Δοκιμή του Dune Prime 3.0
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Απάντηση: Δοκιμή του Dune Prime 3.0
Bookmarks improvements:
- File bookmarks are disabled when playing playlists, they are used only
when playing individual files (press ENTER on a file).
- The setting "Miscellaneous / Playback / Autoresume video files" allows
to completely disable bookmarks for video files.
- The setting "Miscellaneous / Playback / Autoresume audio files" allows
to completely disable bookmarks for audio files.
- The setting "Miscellaneous / Playback / Autoresume DVD" allows to
completely disable bookmarks for DVD discs and DVD-folders/ISO-images.
- Added a support for tags in audio files (MP3, FLAC, WMA, M4A).
- When tags are detected, they are automatically shown for the currently
played file during music playback. The supports tags include: title,
artist, album, track, year, comment.
- The setting "Miscellaneous / Playback / Audio file tags" allows to
disable reading and showing the tags (could be helpful e.g. if it does
not work properly for some files).
- Both Unicode and 8-bit tags are supported. The setting "Miscellaneous
/ Encodings / MP3 tag encoding" allows to force the specified encoding
for tags in MP3 files.
- When music playback starts, a hint about INFO and MENU buttons is
displayed (INFO -- show details about the current track, MENU -- show the
playlist).
- Added support for USB WiFi adapter D-Link DWA-140 version B2 (previously
only version B1 was supported).
- Added full support for discrete power-off and power-on IR commands.
- IR hex codes:
- DISCRETE-POWER-ON: 00 BF 5F A0
- DISCRETE-POWER-OFF: 00 BF 5E A1
- The DISCRETE-POWER-ON IR command is handled exactly as POWER RC button
when the player is in the standby mode, and is ignored when the player
is turned on.
- The DISCRETE-POWER-OFF IR command is handled exactly as POWER RC
button when the player is turned on, and is ignored when the player is
in the standby mode.
- If the player is configured to perform full power-off instead of
entering software standby, the DISCRETE-POWER-OFF and
DISCRETE-POWER-ON commands perform full power-off and power-on.
- Added a possibility to easily format a non-initialized drive (e.g. HDD)
just by pressing ENTER of the drive item on the main screen.
- "dune_folder.txt": "background_order" parameter now supports the
following set of values (instead of "first" and "last" as took place in
the previous firmware version):
- "before_all": the same as "first" in the previous firmware version.
- "before_icons": the same as "last" in the previous firmware version.
- "after_all": a new option, allowing to paint the custom background
after everything else (including file icons).
- "dune_folder.txt": added a possibility to hide file icons (w/o using
dummy fully-transparent icon). Syntax:
- "paint_icons = no" (default is "yes").
- Added more menu languages: Hungarian, Polish. Some other languages
updated/improved.
- The configuration of built-in FTP server adjusted to allow "FXP"
transfers.
- Added support for playback of video files with ".trp" extension (no more
need to rename them).
- Improved the speed of startup of specific MKV files, which previously
could take too long to start (that could even be considered by the user
as hangup in some cases).
- Bugfix: playing a file with an unknown length (such as MP3 with VBR
bitrate) caused playback crash (this bug was introduced in the previous
beta firmware version).
- Bugfix: playing/reading files from SMB share could crash in some cases
(the bug introduced by SMB optimizations in the previous beta firmware
version) (plus some other SMB-related bugs fixed).
- Bugfix: returning to file browser (e.g. after playback) caused crash if
current folder had dune_folder.txt with custom background image.
- Bugfix: specific Blu-ray images could not be played in some cases.
- Bugfix: after switching to TrueHD audiotrack in MKV file, stuttering
could take place in specific cases.
- Bugfix: "dune_folder.txt" / "paint_captions = no" did not work properly
in some cases (when the filename was too long and scrolled, it was shown
despite this setting).
