AZbox HD Elite ... under hard test...
Νέο FW που διέρρευσε σήμερα σε Ουγγαρικό Forum (http://www.netboard.hu/viewtopic.php?topic=16591) ..
0.9.3177
Δεν το έχω τεστάρει γιατί δεν έχω τον δέκτη (σκοπεύω να τον πάρω)..
RELEASE NOTES
# FIXED
- CI can not support HD channel
- CI can not send the reply of ENQ
- Subtitles are transparent when menu is set to transparent
- Unicable is not working
- If playing recorded contents on movie player, recorded contents have no sound
- Can not add new SAT/TP on SAT/TP Editor
- Can not play with After recording
- If the channel has the subtitle language, which was selected on setting, subtitle
should be showed, automatically
# ADDED
- DVB-T/C NIT Search
- DTS decoding
- The menu of "Fixe Interlace on/off" on channel manager
For supporting the encoder, which may not respect the spec on this matter.
"When progressive_frame = 1 the picture is progressive, the two fields represent the
exact same time, and you should not see any comb effect when displaying the frame.
Moreover, when progressive_frame = 0, top_field_first is used to indicate which field
has to be displayed first."
- Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list
- Telefonica transponder on Amazonas(61.0W) is missing
- Always start in TV mode
- "Automatic Reboot Option" to Timer menu
# IMPROVED
- If you choose a movie from hard disk and in the same folder where the movie is stored
there is an .srt or something else the box loads subtile automatically ordered
by .smi/.srt/.txt.
Best Regards,
The OpenSAT/AZBox Team
http://rapidshare.com/files/269530876/patch.zip
panosop
Συστημικός
Απάντηση: AZbox HD Elite ... under hard test...
ΕΠΙΤΕΛΟΥΣ.........!!!!!!!!!!
Δουλεύουν οι Ελληνικοί υπότιτλοι σε .srt, ΣΩΣΤΑ και χωρίς ΚΑΜΜΙΑ ρύθμιση....:107::107:
αντε και το μηχανάκι βελτιώνεται...
Πάρα μα πάρα πολύ ωραία...από θέμα σταθερότητας πώς πάει??Σε συνεργασία με Emus αλλά και γενικότερα στην ταχύτητα αλλαγής καναλιών και γενικά σε θέμα Bugs, είναι ένα αποδεκτό FW?Απ ότι έμαθα είναι FW που διέρευσε ο Head Developer για να πάρει feedback απ τους χρήστες...ξέρει κανείς πότε θα βγεί το επίσημο FW??
δεν είναι ακόμα σε καλό επίπεδο , απλά ικανοποιητικό ...
έβλεπα ταινία 720p και κόλλησε στην 1,5 ώρα , είχε άλλη μισή ... εναλλαγή είναι μέτρια , με τα ... τα πάει σχετικά καλά , και σίγουρα έχει πάρα πολλά bugs που όμως δεν επηρεάζουν την γενική καλούτσικη εικόνα ...
Εχει κάποιος nova κάρτα και τον δέκτη να μας πει πως πάει ; σκέφτομαι να την ενεργοποιήσω ( τον Μάη απενεργοποιήθηκε ) version 6
Νέο firmware 0.9.3180 :
AZBox HD Firmware - rev. 0.9.3180
(2009.08.23)
RELEASE NOTES
# FIXED
# ADDED
- DTS decoding
# IMPROVED
by .smi/.srt/.txt.
Best Regards,
Download: http://www.azupd.com/0.9.3180/patch.bin
Απ οτι μαθάινω είναι η public εκδοση της internal εκδοσης που είχε διαρεύσει (3177=3180)....
ακριβως ιδια σε δυνατοτητες ,bugs και μεγεθος:141: και το ωραιοτερο απο ολα η εκδοση αυτη δεν εχει δοθει προηγουμενως στους beta testers
φοβερο!!!
