Projectors χωρίς λάμπες...
κι αλλο ενα αρθρο
New DLP Home Theater Projectors Use LEDs
Melissa J. Perenson, PC World
Wednesday, June 18, 2008 12:20 PM PDT
LAS VEGAS -- Texas Instruments today announced a new technology that could dramatically change the perception and appeal of front projectors. Its new Brilliant Color DLP chipset works with a PhlatLight Light Emitting Diode (LED) light source to produce images.
Traditionally, DLP projectors relied on a color wheel and mirror design, which would produce color images in conjunction with a lamp light source. Competing projector technologies 3LCD, which uses red, green, and blue LCD panels, and LCOS both require a lamp as well.
Texas Instruments' design is the first full-size LED projector to be shown. But the idea of using LEDs as a light source for displays is not a new one. A handful of pocket-size projectors have used LEDs as a light source, including Toshiba's TDP-FF1AU, the Mitsubishi PocketProjector, and models from Samsung and Boxlight. Both ViewSonic and 3M have shown prototypes, as well. And LCD television and monitors have begun using LED-backlighting in the past year and a half.
No Lamp, No Fuss
Roger Carver, manager of DLP Front Projection at Texas Instruments, calls the new design a major innovation "that will be a breakthrough for the industry. It will change the face of consumer projectors," he says.
That statement may not just be hype: Lamps, which can often cost around $300 to $500, and filters are a big chunk of the total cost of a projector over its lifetime. By not requiring a lamp, these projectors will eliminate the kid-glove treatment (being careful of the lamp, making sure the lamp has sufficiently cooled before powering off the projector) needed by current models.
By contrast, the new DLP technology is "maintenance-free: There's no lamp replacement, no filter replacement. The LEDs last the entire life of the projector," Carver says. "This will enable greater penetration of projectors for consumers."
Now that Texas Instruments has cracked the secret of how to use LEDs as a light source, the company says that DLP technology is "uniquely positioned" to take advantage of LEDs.
"Other technologies, like LCD, requires you to use polarizing filter that throws away half of the light generated by the light source," Carter says. "But it's important to use all of the light, to maximize the brightness for consumer applications. With LEDs, DLP can use all of the light offered, because the technology doesn't need a polarizing filter."
Instead, red, green, and blue LEDs pulse really fast, which eliminates the need for a color wheel.
The LEDs have other benefits as well. An LED-based projector consumes less power than a lamp-based model; and the projector runs cooler, too. That in turn means an LED projector is quieter than a lamp-based projector, since manufacturers won't need to place fans inside to cool down the lamp.
Carter says the lamp-free design of the DLP chipset and LED light source will enable projector manufacturers to produce models that are the same size, or even smaller, than current models
More Colorful, Too
Another benefit for the new LED-based DLP technology: It extends the color gamut beyond traditional lamp projectors, just as the technology does with LED-backlit LCD televisions and monitors.
"The light spectrum of a lamp is limited compared with LEDs," explains Carver. "LEDs have a larger light spectrum, which in turn enables a wider color gamut." Texas Instruments says you get 50 percent more colors with LEDs than with a standard lamp projector.
Again, the company says its technology is well-matched with the LED technology. LEDs have a fast switching speed--they can switch in microseconds, notes Carver. "The DLP chipset's mirrors can match that switching speed. You can pulse the LEDs and pulse the mirrors to get the right colors on the screen," Carver says. "It's the best use of the available light."
Products Coming This Year
Currently, TI is aiming its new LED design to transform the home theater projector market. The prototype, on display as a technology demo at the InfoComm trade show here in Las Vegas, is between 500 and 1000 lumens range, Carver says. That's the sweet spot for home theater projectors, which is why Texas Instruments chose to focus on home theater projectors first. However, business projectors need to be brighter -- from 1500 to 3000 lumens -- because they're often used in ambient light environments.
The company says it expects its partners to release the first LED-based home theater projectors by the end of 2008. However, the technology will come to corporate and education projectors soon, and with sufficient lumens to serve those markets.
"This has the potential to be a game changer for corporate and education markets," adds Carver. He expects the lumen range to grow over the next year or so, and that products will be available by end of next year.
