Yamaha New 5000 Series
Mr Spock
demokratischer - sektor
GT-5000 TURNTABLE
The new GT-5000 Turntable draws inspiration and design characteristics from the acclaimed Yamaha GT (Gigantic and Tremendous) series and presents a new era of Hi-Fi from Yamaha. A custom belt-drive system with quartz timing minimizes the influence of the motor for an open, smooth sound. A short, straight tonearm made of carbon fiber and copper-plated aluminum delivers superior rigidity, weight balance and mechanics resulting in improved traceability.
C-5000 PRE-AMPLIFIER
The C-5000 Pre-Amplifier features fully balanced discrete circuits, with each channel resembling a mirror image of the other, allowing all signal transmission, power supply and ground connections to be minimized in a revolutionary way. Independent, dual toroidal transformers for the right and left channels deliver excellent channel separation and voltage stability. A patented design “floats” the phono EQ, input amp and line amp stages – removing the influence of ground noise from the signal.
M-5000 POWER AMPLIFIER
The M-5000 Power Amplifier features a patented floating and balanced amplifier design, which reduces the signal path as much as possible, minimizing energy loss and achieving lower impedance for high-fidelity performance. Unlike conventional power amplifier designs, the power supply of the M-5000 “floats” from the ground which removes undesirable impacts of minute voltage fluctuations or ground noise.
NS-5000 SPEAKERS
The NS-5000 Speakers are designed to reproduce sound in the purest and most realistic way. They incorporate tweeter, midrange and woofer diaphragms made of Zylon, a high-strength and lightweight synthetic fiber providing exceptional acoustic velocity and the ability to reproduce the most delicate details of audio without the sharp resonance peak inherent of harder materials.
Specifications
NS-5000
Type3 way Bookshelf Bass-reflex Type
Woofers30 cm (12") cone type
MidRange Driver8 cm (3-1/4") dome type
Tweeter3 cm (1-1/4") dome type
Frequency Response26 Hz-40 kHz (-10dB), -100 kHz (-30dB)
Nominal Input Power200 W
Maximum Input Power600 W
Sensitivity88 dB / 2.83 V/1 m
Crossover Frequencies750 Hz / 4.5 kHz
Impedance6 ohms (minimum 3.5 ohms)
Dimensions (W x H x D)395 x 690 x 381 cm; 15-1/2” x 27-1/8” x 15” (with speaker terminals)
Weight35.0 kg; 77.2 lbs. / unit
C-5000
Stereo Amplifier / Receiver
C-5000
Audio SpecificationsInput TerminalRCA:6 (PHONO, TUNER, CD, LINE 1, LINE 2 IN, EXT IN), BAL:4 (PHONO, BAL 1, BAL 2, EXT IN), TRIGGER IN: 1 (Slave mode), REMOTE IN:1
Output TerminalRCA:3 (LINE 2 OUT, LINE 1, LINE 2), BAL:1 (BAL), TRIGGER OUT: 2 (Master mode), REMOTE OUT:1
Rated Output Voltage[Input 200 mV, 20 Hz-20 kHz, 0.01% THD] (BAL BYPASS) 2 Vrms / 150 ohm, (BAL ATT) 1 Vrms / 150 ohm, (LINE 1 / LINE 2) 1 Vrms / 150 ohm), (LINE 2 RECOUT) 200 mVrms / 1.2 kohm
