Απάντηση: Media Player Classic Home Cinema
Αυτό πρακτικά τι σημαίνει Γιώργο?
complete changelogNew:
- New webpage (http://mpc-hc.sourceforge.net)
- Source code moved to GitHub (https://github.com/mpc-hc)
- The DirectX runtime dlls are included in the distribution packages so it’s no longer needed to install the DirectX runtime
- MpegSplitter: support for DVD-Audio LPCM and MLP in .aob files
- Use FFmpeg for AC3 and DTS decoding
- If the icon library is modified in a way that can break the icons associated to the extensions handled by MPC-HC, MPC-HC will automatically try to fix the registry so that each extension is associated to the correct icon
Changed:
- Unrar is statically linked and so MPC-HC and VSFilter no longer need the unrar dll
- The Icon Library was rewritten leading to smaller size
- The Output Options page was redesigned for better usability
- Ticket #625, The translation dll’s size was decreased by 2/3 (uncompressed)
- Ticket #2227, Hide the seek bar in capture mode
- Ticket #2276, Use the new user interface on Vista and later for the Save dialogs
- Ticket #2342, MPC-HC will now use the Windows theme font for the Statusbar, OSD messages and a few other places on Windows Vista and newer
- Ticket #2378, Move the “Remember last playlist” option into the Options dialog
...που μου αρέσει πιο πολύ!MPC-BE μια διαφορετική προσέγγιση του Media Player Classic...
