Mr Spock
demokratischer - sektor
GT-5000 TURNTABLE
The new GT-5000 Turntable draws inspiration and design characteristics from the acclaimed Yamaha GT (Gigantic and Tremendous) series and presents a new era of Hi-Fi from Yamaha. A custom belt-drive system with quartz timing minimizes the influence of the motor for an open, smooth sound. A short, straight tonearm made of carbon fiber and copper-plated aluminum delivers superior rigidity, weight balance and mechanics resulting in improved traceability.
C-5000 PRE-AMPLIFIER
The C-5000 Pre-Amplifier features fully balanced discrete circuits, with each channel resembling a mirror image of the other, allowing all signal transmission, power supply and ground connections to be minimized in a revolutionary way. Independent, dual toroidal transformers for the right and left channels deliver excellent channel separation and voltage stability. A patented design “floats” the phono EQ, input amp and line amp stages – removing the influence of ground noise from the signal.
M-5000 POWER AMPLIFIER
The M-5000 Power Amplifier features a patented floating and balanced amplifier design, which reduces the signal path as much as possible, minimizing energy loss and achieving lower impedance for high-fidelity performance. Unlike conventional power amplifier designs, the power supply of the M-5000 “floats” from the ground which removes undesirable impacts of minute voltage fluctuations or ground noise.
NS-5000 SPEAKERS
The NS-5000 Speakers are designed to reproduce sound in the purest and most realistic way. They incorporate tweeter, midrange and woofer diaphragms made of Zylon, a high-strength and lightweight synthetic fiber providing exceptional acoustic velocity and the ability to reproduce the most delicate details of audio without the sharp resonance peak inherent of harder materials.
Yamaha Announces New 5000 Series
The following is a press release issued by Yamaha. Buena Park, California | October 23, 2019 - Yamaha is making the biggest statement in the Hi-Fi market
Specifications | |
NS-5000 | |
Type | 3 way Bookshelf Bass-reflex Type |
Woofers | 30 cm (12") cone type |
MidRange Driver | 8 cm (3-1/4") dome type |
Tweeter | 3 cm (1-1/4") dome type |
Frequency Response | 26 Hz-40 kHz (-10dB), -100 kHz (-30dB) |
Nominal Input Power | 200 W |
Maximum Input Power | 600 W |
Sensitivity | 88 dB / 2.83 V/1 m |
Crossover Frequencies | 750 Hz / 4.5 kHz |
Impedance | 6 ohms (minimum 3.5 ohms) |
Dimensions (W x H x D) | 395 x 690 x 381 cm; 15-1/2” x 27-1/8” x 15” (with speaker terminals) |
Weight | 35.0 kg; 77.2 lbs. / unit |
C-5000 |
Stereo Amplifier / Receiver | ||
C-5000 |
