SIM2 Grand Cinema MICO 50 Led Projector
Άλλη μια εταιρεία που παρουσιάζει το πρώτο της led μοντέλο μονότσιπου dlp με dynamic black και dark chip 4. Αναμενόμενη κυκλοφορία το Δεκέμβρη και η ανεπιβεβαίωτη ακόμη τιμή γύρω στα 20-23 χιλιάδες ευρώ. Ενδιαφέρον το γεγονός ότι στα τεχνικά χαρακτηριστικά δεν αναγράφεται ούτε καν ονομαστική τιμή φωτεινότητας, παρά μόνο ο τύπος των led που χρησιμοποιεί (ίδια με του Vivitek). Επίσης, ως διάρκεια ζωής των led αναγράφονται οι 30.000 ώρες (έναντι των 20.000 ωρών του δευτέρου).
http://www.sim2.com/home/en/grand-cinema-mico/mico50
The SIM2 Grand Cinema™ MICO 50 projector - the latest addition to SIM2’s award winning Grand Cinema series - is based on 3LED lighting and 0.95" DarkChip4 1080p DLP® chipset from Texas Instruments offering true, uncompressed 1920x1080 resolution.
The SIM2 Grand Cinema™ MICO 50 incorporates 3 individual high power Phlatlight LEDs (one for each color R, G and B) allowing the projector to deliver clearer, brighter and more vibrant images, a wider and more consistent color gamut, and Full-On/Full-Off contrast up to 100,000:1.
Truly green projector
LED lighting technology is the only light source that is truly environmentally friendly.
- Low energy consumption and standby mode < 1W
- Mercury and lead free – no special recycling is required
- No replacement or stockpiling of hazardous materials.
The SIM2 Grand Cinema™ MICO 50 is fully RoHS compliant.
Thanks to LED light source, the SIM2 Grand Cinema™ MICO 50 gives the viewer a totally new home theatre experience in terms of operating and owning costs with LEDs life estimated to last up to 30,000 hours.
AVAILABLE FROM DECEMBER 2009
LIGHT ENGINE
Technology 1 chip DMD 0.95” darkchip 4 chipset by Texas Instruments
Resolution 1920 x 1080 pixels
Contrast ratio (Full ON/ Full OFF): up to 100.000:1
Lighting system Luminus Phlatlight PT120 R/G/B LEDs
Lamp average life time* 30.000 hours*
Color gamut >128% NTSC, >180% Rec. 709
INSTALLATION
Throw ratio 1.5-2.1:1 (T1 standard); 2.1-4.0:1 (T2 optional)
Motorized Lens shift V +60% / - 25%, H +/-8%
Digital keystone adjustment Vertical and Horizontal
Picture size (inches diagonal) 65-200
Aspect ratio 4:3, 16:9 Anamorphic, LetterBox, panoramic, pixel to pixel + 3 custom-user adjustments
ELECTRONICS
Horiz. & vertical scan frequency 15-97kHz/24-85Hz;
Video and Graphic standards PAL (B,G,H,I,M,N,60); SECAM; NTSC 3,58; NTSC 4,43 automatically selected;
HDTV ATSC (480p, 720p, 1080i, 1080p); EU 576p + 1080i 50Hz + 1080@24Hz;
PC graphic VGA, SVGA, XGA, WXGA, SXGA, WSXGA+, UXGA
Video processor built in
Special video adjustments: Noise Reduction, Luma and Chroma transition filters
Other special adjustments: Dynamic Black technology, Memories, Zoom/Crop, Color temperature control and Gamma Functions
INPUTS/OUTPUTS
Analog 1 x Composite Video (RCA)
1 x S-Video (mini Din 4 pin)
1 x Component Input (3x RCA)
1 x RGBHV/YCrCb (1x D-Sub 15 pin)
Digital 2 x HDMI – HDCP compliant
Miscellaneous 1 x Wired remote (3.5mm Mini Jack)
2 x OUT 12V (via DC Jack)
Control 1 x USB (B type connector)
1 x RS232 (Mini Din 9 pin)
Απάντηση: SIM2 Grand Cinema MICO 50 Led Projector
φτηνος ειναι:142:πρεπει να τον δωσουν πιο ακριβα γιατι δεν θα τους μεινει κομματι.....
δεν παμε καλα.....
δεν παμε καλα.....
νομιζω να παρω 2
εναν για το σαλονι και να εχω και ενα 2ο για το θερινο cinema μου :139:
αλλα μην γραφουμε πολλά
μπορει καποιος να τον φερει για ...τεστ :125:
η ΣΙΜ παντα σκιζει σε εμφανιση, αλλα κι αυτες οι τιμες βρε παιδι μου...:139:δεν ακουσανε για την οικονομικη κριση?....
Γνωστοποιήθηκε και η φωτεινότητα του μηχανήματος στα 800 Lumens (δηλαδή καλιμπραρισμένο γύρω στα 500-600), ουσιαστικά ίδια με του Vivitek. Η επίσημη τιμή είναι 25.000$.
Οι πρώτες εντυπώσεις από την εικόνα του:
Sim2 had the led pj running. It was pretty good, but probably not worth the $25k at this point.
