Η Oppo στην Ελλάδα
Κανενα Ευρωπαικο νεο ακομα.
Προς το παρον εχουμε μερικα απο τα τεχνικα χαρακρηριστικα :
Video Specifications
  • Analog Video: Composite, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content; up to 1080i Blu-ray)
  • Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)
  • ABT2010 de-interlacing and scaling solution (HDMI only)
  • 30 and 36bit Deep Color support
Audio Specifications
  • Analog Audio: 7.1ch or 5.1ch, Dedicated Stereo.
  • D/AC: Two-channel Cirrus CS4398 DAC for Discrete Stereo; Eight-channel CS4382A DAC for Multi-Channel Analog.
  • Digital Audio: Coaxial, Optical
  • HDMI Audio: Stereo to 7.1ch.
  • Bit stream and internal decoding of Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio for HDMI and Analog.
  • SACD DSD bit stream over HDMI or straight to analog; SACD DSD to PCM conversion over HDMI.
Media Compatibility
  • Disc Types: BD-Video, DVD-Video, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
    (Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used.)
  • BD Profile: BD-ROM version 2 Profile 2 (also compatible with Profile 1 version 1.0 and 1.1). 1GB of Internal Storage; External Storage expandable through USB.
  • Dual USB Ports (One in back; one front) for video, audio, picture, and BD-Live expandability.
Unique or Optimized Features
  • PS3 caliber load speeds for BD-Java enabled discs.
  • Resolution, Picture and Audio adjustments can be performed on the fly.
  • Discrete Output Resolution: You can force the player to always output a 480i/p, 720p, 1080i and 1080p 50/60Hz, and 1080p/24Hz (DVD-Video and Blu-ray) video signal.
  • Source Direct: This allows the player to intelligently and automatically change the video output resolution of the player based off of the content source. For example, SD DVD will playback at 480i, Blu-ray will play back at 1080p/24Hz, and DVD-Audio and SACD will playback at 1080i (to ensure maximum audio bandwidth is available). This is ideal for people who use external scalers or do not want the BDP-83 to do any video de-interlacing and scaling.
  • Video Demo Mode: Splits the screen vertically with one half showing the original source image, while the other half shows the results of adjustment to the Edge Enhancement, Detail Enhancement and Noise Reduction controls.
  • Up to 1920x1080 native MPEG-2, AVCHD, MKV and DivX/XviD video support; JPEG and PNG picture support.
  • Fully back-lit remote control
  • Anamorphic lens compatible with constant height Zoom. Other Zoom modes identical to DV-983H
General Specifications
  • Power Supply: Power Supply: ~ 100V – 240V, 50/60Hz AC
  • Power Consumption: 35W (0.5W Standby)
  • Dimensions: 430mm x 336mm x 77mm, 16⅞ x 13¼ x 3 inches
  • Mass: 5.1kg / 11.2 lbs
The Early Adoption Program BDP-83 Blu-ray Lacks
  • Decoding of DVD-Audio. Will be updated through future firmware
Επισης τα παρακατω ειναι τα ζητουμενα προσεχως :
Feature Requests
  • APE, FLAC, and WAV lossless; WMA and AAC lossy audio support.
  • Adjustable Crossover. The crossover is either an all-or-nothing 80Hz. We would like to see 40 to 120Hz crossover support.
  • Audio Delay over analog. Audio Delay is currently only available over HDMI. There is concern that analog users will experience down stream video delays which will cause audio/video synchronization errors.
  • Audio Bit Rate and Frequency information. Current implementation only shows Audio Track selected. Having bit rate and frequency information will help determine if we are getting lossless or lossy audio when the BDP-83 is decoding Dolby Digital TrueHD and DTS-HD Master.
  • Internal Test Tones for properly calibrating analog audio outputs as well as testing proper audio output.
  • User Presets. User Presets would allow for multiple changes to the player with a single selection. Saves time adjusting individual sliders to meet specific feature requirements.
Επισης αυτο που ακομα δεν ξερουμε ειναι τι chipset φοραει. Το σπουδαιοτερο απ ολα.
Στις φωτο το βλεπετε ( δεν το βλεπετε ) κατω απο τη ψυκτρα.
ΑΑΑΑΑΑΑΑΑΑ......δε παιζω....
Διαβαστε αυτο :
No we are on a totally different firmware.
Our firmware does not have all of the glitches that some EAP users are reporting. All DVDA discs play perfectly. FLAC and WMV-HD are fully supported as well as region free playback. HD DVDs look AWESOME on the beta test units as well. Did I mention Netflix streaming and built in wi-fi?... ya, that too. Hopfully OPPO will someday give the general public the same features we have.