Re: Απάντηση: Re: Απάντηση: Re: Απάντηση: Δοκιμή του Dune Prime 3.0
Μπραβο βρε συ Γιαννη!
Χαρα στο κουραγιο σου:444:
Βεβαια απο μια μερια θα ηθελα να ημουν μπροστα για να δω
τι φαρμακα θα δωσεις σημερα:405:
Μέχρι τώρα όλοι σώοι. STOP. Αν κάτι πάει σταβά -χτύπα ξύλο- βοηθήστε. STOP. Πείτε ότι δούλευα σκληρά για "επιστημονικούς" σκοπούς. STOP. Επιστρέφω στο λήθαργο. STOP.
only version B1 was supported). Το wi-fi πάλη δεν το βλέπει
Επιβεβαιώνω τον sparos...
Και με το νεο firmware δεν βλέπει το D-Link DWA-140 version B2 (F/W 1.31) :110:
Παιδια μολις ολοκληρωσα τις διαδικασιες και εστησα εναν εξωτερικο ntfs δισκο με το mymovies collection manager,οταν ομως το συνδεω στην εξωτερικη usb και δινω εντολη να το διαβασει μου βγαζει αμεσως error και κανει restart!
Αν ξερει κανεις τι συμβαινει ή υποπτευεται ας πει γιατι εριξα δυο μερες πολυ δουλεια με τη βοηθεια που εδωσε ο φιλος "sparos" και τωρα εχω μεινει παγωτο!
ΕΥΧΑΡΙΣΤΩ
Αισίως έφτασα στο 40% του αρχείου. Τα μάτια μου έχουν γίνει έτσι Αλήθεια τι κερδίζω όταν το τελειώσω?
Ελπίζω αυτό και όχι αυτό
Θεωρώ πάντως δεδομένο να μοιραστούν πρώτα τα μέλη του AVSite το αρχείο με την ελληνική γλώσσα, πριν δοθεί στη μαμά εταιρία για επόμενο firmware update
Καλησπέρα, Χρόνια Πολλά και Καλή Χρονιά σε όλους!
Σήμερα κατάφερα επιτέλους να μεταφράσω ολόκληρο το αρχείο της γλώσσας στα ελληνικά, μετά από πολύ ξενύχτι, καφέδες, χρήση λεξικών και διορθώσεις.
Το αρχείο αυτό το αποθήκευσα στον φάκελο με τις γλώσσες με κωδικοποίηση UTF-8 (όπως αναφέρουν οι οδηγίες του site της Due), το πέρασα με στικάκι στο Dune και το εγκατέστησα σαν custom, αλλά δυστυχώς δεν κατάφερα ακόμα να το κάνω να τρέξει, μιας και το αρχείο παρουσιάζει αριθμό λαθών 1000, αντί των 22 που έχουν όλα τα άλλα αρχεία γλώσσας.
Αν λοιπόν κάποιος από τους κατόχους του Dune Prime 3.0 -διαχειριστής ή μη- είναι καλός γνώστης των υπολογιστών, και επειδή υποψιάζομαι ότι προφανώς υπάρχει κάποιο σφάλμα στην κωδικοποίηση του αρχείου ώστε να είναι συμβατό με το Dune, ας μου στείλει pm, ώστε αύριο να του στείλω το αρχείο (ανοίγει με wordpad) και να το δοκιμάσει.
Στο μεταξύ θα δοκιμάσω κάποιες αλλαγές, μήπως και καταφέρω να το κάνω εγώ να δουλέψει.
Εύχομαι και πάλι σε όλους Καλή Χρονιά και Ευτυχισμένο το 2010!!!
