενα ανεστραμμενο Ethernet καλωδιο και ετσι εδωσα στην τηλεοραση απο το laptop αλλα επειδη εχω στικακι Wireless στο MAX μηπως με καποιον τροπο γλυτωσω την αγορα ακομα ενος usb stick
Ενας αλλος τροπος που σκεφτηκα ειναι να παρω ενα Access Point που να περνει ασυρματα ιντερνετ και να το μεταδιδει μεσω Ethernet γιατι ο AV που θα παρω θα εχει και αυτος Ethernet.
Υπαρχει Access Point που να περνει ασυρματα και να βγαζει 3-4 Ethernet? Θα κανω δουλεια με αυτο γιατι το ιντερνετ δεν το εχω εγω εδω σπιτι μου αλλα απο κατω ο πεθερος μου.
TehLooney