Maximum Output Voltage[1 kHz, 0.05% THD] (BAL) 6 Vrms, (LINE 1 / LINE 2) 3 Vrms, (LINE 2 RECOUT) 3Vrms
Input Sensitivity / Input Impedance[BAL / LINEOUT: 1 V] (BAL) 200 mVrms / 52 kohm, (LINE,etc) 200 mVrms / 47 kohm, [LINE 2 RECOUT, 150mV (1 kHz) ] (PHONO MC 300 ohms) 100 uVrms / 300 ohms, (PHONO MC 100 ohm) 100 uVrms / 100 ohms, (PHONO MC 30 ohm) 100 uVrms / 30 ohm, (PHONO MC 10 ohm) 100 uVrms / 10 ohm, (PHONO MM BAL(UNBAL)) 2.5 mVrms / 52 k(47 kohm), (EXT IN) 1 Vrms / 20 kohm
Maximum Input Signal Voltage[LINE2 REC (1kHz, 0.05% THD)] (BAL) 2.8 Vrms, (BAL ATT) 5.6 Vrms, (LINE,etc) 2.8 Vrms,(PHONO MC) 2 mVrms, (PHONO MM) 50 mVrms, [BAL/LINEOUT (1kHz 0.05% THD)](EXT IN) 5.6 Vrms
Frequency Response[JEITA, Load 22 kohm] (BAL/LINE, etc) +0 / -3 dB (10 Hz-100 kHz), +0 / -0.3 dB (20 Hz-20 kHz)
Total Harmonic Distortion Plus Noise[JEITA, Input: 0.5 V] 0.0100% (BAL [LINE, etc.] to BAL [LINE], 20 Hz-20 kHz), 0.0200% (MM / MC BAL [UNBAL] to LINE 2 RECOUT, 20 Hz-20 kHz)
Channnel Separation[JEITA, Input 1.0 kohm terminated, 1 kHz / 10 kHz] 110 dB or higher (BAL / LINE, etc.), 80 dB or higher (MC, BAL / UNBAL), 98 dB or higher (MM, BAL / UNBAL)
Function Separation[IHF-A network, Input 1.0 kohm terminated, JEITA] 110 dB or higher (BAL / LINE, etc.), 75 dB or higher (MC, BAL / UNBAL), 95 dB or higher (MM, BAL / UNBAL)
Signal-to-Noise Ratio[IHF-A network, Input 1.0 kohm terminated, JEITA] 110 dB or higher (BAL / LINE, etc.), 80 dB or higher (MC, 300 ohms, BAL / UNBAL), 98 dB or higher (MM, BAL / UNBAL)
Residual Noise[IHF-A network] 3 uV (BAL / LINE OUT)
Tone Control Characteristics(BASS) Boost / Cut [30 Hz] ±9 dB, Turnover Frequency 350 Hz, (TREBLE) Boost / Cut [20 Hz] ±9 dB, Turnover Frequency 3.5 kHz
Headphone Jack Rated Output Power35 mW + 35 mW (CD, etc. [1 kHz, 32 ohm, 0.2% THD])
Deviations from RIAA Equalizer±0.5 dB (MC / MM BAL [UNBAL])
Subsonic Filter15 Hz: -3 dB (MC / MM BAL [UNBAL])
GeneralPower Consumption60 W
Standby Power Consumption0.2 W
Power Management (Auto Power Standby)Yes
Dimension (W×H×D)435 x 142 x 451 mm; 17-1/8” x 5-5/8” x 17-3/4”
Weight19.1 kg; 42.11 lbs.
Post automatically merged:
M-5000
Audio SpecificationsInput TerminalRCA: 1, BAL: 1, TRIGGER IN: 1
Output TerminalTRIGGER OUT: 1
Rated Output Power100 W + 100 W (8 ohm, 20 Hz-20 kHz, 0.07% THD, 2-ch driven), 200 W + 200 W (4 ohm, 20 Hz-20 kHz, 0.07% THD, 2-ch driven), 400 W (8 ohm, 20 Hz-20 kHz, 0.07% THD, Monaural driven)
Dynamic Power Per Channel[IHF] 125 W + 125 W (8 ohm), 170 W + 170 W (6 ohm), 250 W + 250 W (4 ohm), 500 W + 500 W (2 ohm)
Dynamic Headroom0.97 dB (8 ohm)
Maximum Output Power220 W + 220 W (4 ohm, 1 kHz, 0.7% THD)
IEC Output Power125 W + 125 W (8 ohm, 1 kHz, 0.02% THD)
Maximum Effective Output Power[JEITA, 1kHz, 10% THD]135 W + 135 W (8 ohm), 270 W + 270 W (4 ohm)
Power Bandwidth10 Hz-50 kHz (8 ohm, 0.1% THD, 45 W)
