PSI Audio AVAA C20
m1ts0s
News poster
AVAA is the solution for room mode problems between 15 – 120 Hz.
What does the AVAA do?
The AVAA is designed to absorb the standing modes between 15 and 120 Hz in a room. It will do so just like passive absorbers but in a much more efficient way and using up much less space. Each operating AVAA will have the same effect as a hole in the wall much larger than the dimensions of the AVAA (that is 0.2 m2). The exact ratio will depend on the frequency and environment but typically range between 5 and 20.
The AVAA will affect the impedance of the air and “suck” low frequencies around it.
Therefore the best position to place an AVAA is in the most rigid corners as that is where all room modes will be most present.
How does it work?
Note that this technology has several international patents pending.
A microphone will measure the acoustic pressure in front of an acoustic resistance.
The acoustic resistance is designed to let air through but reducing significantly the pressure.
A transducer membrane is driven to absorb the volume of air going through the acoustic resistance.
This significantly reduced the acoustic pressure (between 15 and 120 Hz) around the microphone and around the AVAA.
What does the AVAA not do?
The AVAA is a solution for room modes below 120 Hz and absorbs low frequencies only. The AVAA will not absorb frequencies above approximately 150 Hz. It is therefore not a total solution for acoustically bad rooms. For best results, it needs to be combined with passive absorption in higher frequencies.
What effect will the AVAA have in my room?
The AVAA will have the same effect, on frequencies from 15 to 120 Hz, as opening a window about 5 to 10 times the size of the AVAA. This will impact sound in the time, frequency and space dimensions.
  • Time: it will significantly reduce reverberation time in these frequencies especially on room modes.
  • Frequency: with more precise and tighter bass, the masking effect of higher frequencies is reduced. Details in higher frequencies also become clearer.
  • Space: with less indirect sound in the room, the location of the sound is more accurate making the sound image more precise.
How many AVAAs do I need?
An acoustician will be able to compute the effect of a certain number of AVAAs in a particular room.
Depending on the dimension and type of room as well as the result required, between 2 and 8 AVAAs are necessary. For very small rooms a minimum of two AVAAs is recommended to have a symmetrical effect. For most normal size rooms (between 20 and 80 m2) it is recommended to use 4 AVAAs and for larger rooms the number can be increased to 6 or 8.
Product Key Features
  • It is an efficient solution for room mode problems in low frequencies
  • It works independently from any source of sound and doesn't alter it
  • It is stable with no settings or measurements required
  • It can be used in recording room, control room, listening room or any room that has low frequency problems
  • It simply works like an acoustical element in the room
  • It can be turned ON and OFF to alter the acoustic environment
  • It can easily be moved into different rooms
  • It doesn't emit any sound
  • It has a small footprint and is a cost effective solution
  • It is 100% analog - no DSP, no latency
http://www.psiaudio.com/en/our-products/avaa-c20/
m1ts0s
News poster
Σε συζήτηση έκανε εμφάνιση ο Weiss:
"I hope to see developments which are not just incremental enhancements but true, "revolutionary" changes to old habits, like:
- Speaker technology with controlled directivity (DSP based, see the Kii speakers for a first glimpse).
- Active control of room acoustics (see below).
- Binaural playback via speakers (crosstalk canceling).
- Out of head localization for headphone playback.
- For the file based or streaming based playback: Tons of good metadata including the CD booklet we are used to.
- A decent compensation scheme for the musicians on streaming platforms. (This injects money into the struggling music industry again, which in turn results in (technically) better recordings I assume).
In another post in this thread the AVAA system for bass mode control was mentioned. This is a product of the PSI Audio company (I do not have any relation with that company). We recently had an AES (Audio Engineering Society) meeting at PSI Audio where that system was presented. I heard it in three different rooms so far and I must say that it works extremely well. This solves the bass mode problem without any acoustic treatments. There is a paper on the principles here:
http://infoscience.epfl.ch/record/20...a%20of%20a.pdf
Daniel"
dapost
Rehdeko & Harbeth lover
Πολλά τα λεφτά...ακόμη και για τους τετραγωνοδωμάτιους.
Από την άλλη σκέψου με 4 τέτοια να μπορείς να πετάξεις όλη τη σαβούρα που πρέπει αλλιώς να έχεις στο δωμάτιο για να έχεις λίγα μπάσα της προκοπής...
@Bhutia @dapost κάποιος απο σας τα είχε δοκιμάσει;
Έχει απαντηθεί στο παράλληλο Σύμπαν ...Έκτοτε αποτελεί σημείο αναφοράς για οποιαδήποτε εκδοχή setup...
Αν οι μετρήσεις πριν-μετά που βλέπω σε διάφορα setups αντικατοπτρίζουν την πραγματικότητα, πρέπει να αγοράσουμε όλοι 2 τεμάχια, ειδικά ο @Drioannis.
Φαίνεται να είναι καλή λύση, ειδικά για σαλόνια.
Αν σου πω ότι τα είχα σκεφτεί πριν κανένα μήνα...Το ποσό βέβαια είναι σοβαρό αν πας για την ποσότητα που πρέπει δηλ 4.