σκεφτομαι να φτιαξω μονος μου την 0.9.3189 :143:
προσπαθω να κανω record το anixe hd στον εσωτερικο σκληρο και το αποτελεσμα ειναι να εχει καθε 5 δευτερα σπασιμο στην εικονα.
επειδη τον εχω με Hdmi σε ραδιοενισχυτη βλεπω οτι κοβεται και το λινκ μεταξυ τους οταν υπαρχει σπασιμο κατα την διαρκεια αναπαραγωγης.
επισης, οταν επαιξα το αρχειο σε φορητο υπολογιστη παλι υπηρχαν τα σπασιματα οποτε συμπεραινω οτι δεν προλαβαινει να γραψει στον σκληρο το hd stream, γεμιζει καποιο buffer και καθυστερει μεχρι να το αδειασει στον σκληρο.
αντιστοιχο προβλημα ΔΕΝ υπαρχει σε sd recordings.
Οταν καταφερω να τον κανω να παιξει cs τοτε θα δοκιμασω αν η συνδεση wifi σε δικτυακο σκληρο κανει τα ιδια (Αν γινεται αυτο)
κατα τα αλλα ο δεκτης ειναι παρα πολυ καλος, και περα απο το cs(στο οποιο δεν φταιει ο δεκτης) ανταποκριθηκε στις απαιτησεις μου και αξιζει τα λεφτα του.
Παιδια οσοι απο σας νομιζετε οτι η opensat (azbox) πρεπει να κανει public τους drivers για να μπορεσουν διαφορες ομαδες να υποστηριξουν τον εν λογω δεκτη με δικα τους images μπορειτε να το δηλωσετε στην παρακατω διευθυνση
http://www.petitiononline.com/azfree/petition.html
Εγινε:111:
Μην κάνετε όνειρα.... Αυτοί οι drivers είναι ιδιοκτησία της Sigma Designs (low level drivers) και δεν υπόκεινται στο GPL ....! Το έχει δηλώσει μέλος της Opensat ότι δεν μπορούν να του κάνουν public όχι μόνο λόγω της sigma, αλλά γιατί μόλις τo κάνουν θα "ξεπεταχτούν" καμμιά και καμμιά δεκαριά κλώνοι του Azbox HD από την... Κίνα!!!
Να μην ξεχάσω, το 0.9.3180 αποσύρθηκε από τη λίστα με τις αναβαθμίσεις του δέκτη λόγω πολλών προβλημάτων !!!!... Πλέον διαθέσιμες είναι μόνο οι 0.9.2371, 0.9.2372, 0.9.2880 !!! Οι beta testers αναμένουν νέα version τις επόμενες ημέρες από την Opensat ...
Δε λέω, καλός ο δέκτης στα χαρτιά, αλλά πολλά προβλήματα ρε παιδί μου , ειδικά με το diseqc 1.2 μοτέρ, όποτε θέλει το δουλεύει σωστά και όποτε γουστάρει δεν το κουνάει καθόλου ή το στέλνει αλλού γι'αλλού...! Άσε με τα cam , δουλεύει όποτε θέλει και με όποιο θέλει... Ευτυχώς με το dragon συνεργάζεται καλά , αλλιώς...
Άντε να βγάλουνε κανένα firmware της προκοπής, γιατί αρχίζω και τα παίρνω και τον βλέπω να πηγαίνει από κει που ήρθε....!
Μέχρι να δουλέψει σωστά θα έχουν βγει άλλα πιο καλά και έτοιμα
Έχει καταφέρει κανεις να λειτουργησει to wlan wifi με αυτοματη ip δεν λειτουργεί με χειροκίνητη περνάω ip και πάλι τίποτα.
λειτουργουσε σε καποια παλια FW αλλα απο την στιγμη που αρχισαν
να χρησιμοποιοουν το νεο api δεν δουλευει καθολου η αν δουλεψει εχει πολλα bugs
  • rose.athens
roque
