"Vintage Decks & Amplifiers Club"
Τι να κανω με εσας που εχω μπλεξει.....Με οποιον δασκαλο καθησεις......
Θα περασω...ευχαριστωωω!
Οι δάσκαλοι διδάσκουν σε άλλα τμήματα...
Εδώ δεν κάνουμε μάθημα, αλλά την τρέλλα μας με καλή παρεούλα!:D
Ως γνωστόν είμαι λάτρης μιας εταιρίας και με έτρωγε ο κ*Wλος μου να συμπληρώσω την πρώτη Integra σειρά που έβγαλε το 1977, έτσι ώστε να ολοκληρώσω το πρώτο audiophile set….
Έτσι μετά από το U-30 passive selector και τον P-303 class-A προενισχυτή…
… ο Άη Βασίλης πέταξε από το έλκηθρο μαζί με τα δώρα των μικρών ηρώων μου και μια γνήσια συσκευασία!:D
"Onkyo T-909 (1978, $950)
A very rare FM-only tuner, the T-909 was one of the early digitals, coming out the year after the Luxman 5T50 and Sherwood Micro/CPU 100 made their debuts.
Although the T-909 is an attractive tuner, sounds very nice and is powerful - the rich bass and feeling of "reserve power" remind our panelist of a Yamaha CT-7000 or Kenwood L-0TII - the high list price was largely due to the new technology.
The T-909 has only one IF bandwidth, but adjacent channel selectivity is not bad (unlike the CT-7000's which is non-existent).
Tuning is in .2 kHz steps, by scanning with up/down pushbuttons, or with 7 presets.
The T-909 has a unique system of presets in which each station frequency is represented by a specific configuration of LEDs, and to program a frequency into memory one must slide little switches to the right to match the combination of LEDs that are lit under each preset button.
On the back panel are horizontal and vertical outputs for an oscilloscope, RCA outputs for a Dolby adaptor and a variable output level knob. On the front, behind a pop-out panel that also houses the preset system, are Dolby on/off, noise filter, stereo/mono and muting on/off.
The T-909 has the electronic equivalent of 5 gangs and a complicated filter scheme involving LC filters, one 4-pin ceramic and two 3-pin ceramics."
Πηγή: http://www.fmtunerinfo.com/onkyo.html
Αν και με τα σημερινά δεδομένα δεν αξιολογείται ως "killer" συσκευή στον ήχο, συγκρινόμενη με τους δέκτες αναφοράς, εν τούτοις το μηχάνημα πωλείται σε τιμές εξωφρενικές, λόγω της ιδιαίτερης σπανιότητάς του!:o
Εδώ πχ ένα πρόσφατο που πουλήθηκε με βλάβη…
http://www.ebay.com/itm/Onkyo-Model-T-909-Digital-Synthesized-FM-Tuner-For-repair-/281228238248
…κι εδώ ένα σε καλή κατάσταση με κάποια σημάδια όμως από "ελαφριές γρατζουνιές" σύμφωνα με την περιγραφή.
http://www.audio-extasa.eu/onkyo-integra-t909-fm-tuner-p-1326.html
George195