Καταρχάς και με δύο γίνεται δουλειά...Πλην όμως,δεν θα το χαρακτήριζα ιδανικό για σαλόνια...Οι όροι τοποθέτησης είναι εφάμιλλοι εκείνων για αυτόνομα sub,δηλαδή η βέλτιστη δράση επιτυγχάνεται με εγκατάσταση σε ειδικές θέσεις εξαρτώμενες από το χώρο και την τοποθεσία για τις κανονικές πηγές χαμηλών...Δεν λειτουργούν ιδανικά απλώς εγκαθιστώντας τις σε θέσεις που θα βόλευαν...Επίσης η απόσπαση περιττής ενέργειας από το χώρο προϋποθέτει την ύπαρξη αρκετής ενέργειας εκ των προτέρων,δηλαδή για να εξομαλύνουν την κρουστική αίσθηση πρέπει πρώτα να προέκυπτε τέτοια...
Όσο και να ικανοποιήθηκε η περιέργεια,στο τέλος της ημέρας ο χώρος στον οποίο ταίριαζαν αισθητικά (εκείνος με τα Triton και την πιο δύστροπη συμπεριφορά) είχε ήδη κατειλημμένες από άλλα πράγματα τις βέλτιστες θέσεις για εκείνες,ενώ στο δωμάτιο με τις κόρνες όπου βρίσκονταν διαθέσιμες θέσεις για βέλτιστη δράση δεν ταίριαζε η όλη αισθητική.Ακόμα χειρότερα,στο δωμάτιο με τα Vecteur ούτε η αισθητική συμφωνούσε ούτε ήταν διαθέσιμες οι απολύτως βέλτιστες θέσεις....Για μένα είναι πολύ ανώτερη διασκέδαση το παιγνίδι με πραγματικά sub,ιδίως εφόσον γίνεται να εξαγάγω spectro προσεγγίζοντα τη βέλτιστη δράση από το αντικείμενο του νήματος...απουσία αυτού:
dapost
Χωρίς να έχω να επιδείξω παρόμοια σπέκτρο για ...φίλημα, κατέληξα στα ίδια συμπεράσματα μετά από χρήση ενός bagend basstrap.
- Θέλει προσεκτική τοποθέτηση για βέλτιστη λειτουργία.
- Θέλει ικανό output χαμηλών εξαρχής ώστε να μένει χαρά και να μην ψάχνεις το χαμηλό.
- Εν τέλει, έχουμε καλομάθει με το dsp και τις φθηνές πλέον και πολλαπλές πηγές χαμηλών συχνοτήτων και μάλλον δεν μας είναι απαραίτητες τέτοιες συσκευές.
Για αναλογικά σεταπς όμως και για σεταπς που δεν μπορούν να διαχειριστούν πολλαπλά σαμπς, που είναι και τα περισσότερα μην πω σχεδόν όλα τα hifi, είναι πολύ καλή λύση.
Στη δική μου περίπτωση, η λογική που αγοράστηκε ήταν να παίξει το ρόλο του "double" στο single bass array που υπάρχει στο δωμάτιο. Δηλαδή να ακυρώνει την ιδιοσυχνότητα της "ελεύθερης" διάστασης του χώρου. Τελικά, προτιμήθηκε η κλασσική λύση ενός (μεγαλούτσικου είναι η αλήθεια 2 x 1.5 x 0.7m) αλλά πιο αποτελεσματικού εν τέλει bass absorber.
Εννοείται πως η επιλογή της θέσης τοποθέτησης τους γίνεται μετά από μετρήσεις στις γωνίες του δωματίου. Ουσιαστικά ψάχνουμε να βρούμε που "μαζεύεται" το μπάσο περισσότερο. Και μπορούμε να εντοπίσουμε και ποιες είναι οι καταστρεπτικές συχνότητες-modes και που μαζεύονται και αυτές.
Τα πλεονεκτήματα τους είναι πως είναι πιο μικρά από τα σαμπς, και έχουν σχήμα που ταιριάζει στις γωνίες. Επίσης δεν θέλουν πολύπλοκες ρυθμίσεις κατά @Bhutia , τα ανάβεις και λειτουργούν. Βάζεις και 2 σαμπς και είσαι κούκλος. Η τιμή των psi είναι πάνω κάτω όσο ενός μεγάλου σαμπ.
Η επιλογή των 4+ σαμπς σε σαλόνι γίνεται πολύ πιο δύσκολη, διότι χρειάζεται processor/minidsp για 4 σαμπς, δύσκολη τοποθέτηση των 4 σαμπς σε σημεία που η σύζυγος δεν συμφωνεί, και μεγάλη ταλαιπωρία (και γνώση) στην ισοστάθμιση.
Εγώ πάντως όταν βρω την όρεξη να ξανασχοληθώ με ισοστάθμιση συστήματος+ ολοκλήρωση των treatments (μάλλον το επόμενο δίσεκτο έτος :roflmao: ) θα ψωνίσω 2-3 τεμάχια, έχω κάποια φασικά προβλήματα χώρου που δεν παλεύονται.
Πάρε 2 και βλέπουμε.
:rolleyes:Eγω λεω τωρα εαν καποιος αγορασει το ποιο οικονομικο 8ιντσο σαμπ και ενα minidsp το ποιο οικονομικο και low,high cut btw 48/0ct δεν κανει δουλεια ;:whistling:
:rolleyes:
Εξαρτάται τι σημαίνει για τον καθένα "κάνει δουλειά".
:whistling:
roberto_portale