Απο εδω....
Αυτα ειναι τα λογια ενος απο τους Beta-testers της Oppo.
Προσθεσαν AAC, DVD-Audio στο νεο firmware που κυκλοφορησε, αλλα FLAC, WMV-HD και region-free καθως επισης και το πιο κουφο....HD-DVD.....ποσα θελουν να μας κουφανουν.
Ελπιζω οπως λεει και ο smarty-pants να τα δουμε ολα αυτα μεσα στο player οταν κυκλοφορησει.
Τα νεοτερα που δεν ξερετε ειναι :
Στην Αμερικη κυκλοφορει ( μεχρι νεοτερας ) στα μεσα Απριλιου.
Η Ευρωπη δηλωσε ( τρομαρα τους ) ενα μηνα μετα.....οταν ειπα ζησε Μαη μου......
Το δευτερο που δεν το εχει ανακοινωσει κανενας ειναι το chipset που εχει το BDP-83 : προκειται για το νεο Mediatek MT-8520.
Ακομα μια φορα η MTK εκανε το θαυμα της.
Γιαυτο εχουμε αυτες τις διαφορες στη ταχυτητα επεξεργασιας και την ποιοτητα ηχου και εικονας.
Και το καλυτερο απ ολα , που αφορα εμας , ειναι οτι σε λιγο καιρο καποιος θα βγαλει και το region-free code, αλλα και την υποστηριξη των Ελληνικων, αν δε μας κανουν τη χαρη να τη βαλουν αυτοι.
Τιμη δεν εχει ανακοινωθει ακομα.
Mediatek’s HD AV experience: You don’t just see it, you LIVE it!
Say goodbye to standard definition video. The MT8520 powered Blu-ray ™ Player provides full 1080p resolution for perfect viewing enjoyment. In addition, the MT8520 powered Blu-ray ™ Player is equipped with up to 7.1 channels of HD surround sound. Out of this world.
Play Any Disc, Any Time.
The MT8520 supports playback for almost every optical disc, including Blu-ray disc, DVD, VCD, and CD-DA. Born from MediaTek’s proven technologies, it offers the world’s best and most reliable playability of DVD SoC – MT1389 series.
Features
● Dual-channel HD MPEG-2/AVC/VC-1 video decoder
● Dual-channel multi-format HD audio decoder
● Motion-adaptive, edge-perserving de-interlace
● Integrated HDMI 1.3 transmitter
● USB 2.0
● 148MHz/12-BIT, 6 CH TV encoder
● BD-Live and on-line applications
Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Ανυπομονώ να δω τεστ σε ελληνικό έδαφος.
Το 2 EAP group είναι ενθουσιασμένο με το player.
Αποστόλη κανόνισε να μας φτιάξουν τα ελληνικά για mkv, και να μαστε απο τους πρώτους που θα παραλάβουν στην Ευρώπη.
Re: Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Για τα Ελληνικα τους το εχω πει και ευχομαι να μας ικανοποιησουν.
Το οτι θα ειμαστε οι πρωτοι που θα παραλαβουμε αυτο ειναι σιγουρο.
Μολις εχω τιμη και ημερομηνια θα σας ενημερωσω, γιατι ειναι πολυ πιθανο να χρειαστει να δεσμευσουμε μηχανηματα, οποτε θα δουλεψει pre-order. Λιγο υπομονη.....
Οι 300 του 2ου ΕΑΡ , εχουν βρει μερικα ακομα bugs, αλλα αυτο ειναι καλο, για να μη τα φαμε εμεις στα player παραγωγης.
Αυτη τη στιγμη ειμαστε στο firmware No16....το ψαχνουν για τα καλα το θεμα...
Το Ultimate AV Magazine, εκανε το πρωτο ''εμεσο'' τεστ του BDP-83, με το review του Quantum of Solace :
The AVC encode looks outstanding with razor-sharp detail, excellent contrast, and rich color palette. Depending on the locale, the cinematography changes to fit the surroundings. In Italy, the inviting countryside features deep greens and blues with relatively obscured film grain. Yet when Bond travels to Haiti, grain is more prevalent, contrast is heightened, and the color palette is more subdued. My only complaint is some minor instances of moiré in what's otherwise a nearly perfect presentation.