οπως βλεπετε πιο πανω η TI ισχυριζεται οτι τα DLP εχουν πλεονεκτημα ως προς τα LCD στη χρηση led διοτι δεν χρησιμοποιουν φιλτρα.
ισως γι'αυτο προχωρουν σε κατασκευη τετοιου προβολεα.
NIX
Απάντηση: Projectors χωρίς λάμπες...
Πρωτον στην απορια του Παναγιωτη ως το πως θα μας τα παιρνουν αφου δεν θα πουλανε πια λαμπες,η απαντηση βρισκεται στο πιο πανω κειμενο που παρεθεσε ο Δημητρης.
Θα πουλανε δηλαδη πιο πολλους προβολεις.
Οταν θα εχεις ενα κουτακι που δεν θα θελει καμια συντηρηση,θα ειναι υπερφορητο,θα καταναλωνει ελαχιστο ρευμα και θα μπορει να παραγει εικονα 100" ολοι θα θελουν ν`αγορασουν ενα.Αλλος για το σαλονι,αλλος για το εξοχικο,αλλος για το παιδικο,αλλος για τη κρεβατοκαμαρα κ.λ.π.
Θα φερει τους προβολεις στην μεγαλη μαζα με πολυ μεγαλυτερα κερδη απο τις πενιχρες πωλησεις λαμπων.(ποσοι νομιζετε οτι αγοραζουν λαμπα?)
Επισης στο ως ανω κειμενο επιβεβαιώνεται αυτο που ελεγα για την αποδοτικοτερη χρηση του φωτος απο τους DLP.
Οποιος θελει να θυμηθει... http://www.avsite.gr/vb/showthread.php?t=49149&highlight=%F0%E9%E8%E7%EA%E1%ED%E8%F1%F9%F0%EF%F2
Μακαρι να γινουν γρηγορα ΟΛΑ αυτα και να κυκλοφορησουν στην παραγωγη τα πρωτα μοντελα, και να μην περιμενουμε 2-3 χρονια μεχρι να δουμε φως ομως...
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Εγώ π.χ. δεν αγόρασα μέχρι σήμερα ούτε μία. Άλλαξα μία δωρεάν στον επσον τον 600άρη.
Re: Απάντηση: Projectors χωρίς λάμπες...
Ε πως να προλαβεις να αλλαξεις λαμπα αφου οι προβολεις σου διαρκουν οσο οι πανσετες στο πιατο σου :142:
πολυ περιεργο ολο το σκηνικο γυρω απο την επιδειξη της TI στην ιnfocomm.Κανενας απολυτως δεν ειδε αυτη την επιδειξη απο το αμερικανικο φορουμ και δεν μπορω να βρω πουθενα καμμια αναφορα δημοσιογραφου που να ειδε την επιδειξη.:415:Για τετοια επαναστατικη ειδηση πολυ μυστηριο και σκοταδι επικρατει!!!!!!!!!!!!!
Απάντηση: Re: Απάντηση: Projectors χωρίς λάμπες...
Ολα τα καλα τελειωνουν γρηγορα:114:
MAD
Σιαρτάκιας
Εδώ πάει η παροιμία που λέει (ρίχνουν άδεια να πιάσουν γεμάτα!) βολιδοσκοπούν την αγορά πιθανόν!
NIX
Θα ηταν αδεια μονο εαν δεν υπηρχαν τα Phlatlight Led σε παραγωγη αλλα εφοσον υπαρχουν ως εμπορικο προΐον δεν ισχυει αυτο που γραφεις.
Η Samsung εχει DLP προβολικη τηλεοραση με Phlatlight Led εδω και περιπου ενα χρονο.