Damping Factor300 or higher (8 ohm, 1 kHz)
Input Sensitivity / Input Impedance(BAL) 2.0 Vrms / 47 kohm, (LINE) 1.0 Vrms / 47 kohm [1 kHz 100 W / 8 ohm conversion]
Maximum Input Signal Voltage(BAL) 2.20 Vrms [1 kHz, 0.5% THD], (LINE) 1.10 Vrms [1 kHz, 0.5% THD]
Frequency Response+0 dB / -3 dB (5 Hz-100 kHz), +0 dB / -0.3 dB (20 Hz-20 kHz)
Total Harmonic Distortion Plus Noise2ch driven: 0.035% (LINE [BAL] to SP Out, 20 Hz-20 kHz, 50 W, 8 ohms), Monaural driven: 0.05% (LINE [BAL] to SP Out, 20 Hz-20 kHz, 200 W, 8 ohms)
Channnel Separation90 dB or higher (1 kHz, Input 1.0 kohm Terminated), 70 dB or higher (10 kHz, Input 1.0 kohm Terminated)
Signal-to-Noise Ratio[IHF-A network, Input 1 kohm shorted] 110 dB
Residual Noise[IHF-A network] (BAL) 40 uVrms, (LINE) 50 uVrms
Meter ClassThe 2.5th class
GeneralPower Consumption400 W
Standby Power ConsumptionOff Mode: 0.1 W, Standby Mode: 0.2 W
Maximum Power Consumption800 W
Dimension (W×H×D)435 x 180 x 464 mm; 17-1/8” x 7-1/8” x 18-1/4”
Weight26.9 kg; 59.3 lbs.
Είμαι πραγματικά περίεργος να δω πως θα εξελιχθεί αυτό το πόστ, αν και μεταξύ μας εμφανίστηκε σε στιγμή που υπάρχουν πιο ανταγωνιστικά :geek:
A
AKARL
GT-5000 TURNTABLE
NS-5000 SPEAKERS
NS-5000
Specifications
C-5000
C-5000
M-5000
Η αναγραφή τιμών στα προκλητικά ποστς είναι υποχρεωτική! :bigboss:
Mr Spock
GT-5000
Turntable
TurntableDrive MethodBelt drive
MotorAC synhronous motor
Motor DriveCrystal sine wave
Rotation Speed33-1/3 rpm, 45 rpm
Rotation Speed Variation±0.1%
Rotation Speed AdjustmentBuilt-in crystal osc. Adjustment Step: 0.1%, Adjustment Range: ±1.5%
Wow And Flutterless than 0.04%
Platter[Outer] Machined aluminium (Diameter 35 cm), [Inner] Brass (Diameter 14.3 cm),
TonearmTonearmStatic balance straight tonearm
Effective Arm Length223 mm
Overhang-17 mm
Acceptable Cartridge Weight13.5-36 g (including headshell) / (25-36 g need sub weight)
Attached CartridgeHead-shell Weight14 g (including screws, nuts and wires)
Audio SpecificationsOutput TerminalAnalogue Audio: 2 (XLR balance x 1, RCA unbalance x 1), Strobe: 1 (3.5 mm mini jack)
GeneralPower Consumption15 W
Dimension (W×H×D)546 x 221 x 411 mm; 21-1/2"x 8-3/4"x 16-1/8"
Weight26.5 kg; 58.4 lbs.
- όχι πριν ανιχνευθεί η street price ;)
Wizzy is right. Οι συγκρίσεις γίνονται με τις τιμές του τιμοκαταλόγου λιανικής.
Σίγουρα θα είναι αλμυρές οι τιμές τους. Αν θυμάμαι καλά τα ηχεία που παρουσιάστηκαν πέρυσι έχουν κάτι 5000e ή κάνω λάθος?
Εχω να πω και κάτι άλλο όμως . Την τοπολογία του προ και τελικού, με ,floating ground και balanced Line , phono, amps, τα έχει εφεύρει και υλοποιήσει πρώτη η SANSUI από το 1982, στα πρώτα a-xbalanced μηχανήματά της, Β2301, C2301, και μετά και στους ολοκληρωμένους AU-G90X και σε κάμποσα άλλα μηχανήματα μετά μαζί με
Την balanced τοπολογία με floating ground .Το ίδιο χρησιμοποιούσε και η ACCUPHASE.
H YAMAHA τώρα ξύπνησε? Τώρα το θυμήθηκε?
