Hypex ή Truepath ?
Απάντηση: Hypex ή Truepath ?
στα 60.000;
θα μου πεις ο παρακατω που εχει δωσει τοσα για καλωδια, θα το θεωρει αστειο το ποσο.
Cabling/Interconnects:
Necessary Transparent Cable Opus MM interconnects or equivalent: $200,000
τον FBB 700 τον εχει ακουσει κανεις; - λενε οτι δουλευει ως ταξη Α εξου και η καταναλωση ρευματος.
τον άκουσα (κι αυτόν και τον 300 άρη) αλλά το τριπάθιο έπαιζε καλύτερα.
Κώστας Φ.
Ο συγκεκριμένος χρησιμοποιεί ένα κύκλωμα της Krell για "έξυπνο" bias..
Aν ήταν τυπικός (pure) Class-A ενισχυτής θα έπρεπε να έχει ψύκτρες σε μέγεθος ντουλάπας για να δίνει 700 Watt στα 8Ω, 1400W στα 4 και 2800W στα 2Ω.
Διαβάζω εδώ:
Krell's amplifiers have always been based upon class-A operation, which is the most linear, lowest distortion operational mode. But there are inherent problems with class-A operation: The full current needed for full-power operation is continuously carried by the amp at all times, no matter what the signal actually requires. This is inefficient, delivering 10% or less of the amp's total power draw as usable power. The rest of that draw is turned into heat. Thousands of watts of heat end up being dissipated to create a few hundred watts of usable power. This means that class-A amps need huge cooling systems, usually either massive heatsinks or fans, or both, and these add to the amp's size and cost.
A simple solution to this is to bias the amplifier to operate in class AB, where the amp will operate at a much higher level of efficiency (possibly as high as 50%), which permits the amp to be smaller and requires less heat dissipation. The downside is higher distortion.
Beginning with the astonishing Krell Audio Standard amplifier, which I auditioned at some length in Santa Fe, Krell employed a technology called Sustained Plateau Bias. The KAS tracked the musical signal in relation to the amplifier's bias. The bias level was set in several discrete plateaus, so that when the musical signal required a higher bias level to remain in class-A operation, the amplifier would elevate the bias to that plateau long enough to produce the signal needed before ramping back down to a lower bias point. This kept the amplifier operating in class A no matter what the signal requirements, but it reduced the amount of wasted energy.
The FPB, or Full Power Balanced, line of amplifiers employs Sustained Plateau Bias II, a refinement that employs microprocessors to monitor not only the signal level, but also the loudspeaker's impedance. That way, both signal and load are monitored and constantly adjusted so that the amplifier constantly operates in the class-A bias that yields the lowest possible distortion with the lowest possible heat dissipation at all times. In theory, it's a win/win situation. And, in practice, that's what it seemed, too. I auditioned the Krell FPB-600, and it was powerful, transparent, nuanced, and reliable.
Πάντως και οι 600ρηδες οι Evo ανέβαζαν αισθητά τη θερμοκρασία του δωματίου, ενώ τις ψύκτρες δεν μπορούσες να τις ακουμπήσεις. Το έγκαυμα το είχες στο τσεπάκι αν άφηνες το χέρι 3-4 δευτερόλεπτα επάνω.
Τι να πω... άσχετοι είστε ρε, αν είναι να πάρεις κρέλ παιδάκι μου, πάρε ένα μρά να ησυχάσεις... (16,000 W into .5 Ohm)
και οτιδήποτε άλλο στο καλάθι των αχρήστων....
ΥΓ αν περισσέψουν τίποτα ψιλά, χτύπα και το σαμπάκι το μρού.
ασχετοι οι αφραγκοι;
στα 60.000;
γιατι πολλα ειναι;
80.000 κανουν τα vtl και παιζουν χειροτερα απο τους evolution 10.000-15.000 δε θυμαμαι ακριβως.
Ενδιαφέρον θέμα
να μπούνε κι οι λυχνιες στον τίτλο...
Να ρωτήσω δυο πράγματα:
Α. Αυτοί οι καθαροί Α λυχνιες έστω ένα βαττ,
SE από πόσο ξεκινάνε;
Β. Ποιες εταιρίες έχουν Hypex έστω σε 1500 και κάτω έτοιμους;
Αυτός ο micromega IA-60
έχει λέει module hypex
πως μπορώ να καταλάβω την ποιότητα ενός hypex;
Εννοώ μεταξύ hypex: module, τροφοδοσία;
hypex κατω απο 1500 απο εταιρεια χλωμο.
αυτος ο micromega ειναι μονο 2χ60;
τι εννοεις να καταλαβης την ποιοτητα;
τα module οπως και τα τροφοδοτικα
εχουν κατηγοριες με φτηνοτερη την st
μετα την hg και τελος προσθετης και
τα hxr.(στα module ειναι βελτιωσης τροφοδοσιας περαιτερω).
εδω ισχυη το οτι πληρωσεις παιρνης.
Το stereophile στην παρουσίαση του μιλάει για hypex
στα 1500 έξω είναι ο ΙΑ-180
ο ΙΑ-60 βγάζει 2x 45 στα 8 ωμ μετρημένα με 0,1 %
και έχει 150 βαττ κατανάλωση.
Άλλος έτοιμος hypex από πόσα;
Για κλάση Α SE λαμπατο από ποσά;
πολυ λιγα watt και πολυ ακριβος.
εχει εδω καποιους ετοιμους αλλα ειναι
ιδιοκατασκευες.
οι τιμες ειναι ανα καναλη και χωρις φπα.
http://www.sfb.net/
Τι λέτε για την άποψη, η οποια λέγεται απο πολλούς, ότι η μακροχρόνια χρήση ενισχυτών class D καταστρέφει τα τουιτερ των ηχείων ?
tyler durden
Μη ριβγιούερ
μετρημενα απο τον ΗΧΟ, 2χ41W
Απάντηση: Re: Hypex ή Truepath ?
επίσης καταστρέφει την κινητικότητα του σπέρματος.:143::135::137:
ΙΜΗΟ... κολοκύθια (ή τρίχες κατσαρές, διαλέξτε και πάρτε)
Μη γελατε το ακουσα απο σοβαρους τεχνικους,γνωστους στο χώρο (ονοματα με pm)
και το διαβασα στο diyaudio, οτι δηλαδη βγαζουν RF στην εξοδο.
Spiromag