Samsung's 2007 Slim LED DLP sets are PhlatLight powered
Video Imaging DesignLine
(04/24/2007 4:38 PM EDT)
Woburn, Massachusetts -- Luminus Devices, Inc. has announced that Samsung Electronics Co., Ltd. has begun shipping its new line of Slim Depth LED Engine Widescreen DLP HDTVs with 1080p resolution, featuring Luminus' patented PhlatLight LED technology. The six new models use Luminus' high-powered, energy-efficient LED illumination in place of a UHP or arc lamp, the traditional light source found in most projection TVs. Samsung's new LED-based Slim DLP HDTVs are on store shelves now at national retailers including, Best Buy, Circuit City, Sears, and Tweeter.
http://www.videsignline.com/products/199201206
Στο αμερικανικο site της samsung εχει δυο μοντελα 61" και 67" με Phlatlight Led.
http://www.samsung.com/us/consumer/...up=televisions&type=televisions&subtype=dlptv
Luminus Devices to Exhibit PhlatLight LED Products During SID 2008
Mon May 19, 2008 11:32am EDT
LOS ANGELES--(Business Wire)--
Luminus Devices, Inc., the developer and manufacturer of
PhlatLight(R) (Photonic Lattice) LED products for a wide variety of
display and illumination applications, today announced that it will
demonstrate a variety of PhlatLight powered products and a full line
of PhlatLight LED chipsets and support components at this week's SID
2008 (Society of Information Display) 2008 taking place from May
20-22, 2008 in Los Angeles, Calif.
"Luminus continues to expand into new product categories and
applications where solid-state RGB illumination is desirable and
PhlatLight LEDs unique brightness, reliability, and performance,
enable manufacturers to develop innovative new product designs." said
Christian Hoepfner, vice president, products. "Products developed with
PhlatLight LEDs offer superior image performance and new attractive
form factors due to the compact size and the elimination of the need
to replace the light source."
Luminus will highlight the following:
Luminus will demonstrate its award winning PhlatLight Back-Light
Unit (BLU) in a 46" LCD TV illuminated with only eight light modules,
each containing a single red, green and blue PhlatLight LED. The
unique high brightness and collimated light output of PhlatLight LEDs
requires only a few PhlatLight RGB modules to illuminate light guides,
creating uniform diffuse white light with a wider color gamut than
CCFL or white LED backlights. This dramatically reduces parts count,
complexity and cost while improving long-term uniformity for large
screen LCD TVs compared to direct LED backlights with arrays of
thousands of conventional LEDs. The PhlatLight LEDs illuminate
MicroLens(TM) light guides, manufactured by Luminus partner Global
Lighting Technology, enabling thinner designs. The 46" TV demonstrated
by Luminus is from partner company Jabil Circuit, a leading BLU and TV
designer and manufacturer. The PhlatLight BLU has been awarded this
year's highest display industry honor from SID for winning the 2008
Display Component of the Year Gold Award.
Luminus will demonstrate a home theater front projector prototype
powered by a single PhlatLight PT120 chipset. The latest generation of
PhlatLight LEDs have achieved a dramatic increase in brightness,
enabling home theater projectors to be designed that produce more than
750 ANSI lumens. This level of brightness, never before generated by
an LED chipset, will enable such applications as LED based home cinema
projectors and business projectors. These projectors will have the
other benefits of LED technology, including instant-on operation, high
contrast ratios, long lifetimes and wide color gamut. In addition,
unlike the arc-lamps that PhlatLight LEDs replace, they do not contain
any mercury.
Luminus will highlight their continued expansion into portable
pocket projectors, demonstrating two new models, the HS102 from LG
Electronics and the SP-P400 from Samsung Electronics. These projectors
use the new PhlatLight PT54 RGB chipset, enabling brightness to
increase to 150 lumens and higher, enabling faster growth and wider
acceptance of this new projection category.
Luminus' suite will also feature Samsung's newest PhlatLight LED
powered DLP television, the HL67A750. This 67" model is the largest
LED-illuminated rear projection TV ever produced. Unlike the mercury
arc-lamp and color wheel, used in earlier models, the PhlatLight
chipset never has to be replaced.
Luminus will be conducting demonstrations of its revolutionary
technology in a private suite at the Sheraton Downtown LA, located at
711 South Hope Street, Los Angeles, Calif. in room 2408, approximately
one mile from the Los Angeles Convention Center. Anyone interested in
scheduling an appointment should contact Bill Keeler or Nicole Slein
at (781) 684-0770 for more information.
