Κανενα Ευρωπαικο νεο ακομα.
Προς το παρον εχουμε μερικα απο τα τεχνικα χαρακρηριστικα :
Video Specifications
Feature Requests
Επισης αυτο που ακομα δεν ξερουμε ειναι τι chipset φοραει. Το σπουδαιοτερο απ ολα.
Στις φωτο το βλεπετε ( δεν το βλεπετε ) κατω απο τη ψυκτρα.
- Analog Video: Composite, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content; up to 1080i Blu-ray)
- Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)
- ABT2010 de-interlacing and scaling solution (HDMI only)
- 30 and 36bit Deep Color support
- Analog Audio: 7.1ch or 5.1ch, Dedicated Stereo.
- D/AC: Two-channel Cirrus CS4398 DAC for Discrete Stereo; Eight-channel CS4382A DAC for Multi-Channel Analog.
- Digital Audio: Coaxial, Optical
- HDMI Audio: Stereo to 7.1ch.
- Bit stream and internal decoding of Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio for HDMI and Analog.
- SACD DSD bit stream over HDMI or straight to analog; SACD DSD to PCM conversion over HDMI.
- Disc Types: BD-Video, DVD-Video, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
(Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used.) - BD Profile: BD-ROM version 2 Profile 2 (also compatible with Profile 1 version 1.0 and 1.1). 1GB of Internal Storage; External Storage expandable through USB.
- Dual USB Ports (One in back; one front) for video, audio, picture, and BD-Live expandability.
- PS3 caliber load speeds for BD-Java enabled discs.
- Resolution, Picture and Audio adjustments can be performed on the fly.
- Discrete Output Resolution: You can force the player to always output a 480i/p, 720p, 1080i and 1080p 50/60Hz, and 1080p/24Hz (DVD-Video and Blu-ray) video signal.
- Source Direct: This allows the player to intelligently and automatically change the video output resolution of the player based off of the content source. For example, SD DVD will playback at 480i, Blu-ray will play back at 1080p/24Hz, and DVD-Audio and SACD will playback at 1080i (to ensure maximum audio bandwidth is available). This is ideal for people who use external scalers or do not want the BDP-83 to do any video de-interlacing and scaling.
- Video Demo Mode: Splits the screen vertically with one half showing the original source image, while the other half shows the results of adjustment to the Edge Enhancement, Detail Enhancement and Noise Reduction controls.
- Up to 1920x1080 native MPEG-2, AVCHD, MKV and DivX/XviD video support; JPEG and PNG picture support.
- Fully back-lit remote control
- Anamorphic lens compatible with constant height Zoom. Other Zoom modes identical to DV-983H
- Power Supply: Power Supply: ~ 100V – 240V, 50/60Hz AC
- Power Consumption: 35W (0.5W Standby)
- Dimensions: 430mm x 336mm x 77mm, 16⅞ x 13¼ x 3 inches
- Mass: 5.1kg / 11.2 lbs
- Decoding of DVD-Audio. Will be updated through future firmware
Feature Requests
- APE, FLAC, and WAV lossless; WMA and AAC lossy audio support.
- Adjustable Crossover. The crossover is either an all-or-nothing 80Hz. We would like to see 40 to 120Hz crossover support.
- Audio Delay over analog. Audio Delay is currently only available over HDMI. There is concern that analog users will experience down stream video delays which will cause audio/video synchronization errors.
- Audio Bit Rate and Frequency information. Current implementation only shows Audio Track selected. Having bit rate and frequency information will help determine if we are getting lossless or lossy audio when the BDP-83 is decoding Dolby Digital TrueHD and DTS-HD Master.
- Internal Test Tones for properly calibrating analog audio outputs as well as testing proper audio output.
- User Presets. User Presets would allow for multiple changes to the player with a single selection. Saves time adjusting individual sliders to meet specific feature requirements.