I (by sheer accident) ended up seeing the very 1st showing for this CEDIA. We were told we were the very 1st ever to see the new product...... the new LΕD unit. Sorry, I forgot the new name, and didn't write it down. It physically looks like and is close to the size of a HT5000 but with a smoothed iff, shiny painted case like a C3X. It threw a nice picture, I was surprised by it's brightness, I expected less. Nothing ground shaking but interesting and the picture looked pretty good on the material they showed. It was followed by the Lumis, and that was the end of the LΕD for me.
I thought the SIM2 Mico 50 looked very good. It was being shown on an 8' wide JKP Affinity .9 gain screen. It was bright enough on that screen.
The Sim uses the Chilin engine, but they have their own implementation. It will cost $25k. It looked nice, but by Sims own admission it isn't as good as the Lumis. It looked like the on/off wasn't that great, but otherwise a nice start. They are doing their own design which will probably be unveiled at Cedia next year.
Με λίγα λόγια καλός, αλλά πολύ ακριβός για την ώρα για αυτά που προσφέρει, με την εικόνα του να μην είναι στο επίπεδο του Lumis. Με όσα έχω διαβάσει μέχρι τώρα, φαίνεται να εδραιώνεται η άποψη ότι οι τρίτσιποι dlp θα παραμείνουν στην πρωτοκαθεδρία για τουλάχιστον 3-4 χρόνια ακόμη, μέχρι οι led να λύσουν όλα τους τα προβλήματα και να γίνουν πιο οικονομικοί.
Και οι πρώτες εντυπώσεις από μοντέλο παραγωγής από το συνήθη ύποπτο Alan Gouger:
Σχεδόν αθόρυβος λόγω υδρόψυξης, φωτεινότητα τουλάχιστον ισοδύναμη με τους καινούργιους jvc, εικόνα που θυμίζει περισσότερο crt και lcos χωρίς να θυσιάζει τo ansi ως παραδοσιακή δύναμη των dlp, χρώμα που κανένας προβολέας λάμπας δεν μπορεί να αναπαράξει, ικανότητα ολικού σβησίματος των led σε μαύρη οθόνη (παρόμοια με το fade to black των crt). Το μηχάνημα παρόλο που φαίνεται να χρησιμοποιεί την ίδια οπτική μηχανή με του Vivitek (της Delta), ακολουθεί άλλη φιλοσοφία άνευ δυναμικής ίριδας και των τεχνουργημάτων που συνοδεύουν αυτή. Σύμφωνα με παλαιότερο πόστ του συνήθως έγκυρου coldmachine, η sim2 στα επόμενα μοντέλα της θα αναπτύξει τη δική της οπτική μηχανή, ειδικά για τη χρήση με led.
Πρόχειρη σύγκριση με Lumis, πάλι κατά τον ίδιο:
Lumis: Καλύτερο ansi και μαύρο (σε πραγματικές συνθήκες θέασης), φωτεινότητα, μικρότερο μέγεθος κουτιού.
Mico: Καλύτερο χρώμα, λιγότερα τεχνουργήματα, πιο ξεκούραστη, πυκνή και σταθερή εικόνα, σταθερή φωτεινότητα, μικρότερος θόρυβος λειτουργίας.
Παρακάτω οι πρώτες μετρήσεις του συνεργάτη του Jason Turk:
ansi contrast: 895:1
φωτεινότητα μετά από καλιμπράρισμα: 605 lumens (με ονομαστική 800).
on/off contrast: δεν κατέστη δυνατό να μετρηθεί με φωτόμετρο κατωτέρου ορίου .0001 (λόγω σβησίματος των led).
Περισσότερα εδώ:
http://www.avsforum.com/avs-vb/showthread.php?t=1202802
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
on/off contrast: δεν κατέστη δυνατό να μετρηθεί με φωτόμετρο κατώτερου ορίου .0001 (λόγω σβησίματος των led).
Πω,πω!:111:
Το βατερλω του Βογιατζακη:144:
καλα,αυτο το σβηνουν τα LED και βγαζω μαυρο ειναι τεχνασμα,δεν μπορει να παρθει σοβαρα.
Λεει εχει χειροτερο μαυρο απο τον LUMIS,που δεν ειναι καλο νεο.Υποτιθεται οτι περιμενουμε απο τα LED καλυτερο μαυρο,ειδικα σ'αυτη την τιμη.Το ΚΑΛΟ νεο ειναι η φωτεινοτητα που δεν ειναι καθολου ασχημη και υποτιθεται ειναι το βασικο προβλημα της τεχνολογιας.
Για το χρωμα εχουμε ξανακουσει και τα καλα της φωτεινης πηγης τα ξερουμε.Γενικα ετσι οπως τ'ακουω πρεπει ναναι ευχαριστη εικονα αλλα "πολλα τα λεφτα Αρη".