About Luminus Devices
Luminus Devices, Inc. develops and manufactures high performance
solid state light sources for a variety of illumination applications,
including high definition TVs, video projectors, avionics displays,
and lighting systems. Its patented PhlatLight(R) (Photonic Lattice)
LED products are the brightest and most versatile solid-state light
sources available today and are enabling innovative products and
applications never before possible. Luminus Devices' headquarters and
primary manufacturing facilities are located in Billerica,
Massachusetts, U.S.A. For more information, visit www.luminus.com and
www.phlatlight.com.
Note to editors: PhlatLight is a registered trademark of Luminus
Devices.
Schwartz Communications
Bill Keeler or Nicole Slein, 781 684-0770
[email protected]
Copyright Business Wire 2008
τα γεγονοτα ειναι χιονοστιβαδα.Ο εμπορος Αλαν και ιδιοκτητης του αμερικανικου Φορουμ,γραφει οτι στη cedia
θα υπαρχει προβολεας LED με 1100λουμενς!!!!!!!!!!!!!!Δεν αποκαλυπτει προς το παρον το ονομα της εταιριας........
απ'οτι φαινεται ,τεχνικα το θεμα εχει λυθει,δηλαδη να δωσουν αρκετο φως τα LED,αλλα μεχρι να γινουν ολα αυτα υλοποιηση σε προβολεις και ναναι εμπορικη πραγματικοτητα μαλλον θα παρει κανενα χρονο ακομα.Εξαρταται βεβαιατι ανταποκριση θα εχουν τα πρωτα πρωτοτυπα που θα βγουν.
loggeo
Και φυσικά ποιά θα είναι τα standards τιμών στις αρχές για projectors τέτοιας τεχνολογίας.
Απάντηση: Re: Projectors χωρίς λάμπες...
Ενας χρόνος είναι πολύ μικρο χρονικό διάστημα και θα ηταν ευτυχές εργο αν γινόταν κατι τετοιο τόσο γρήγορα…
Πάντως όπως γράφω και στο πρώτο μου μήνυμα σε αυτό το τοπικ , καλο είναι πρωτα να δούμε με τα ματια μας τι σοι φως θα βγάζουν αυτά τα led και μετα πανηγυρίζουμε…
Προς το παρόν εχουμε μια παρουσίαση μιας νεας τεχνολογίας που ωστόσο καμια κατασκευάστρια εταιρία προβολικών δεν εχει ανακοινώσει την πρόθεση της να προχωρήσει σε υιοθέτηση αυτής της πατέντας…
<o:p> </o:p>
Re: Όπου ακούς πολλά αβγά...
<?xml:namespace prefix = o /><o:p></o:p>
Θα συμφωνήσω με τον Αντρέα, εξακολουθώ να "κρατάω μικρό καλάθι", μέχρι τουλάχιστον να δούμε τα πρώτα πρωτότυπα και να αντιληφτούμε επακριβώς τι παίζει με τη νέα τεχνολογία... :121:
Re: Απάντηση: Re: Projectors χωρίς λάμπες...
<o:p> </o:p>
ενας χρονος στους προβολεις δεν ειναι καθολου λιγο.Λογικα η κατασταση λεει οτι θα βγουν καποια πρωτοτυπα αυτο το φθινοπωρο,μερικα θα παρουσιαστουν στην CEdia το Σεπτεμβριο,αλλα μαλλον και αργοτερα προς το χειμωνα.Αν ολα πανε καλα,τα πρωτα εμπορικα μοντελα πρεπει να βγουν την ανοιξη του 2009 με καλυτερες πιθανοτητες το φθινοπωρο του 2009.Βεβαια εξαρταται και τι ανταποκριση θα εχουν απο το κοινο αυτα τα πρωτοτυπα.Αν οι εταιριες δουν μεγαλο ενδιαφερον θα σκιστουν να τα βγαλουν.Δεδομενου οτι δεν εχει δει κανεις πρακτικα την τεχνολογια αυτη σε δραση ακομα,μπορει να ξεφουσκωσει ολη η υποθεση.
DAMBO
