Δοκιμή του Dune Prime 3.0
Απάντηση: Δοκιμή του Dune Prime 3.0
Version "121018_0846" (the latest stable version)
http://dune-hd.com/firmware/
Changes since 120815_2150:
- NOTE: This is a minor update to 120815_2151.
- Dune HD TV models: Bugfix: Vidimax application could report "error 7" in
some cases during playback.
- Bugfix: fixed problem with the playback of certain MMS URLs (the problem
appeared in the firmware version 120608_1420_beta).
- Bugfix: playback of MPEG-TS streams w/o audio and with temporary audio
dropouts could cause problems. (This includes playback of multicast, HLS,
DVB MPEG-TS streams.)
- Bugfix: playback of media content via HTTP protocol could cause hangup in
some cases (e.g. when the server did not respond).
- HLS playback improvements:
- By default, the initial quality is now chosen based on the previous
statistics (remembered till reboot).
- Various performance and stability improvements.
- Bugfix: too long HLS URLs were refused to play.
- media_url: 'hls_initial_bandwidth' parameter extended with new possible
values: 'auto' and 'auto_high'.
- More details: http://dune-hd.com/support/misc/media_url.txt
- Improvements in API for PHP plugins:
- Default PHP plugin operation timeout increased to 60 seconds.
- Bugfix: PHP plugin operation was handled in wrong way in some cases.
- Bugfix: EPG OSD column had wrong title in some cases.
- Dune HD TV models: Improvements in API for HTML+JS applications:
- Bugfix: when playing HLS stream, read error events could be wrongly
generated even in the absence of any errors.
Το αυθεντικό ελληνικό bluray Ice Age 4 αρνείται κατηγορηματικά να παίξει τόσο στο Prime όσο και στο pc με το Powerdvd. :141::141:
Απορώ τι σκ@τ@ έχουν κάνει....
ichaltou
Αλλαχτήρι
στειλτο σε μένα... το αγοραζω....
βαλτο στο anydvd και καντο αρχείο...
To anydvd λέει ότι δεν μπόρεσε να αφαιρέσει το BD+...:141:
Επίσης και το makeMKV δεν κατάφερε να το ανοίξει.
Τα ξέραμε τα κόλπα εδώ και χρόνια Γιαννάκη. Άλλο που βαρέθηκα να ασχολούμαι με το σπορ.
Την τελευταία 7.1.0.0.
Βαριέμαι τώρα να εγκαταστήσω το ΤΜΤ. Πάντως στο Panasonic BD-50 παίζει.
gkontoletas
trouble in my brain
Στο Prime με Play Lite δεν παίζει;
έχεις την τελευταία έκδοση του PowerDVD 12 build 2118a;
Η Slysoft γνωρίζει το πρόβλημα και νομίζω ότι σε λίγες μέρες κάτι θα κάνει...
Δοκίμασα το δισκάκι. Απόψε θα δοκιμάσω και το iso που παίρνω από το anydvd με play lite, ή με αυτό που παίρνω με το imgburn.
Το powerdvd 12 το έπαιξε τελικά με την τελευταία έκδοσή του. Το κουφό είναι ότι πριν περάσω την ενημέρωση, το δισκάκι έπαιξε με το powerdvd 11! :111:
Μηχανήματα του διαβόλου......:114:
Στο Prime έχεις περάσει το τελευταίο firmware Γιάννη,αυτό που βγήκε πριν 3-4 μέρες?
Στο ένα ναι, στο άλλο όχι. Το αποτέλεσμα ήταν το ίδιο. Μεταφέρω τώρα στον δικτυακό, τόσο το bluray folder όσο και το iso (71,4 GB), και θα ενημερώσω.
Με τη λειτουργία Play Lite η αναπαραγωγή ξεκίνησε κανονικά, τόσο σε folder όσο και σε iso. Όμως: προφανώς η προειδοποίηση του anyDVD ότι μπορεί να υπάρχουν προβληματικά frames είναι πραγματική. Η εικόνα παρουσιάζει έντονο πιξέλιασμα σε διάφορα σημεία του κάδρου σε όλη τη διάρκειά της, με αποτέλεσμα να γίνεται αδύνατη η παρακολούθησή της.
Το ίδιο συνέβη νωρίτερα με την αναπαραγωγή του iso από το PowerDVD στον υπολογιστή, και το είχα αποδώσει σε πιθανή αδυναμία της κάρτας γραφικών.
Θα δοκιμάσω σε λίγο την beta έκδοση του anyDVD και βλέπουμε.
Δεν κράτησε και πολύ η δοκιμή:
"No data for the disc "ICE_AGE_4" is available in the online decryption database!
Please try again later! "
ήταν το μήνυμα που πήρα μόλις το anyDVD έλεγξε το δισκάκι. :141:
Καλησπέρα σε όλους
Επαναφέρω το νήμα στην επικαιρότητα για δυο λόγους:
Ο πρώτος έχει να κάνει με την επανενεργοποίηση του δικού μου Prime, το οποίο καθότανε για μεγάλο χρονικό διάστημα ανενεργό, ή μάλλον έπαιζε απλά το ρόλο ενός κανονικού BD player και τίποτα παραπάνω.