Είναι η καλύτερη σχεδίαση τοπολογικά , με τα περισσότερα πλεονεκτήματα all over, αλλά είναι ακριβή. Διότι όλα , τα πάντα όλα είναι διπλά. Από τροφοδοσία , από είσοδο-διαφορικό , από προενίσχυση ,από οδήγηση , από τελικά στάδια.
Τι διάολο ? ληγμένα παίρνουν?
12600 εχουν...το ζευγαρι ομως
Mr Spock
Θες να εξηγήσεις τους λόγους;
- ανάλογα με την τιμολογιακή πολιτική , υπάρχουν από μεγάλες έως και μη εκπτώσεις , μπορεί ο κατασκευαστής να έχει υψηλή αρχική τιμή για να κάνει εφέ σε κάποιους κύκλους που ζητάνε ακριβό προϊόν ( σνομπάροντας τα φτηνά ) , και μετά να την κατεβάζει
- οπότε η κατηγορία στην οποία συγκαταλέγεται το εν λόγω προϊόν βάσει ονομαστικής τιμής δεν ισχύει
- η grado sonata πχ με ονοματική τιμή 880 ευρώ , είχε street price 580 ευρώ που ήταν και πραγματική κατηγορία της . . . διότι εάν την βλέπαμε ως κατηγορία κοντά στο χιλιάρικο , τότε κοντά της ήταν η shelter πχ , από την οποία έτρωγε ξύλο . . . όλα αυτά πριν 10 χρόνια που αγόρασα την grado
Ναι, αλλά οι τιμολογιακές πολιτικές κάθε εταιρίας κι οι μεγάλες/μικρές εκπτώσεις δεν ενδιαφέρουν, για παράδειγμα, τον reviewer ο οποίος θα κάνει συγκριτικό test μεταξύ δέκα κεφαλών κάτω από €1000 ή γενικότερα, σε κάθε άλλη περίπτωση σύγκρισης προϊόντων. Οπότε, ο εκάστοτε αναγνώστης και τελικός καταναλωτής, λαμβάνει μια γενική εικόνα των αντίστοιχων προϊόντων σε συγκριμένη κατηγορία τιμής. Κάποια θα είναι καλύτερα, κάποια θα είναι χειρότερα, προφανώς.
Ο τελικός καταναλωτής ορίζει τον προϋπολογισμό του (=κατηγορία τιμής καταλόγου), κάνει την έρευνά του κι αποφασίζει αναλόγως. Εάν ο αντιπρόσωπος είναι κολλητός του και του πουλήσει το προϊόν με 50% έκπτωση επειδή έτσι θέλει, είναι άλλη ιστορία.
Mr Spock
- για αυτό τα συγκριτικά τεστ κάτω και κοντά στο χιλιαρικο έβγαζαν την grado τελευταία, λογικο αφού ανήκει στην κατηγορία πέριξ του πεντακοσαρικου
- λάθος κατ εμέ του reviewer να την εντάξει εκεί
H recommended power input για τα ηχεία ειναι 200W-600W και ο τελικός της ίδιας σειράς είναι 2Χ100W στα 8 Ohm..
Κάτι δε μου κολλάει ή κάτι καταλαβαίνω λάθος.
Mr Spock
- ο τελικός γίνεται 400 W (8 ohm, 20 Hz-20 kHz, 0.07% THD, Monaural driven) . . . οπότε μελλοντικά βάζεις άλλον ένα . . . όντως βάσει specs είναι λίγος
Mr Spock
Πολύ ωραίο νεοβιντάζ ηχοσύστημα.
Ο,τι πρέπει για βινύλιο.
- προσοχή , αλλοτριώνεσαι :) . . . εάν θές πες μας την άποψή σου στην ερώτηση του 1308
Είπε ο Τάκης.
Οι τσιπηδες παίρνουν ένα, για στάθμες ασανσέρ, κι οι άνετοι 2.
Και γιατί δε βγάζει εξ αρχής ένα μονομπλοκι των τετρακοσιωνε βαττ, να αγοράσουμε δύο από δαύτα ρε αδερφέ και να πουλήσουμε μούρη και εμείς οι χαιενταδες?? :tongue:
Σωτήρης Καλύμνιος