Πω,πω!:111:
Μάλλον το δικό σου Βατερλώ θέλεις να πεις Σκαφάτε! :137:
Τα LED πάνε κι έρχονται στο εξωτερικό, αλλά εμείς εδώ απλά μυρίζουμε τα δάχτυλά μας, μπας κι ανακαλύψουμε την αλήθεια... :204:
Από τα πολλά διαμάντια κυριολεκτικά που μπορείς να ανακαλύψεις στο αμερικάνικο φόρουμ, από ανθρώπους όπως ο Ντάριν, ο Γκρεγκ Ρότζερς, ο Μάρκ Πέτερσεν κτλ., που πραγματικά χαίρεσαι να τους διαβάζεις, αφού προσπαθούν να κάνουν τη βαθιά γνώση της βιντεοπροβολής κτήμα ακόμα και των πλέον άσχετων από εμάς... :126:
Διαβάστε τι γράφει ο Ντάριν σχετικά με το φαινόμενο του rainbow, εγώ τουλάχιστον πιάστηκα εντελώς «αδιάβαστος», μια και συνέδεα το φαινόμενο του rainbow αποκλειστικά με την ύπαρξη του χρωματικού τροχού στους μονότσιπους DLP προβολείς: :120:
To add to what Art and Alan said, while the color is done sequentially it is possible that an LED single chip DLP could have less rainbow effect to humans than a 3 chip DLP with a lamp, since 3 chip DLP technically has color separation too and the LEDs can be switched very quickly. I haven't figured out the math, but I recall TI claiming something like the equivalent of a 40x or 48x colorwheel with LEDs 2 or 3 years ago and they told me that the Air Force had done some studies that humans wouldn't see rainbows above something like 24x. They may have settled on a lower effective multiplier since then. I say "effective multiplier" mostly because with LEDs they don't have to do a fixed sequence between the colors like colorwheels do.
Και δείτε επίσης και εδώ τι συμπληρώνει ο φίλτατος Ντάριν, δίνοντας περαιτέρω διευκρινήσεις:
A 1 chip with a colorwheel and lamp can do 4 basic states for a pixel. Those states green, blue, red, and black. A 3 chip DLP 8 basic states for a pixel. Those states are white, green, cyan, blue, magenta, red, yellow, and black. Other than that the "rainbow effect" is pretty much the same idea with the chip having less because it can do those secondaries and white, along with because able to switch between those 8 states with the chips (not using a colorwheel). There are still color separations with the 3 chip because any color besides those 8 requires that the projector put one of the 8 up at one instance in time and then one or more others up at another point in time just to try to simulate the color people are supposed to see. Just consider creating a color halfway between green and yellow. The 3 chip DLP has to create that by doing green part of the time and yellow some of the rest of the time, letting people's vision kind of average that out.
An analog device in a 3 chip is a different story, but with DLP 3 chip doesn't mean no color separations. Less of them that would be noticeable to humans, but still there.
Επίσης, τα ευρήματα του Jason Turk είναι άκρως εντυπωσιακά: ακόμα και σε απόσταση μίας ίντσας (δηλαδή, ούτε λίγο ούτε πολύ, δυόμισι εκατοστά απόσταση) του φωτόμετρου από τον φακό του προβολέα, δεν μπορούσε να πάρει καμία ένδειξη φωτεινότητας! :111:
I measured the on/off contrast...well...no I didn't. It was infinite. Basically I could put my meter at 1" from the lens and I got no reading on black (it turns off the LED's)...I should mention my meter goes down to .0001 as well. I did measure ANSI and got 895:1...amongst the highest to date.
Και όλα αυτά με ένα φωτόμετρο που μπορεί να κατέβει στο ένα δεκάκις του χιλιοστού του lux (φαντάζομαι ότι μετράει σε lux), όπως γράφει!!! :111:
Ενώ το ANSI contrast είναι κι αυτό στα ουράνια με τη μέτρηση του 895:1!!! :111:
JL_
Ωραία τα λέει ο φίλτατος Ντάριν, αλλά δεν είναι σωστό να τεντώνουμε τη θεωρία για να μειώσουμε την αξία των τρίτσιπων...
Είναι αδύνατον να δει το μάτι rainbow effect σε τρίτσιπο, καθώς ο φίλτατος Ντάριν, ξέχασε να αναφέρει πως η εναλλαγή ανάμεσα στις τέσσερις διακριτές χρωματικές καταστάσεις του μονότσιπου επισυμβαίνει συνήθως σε σταθερούς κύκλους 3-6 επαναλήψεων το δευτερόλεπτο, ενώ η εναλλαγή ανάμεσα στις οκτώ διακριτές χρωματικές καταστάσεις των τρίτσιπων, επισυμβαίνει σε μη σταθερούς κύκλους των χιλιάδων φορών το δευτερόλεπτο...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Εχεις και παραπονο βρε συ.
Λιγα εχεις δει πρωτος απ'ολους....:136:
Lumis: Καλύτερο ansi και μαύρο (σε πραγματικές συνθήκες θέασης)....
Χμμ...
Αν δουλεύει όπως οι τηλεοράσεις Led με τα back light και τα local dimming...
στις μετρήσεις "Παναγίτσα μου"
στο πανί "παπαριές Μαρίτσα μου"
Manosmathiou