Όταν το είχα αγοράσει (Φεβρουάριος 2010), είχα τη φιλοδοξία να το χρησιμοποιήσω ως διπλή συσκευή, τόσο ως απλό Blu-ray όσο και ως Media player. Αλλά, αφ' ενός η συχνή - για την εποχή - απουσία μου στο εξωτερικό και αφ' ετέρου το γεγονός ότι μπήκα για τα καλά στην ενασχόληση που λέγεται "HTPC/PC building", η φιλοδοξία αυτή ατόνισε και η συσκευή έμεινε να κάνει μόνο το ένα από τα δύο, το πρώτο.
Ο δέυτερος λόγος, σχετιζόμενος άμεσα με τον πρώτο, είναι η ανάγκη προσθήκης εσωτερικού δίσκου, προκειμένου να απλοποιηθεί η λειτουργία του σαν Media player.
Για τον πρώτο λόγο (δηλ. για ολοκληρωμένη χρήση ως Media player), φαντάζομαι ότι θα χρειαστώ κάποια πραγματάκια, που ίσως αφορούν κάποιες ενημερώσεις ή αναβαθμίσεις στο λογισμικό-λειτουργικό του και στη διαδικασία συνδεσιμότητάς του. Επομένως, και προκειμένου να μην ψάχνω τις προηγούμενες 75 σελίδες του νήματος, ερωτώ:
- Υπάρχει κάποια ενημέρωση ή αναβάθμιση που πρέπει να εφαρμοστεί στο λογισμικό-λειτουργικό του? Και αν ναι, πού θα τη βρω και πού θα ψάξω να βρω τη διαδικασία εφαρμογής της? Η ερώτηση αφορά ακόμα και αν αυτή η πληροφορία υπάρχει εδώ, σε αυτό το νήμα.
- Κάπου διάβασα ότι εκτός από το διαθέσιμο στη συσκευή περιβάλλον, υπάρχει και άλλο, προερχόμενο από ανεξάρτητο κατασκευαστή λογισμικού. Αν ναι, αξίζει τον κόπο, είναι δύσκολο να εγκατασταθεί και γενικά βοηθάει ή δεν αξίζει?
- Το player είναι συνδεδεμένο στο διαδίκτυο μέσω της σύνδεσης LAN (το σύνδεσα πρόσφατα). Έχει σχέση - και μήπως θα βοηθήσει - αυτή η σύνδεση, προκειμένου να επιτευχθεί η όποια πιθανή ενημέρωση λογισμικού, ή αυτό μπορεί να γίνει απλά μέσω ενός USB stick ή κάτι ανάλογο?
- Το οικιακό δίκτυο έχει πάνω του δυο-τρεις υπολογιστές, όλους με Windows 7 ή 8/8.1, καθώς και έναν Home Server (με WHS - τα πρώτα). Μερικές δεκάδες (για να μην πω περισσότερες) ταινίες είναι ήδη αποθηκευμένες σκόρπιες εδώ κι εκεί σε αυτούς τους υπολογιστές. Λειτουργικά, αυτό θα βοηθούσε στο να αναλάβει ο Dune το ρόλο του κέντρου αναπαραγωγής όλων αυτών των σκόρπιων ταινιών? Και αν ναι, πώς? Δεν ζητάω λεπτομέρειες, εννοώ αν μέσω του οικιακού δικτύου θα μπορεί ο Dune να τις "ρουφάει" από τους τόπους αποθήκευσής τους και να τις αναπαράγει, όπως θα αναπαρήγαγε οποιοδήποτε αρχείο που θα ήταν απ' ευθείας συνδεδεμένο με αυτόν (π.χ. μέσω USB ή SATA/e-SATA.
Για το δεύτερο (εσωτερικός δίσκος), θυμάμαι από την αρχή που συζητούσαμε ότι η εγκατάσταση δίσκου στο εσωτερικό της συσκευής απαιτούσε αυτό να γίνει από τους κατά τόπους αντιπροσώπους του κατασκευαστή, προκειμένου να μην επηρεαστεί η εγγύηση. Τώρα, μετά από 4+ χρόνια, φαντάζομαι ότι έτσι κι αλλιώς η εγγύηση του δικού μου έχει λήξει. Επομένως, συμπεραίνω ότι αυτό θα μπορούσε να γίνει και από μένα τον ίδιο. Τα λέω καλά μέχρις εδώ?
Επίσης, θυμάμαι ότι η κενή θέση στο εσωτερικό ήταν για δίσκο 2.5". Κάπου είδα όμως ότι κάποιος έχει τοποθετήσει δίσκο 3.5", χωρίς να αντιμετωπίσει ιδιαίτερα προβλήματα χώρου, απλά χρειάστηκε να κάνει κάποιες μικρές εσωτερικές παρεμβάσεις, προκειμένου να στηριχτεί καλά ο σκληρός των 3.5" και έβαλε και κάποιον έξτρα ανεμιστήρα. Αν κάπου μέσα εδώ - ακόμα και εδώ στο ίδιο το νήμα - υπάρχει σχετική αναφορά με πληροφορίες για την τοποθέτηση, θα εκτιμούσα μια παραπομπή, ώστε να τις μελετήσω για να ξέρω τί θα κάνω.