The DTS-HD MA 5.1 soundtrack is amazing and hits you right in the chest from the opening scene with deep, impactful LFE and a constant bombardment of discrete effects from every speaker. Dialog takes a backseat to the action in the screenplay, but it is always intelligible and easily understood, and the dynamics are first-rate in one of the best live-action tracks of the year.
Source
Oppo BDP-83 Blu-ray player
http://www.ultimateavmag.com/moviereviews/032609quantum/
Απόστολε κανα καλο ΠΑΣΧΑΛΙΑΤΙΚΟ νεο δεν μας εχεις.. ακομα ..?? :137:
Οπως εχω πει και πριν....ζησε Μαη μου....
Η κυκλοφορια του στην Ευρωπη αναμενεται ενα μηνα μετα την κυκλοφορια στην Αμερικη.
Το νου σας στη σουβλα προς το παρον.....:116:
Νεοτερα απο το μετωπο :
- Το DVD Audio ειναι πλεον και επισημο.
- Το chip set ειναι οντως το Mediatek MT8520, ειδικα κατασκευασμενο για την Oppo με κωδ. OP8521G
Δειτε το στη φωτο.
Στο πανω μερος της φωτο στο κεντρο, βλεπετε ενα SATA port.
Αυτο ειναι για το blu-ray drive.
Αλλες φωτο εδω....
Στις επομενες ημερες πιστευω οτι θα εχουμε και την επισημη ανακοινωση για την Αμερικη.
Αντε να δουμε ... γιατι εχουμε παρει υπνον βαθυ περιμενοντας...:103:...
Πάντως διαβαζα προσφατα οτι οι Ελληνες Βιντεοκλαμπαδες σαμποταρουν την πορεια του BR
στην Ελληνικη αγορά... ποιος ξερει γιατι... :134:.. ισως φοβουνται οτι δεν θα κερδιζουν πολλα..??
ισως οτι το BR-disk ειναι πιο ευαισθητο απο το DVD-disk....
Ακομα το ρημαδι?
Στην Αγγλια πωλειται ηδη, περιοχης Α ομως.
Ακομα το ρημαδι?
Δημητρη,
Δεν πωλειται ακομα. Απλα δεχονται pre-orders.
Ακομα δεν εχει κυκλοφορησει ουτε στην Αμερικη, περαν των 50+300 τεμ. για το Early Adoption Program.
Στην Ευρωπη θα κυκλοφορησει ενα μηνα μετα την Αμερικη.
Οταν θα εχω ημερομηνια και τιμη, θα εχουμε pre-order και στην Ελλαδα.
Πηγαινε στο εγγλεζικο avforums να δεις που ξεκινησαν να γραφουν εντυπωσεις...:121:
Δημητρη λες να μην θελει να πουλησει ο Απόστολος..??...:121:
Αλλα οι Αμερικανοι... κανουν το προγραμμα που αυτοι θελουν...
Τι να σου πει ο Αποστολος...? αν δεν εχει απο αυτους ανταποκριση..?
Αυτα ειναι τα νεα :
Hello Apostolos,
No fresh updates on European blu-ray player. I will keep you updated.
The unit sold in UK is american region A
Greek subtitles: waiting for reply from engineers.
To ξερω οτι δεν κυκλοφορει ακομα περιοχης Β, απλα ηθελα να δω εαν υπαρχουν τιποτα νεα. Δεν ειχα σκοπο να 'τσιγκλισω' τον Αποστολη βρε συ...
Το τελευταιο HITECH το ειχε φατσα καρτα το 83 σαν το πρωτο Universal BD-Player στα ~500 $
.... αντε να δουμε ποτε θα αποφασισουν οι Αμερικανοι να ξεκινησουν την παραγωγη...:140:
Ας πεί κάποιος ρε παιδιά στο Κο. Κατσενή και στο HITECH, ότι υπάρχει επίσημη αντιπροσωπεία στην Ελλάδα της OPPO και ότι μπορούμε να το προμηθευτούμε και από εδώ.
Αν δε το ήξερε:121:, να αλλάξει κατηγορία ή επάγγελμα.
ΑΠΑΡΑΔΕΚΤΟ !!!
Δηλαδή οι Αμερικάνοι είναι κατασκευαστές των OPPO;
Ενδιαφέρον!
:616:
Η Oppo ειναι Αμερικανικη εταιρεια που σχεδιαζει και κατασκευαζει τα προιοντα της και οπως σχεδον ολοι πλεον, τα συναρμολογει στο Hong Kong.
Τα player της Oppo δεν γραφουν made in China αλλα assembled in China.
takis-g