Αυτό που διάβασα για εγκατάσταση σκληρού 3.5" είναι στο παρακάτω link (Post # 30):
http://www.mpcclub.com/forum/showthread.php?t=24880&page=3
Ακόμα, αυτό που ήθελα να ρωτήσω είναι αν υπάρχει περιορισμός στη χωρητικότητα του εσωτερικού δίσκου ή αν δέχεται οποιαδήποτε χωρητικότητα. Ενθυμούμενος, αλλά και διαβάζοντας το manual της συσκευής, είδα ότι ο οποιοσδήποτε δίσκος, συνδεδεμένος με αυτήν εξωτερικά ή εσωτερικά, πρέπει να φορμαριστεί σε EXT2/EXT3 format. Έχω ήδη κατεβάσει την εφαρμογή Ext2Fsd-0.53.exe, προκειμένου να την χρησιμοποιήσω για το φορμάρισμα κάποιου δίσκου, αν χρειαστεί. Ωστόσο, θα ρωτήσω αν η ίδια η συσκευή φορμάρει ή όχι κάποιον δίσκο, αν εγκατασταθεί μέσα της και συνδεθεί.
Ακόμα, θα ρωτήσω κάτι σχετικά με τους περιορισμούς διαχείρισης των συνδεδεμένων δίσκων. Διάβασα ότι, εγκαθιστώντας εσωτερικό σκληρό δίσκο, ο χρήστης χάνει τη συνδεσιμότητα της θύρας e-SATA, για σύνδεση με εξωτερικό σκληρό (ή συστοιχία σκληρών) SATA. Λογικό ακούγεται, αλλά θα ήθελα να το επιβεβαιώσω. Ταυτόχρονα, θέλω να μάθω αν η θύρα USB εξακολουθεί να παραμένει ενεργή, προκειμένου να συνδεθεί κιt άλλος εξωτερικός σκληρός, παράλληλα με τον εσωτερικό SATA ή αντίστοιχα με κάποιον εξωτερικό e-SATA.
Τέλος, θα ήθελα μια γρήγορη συμβουλή για έναν σκληρό 2.5άρη, σε καλή τιμή και με αρκετή χωρητικότητα, αν δεν τελεσφορήσει η συνταγή εγκατάστασης σκληρού 3.5", που εκεί οι επιλογές είναι περισσότερες και σε καλύτερες ίσως τιμές.
Πολλές οι ερωτήσεις μου και οι απορίες, και μάλιστα για μια συσκευή που έχει αποσυρθεί(?) από την αγορά, αλλά αφού ξεκίνησα, ας το ολοκληρώσω.
Ευχαριστώ.
Εν τάχει:
  • Firmware update γίνεται μέσω internet από το ίδιο το Dune, στην καρτέλα setup.
  • Το Dune μπορεί να αναλάβει την αναπαραγωγή όλων των ταινιών που υπάρχουν στα pc του δικτύου, αρκεί να τους έχεις δώσει τα απαραίτητα δικαιώματα διαμοιρασμού. Οδηγός για το πώς γίνεται υπάρχει εδώ.
  • Δεν θυμάμαι μέγεθος και χωρητικότητα σκληρού. Ωστόσο καλό είναι το format να το αναλάβει το ίδιο το Dune.
  • Οι εξωτερικές usb παραμένουν ενεργές, όμως σε πολλούς εξωτερικούς υπάρχει πρόβλημα στην ανάγνωση λόγω μη επαρκούς τροφοδοσίας ρεύματος από τις usb του Dune. Καλό θα είναι να συνδεθούν εξωτερικοί σκληροί με δική τους τροφοδοσία.
Εν τάχει:
Χμμμ,,,, μάλιστα. Ίσως γι αυτό να μην μπόρεσε να "διαβάσει" τον WD Elements. Και δεν έχει δική του τροφοδοσία να τον δοκιμάσω. Ωστόσο, θα κάνω μια δοκιμή με έναν άλλο εξωτερικό της Verbatim, που έχει δική του τροφοδοσία και θα δω.
Τα παλιά μοντέλα Dune αναγνωρίζουν δίσκους μέχρι 2ΤΒ
Ευχαριστώ, Γιώργο.
Έχω βρει τους εξής:
Έναν σχετικά φτηνό Western Digital WD10JPVX Scorpio Blue στο 1 TB
Έναν ακριβότερο Western Digital, αλλά NAS (Raid) Red Edition, WD10JFCX, πάλι στο 1 TB
Και τέλος έναν αρκετά ακριβότερο, αλλά στα 2 TB, Toshiba Enterprise Edition MQ01ABB200
Πρόταση?
Και κάποιος green της wd είναι ότι πρέπει για streaming σε media player τόσο από usb,όσο και από δίκτυο.
Καλύτερα να αγοράσεις κάτι σε nas server που έχουν green power δισκους.
Καλημέρα κι ευχαριστώ. Μιλάς δηλαδή για κάτι σαν αυτόν:
Σωστά?
manos.papadopoulos