Καλησπέρα και χρόνια πολλά και από μένα! Λοιπόν σήμερα σύνδεσα για πρώτη φορά το Base μετά από τόσο καιρό που το έχω. Η σύνδεση έγινε σε ενισχυτή Pionner LX52 και από εκεί σε Pioneer LX5090. Έβαλα αμέσως το τελευταίο firmware, έκανα τις απαραίτητες ρυθμίσεις και έβαλα έναν σκληρό δίσκο για να δω ένα blu-ray σε iso. Λοιπόν παρουσιάστηκε το εξής πρόβλημα. Μετά από περίπου 19 λεπτά αναπαραγωγής το dune κολλούσε και έκανε reset. Ξαναέβαζα την ταινία, ξανά το ίδιο στα επόμενα 19 λεπτά περίπου. Ανακάλυψα ότι αν πατήσω π.χ. pause και μετά ξανά play τότε είναι σαν να γίνονται reset τα 19 λεπτά για το κόλλημα. Έτσι κάθε περίπου 17-18 λεπτά πατούσα pause και μετά play για να μην κολλήσει. Τι έχετε να πείτε???
Εχθες ειδα το πρωτο bluray iso στο base μου και το επαιξε νερο,πραγματικα χωρις κανενα προβλημα,βεβαια εχω πανω το firmware που το παρελαβα,δεν εχω προβει σε αναβαθμιση!
Λοιπόν νέες εντύπωσεις. Σήμερα έβαλα να δω άλλη μια ταινία blu-ray σε iso rip. Σε άλλο δίσκο, αλλά ίδιο μοντέλο. Λοιπόν κάθε 30 λεπτά κολλούσε και έκανε reset. Ούτε το κόλπο με το pause-play έπιασε. Μετά από 30 + 30 λεπτά ταινίας κολλούσε κάθε 5 λεπτά και έκανε reset. Επίσης κατά διαστήματα έχανε τον ήχο και τον ξαναέβρισκε ή κολλούσε η εικόνα και επανερχόταν. Βγάζω λοιπόν τον δίσκο τον βάζω σε μια εξωτερική θήκη και τον συνδέω μέσω usb. Ως δια μαγείας όλα τα προβλήματα λύθηκαν! Απροβλημάτιστο playback! Οπότε λέω κάποιο πρόβλημα έχει το dune ή δεν γουστάρει τους δίσκους μου "μέσα του" ή μήπως υπάρχει θέμα overheating. Λέω για να δω το site για Hardware Compatibility και πέφτει το μάτι μου σε αυτό:
HDD models for usage with internal HDD rack.
For player models having internal HDD rack (such as Dune HD Mini, Dune HD Center, Dune HD Base, Dune HD Base 2.0, Dune HD Base 3.0), please consider the following recommendations:
* Use HDD with a suitable heat emission level. The exact suitable HDD models may depend on various factors, such as the ambient temperature and player cooling and airflow conditions. Generally, it is recommended to use HDD models with the smallest possible RPM value (e.g. 5400 RPM), smallest possible number of platters (e.g. 1 or 2 platters), and specially optimized for reduced power consumption and heat production and for use inside A/V equipment (e.g. Western Digital Green Power series).
* For example, HDD models such as Western Digital WD5000AACS (500 GB, 5400 RPM, 2 platters) and Seagate ST31000528AS (1000GB, 7200 RPM, 2 platters) are typicaly suitable.
* HDD models with high heat production, such as Seagate ST31500341AS (1500 GB, 7200 RPM, 4 platters) are not suitable and must not be used.
Αυτό είναι το μοντέλο των δίσκων που δοκίμαζα!
To prime 3 ειναι αθορυβο?
Αν εχει ανεμιστηρα, ρυθμιζονται οι στροφες του?
Ρε παιδιά καλημέρα σε όλους σας και καλή χρονιά. Κάπου διάβασα και θα ήθελα να μου πείτε αν ισχύει κάτι τέτοιο.
Μπορεί να παίξει bluray χωρίς ελληνικούς υπότιτλους (αγορασμένο από εξωτερικό) και να του δώσουμε εμείς με κάποιο τρόπο srt αρχείο με ελληνικούς υπότιτλους και να το παίξει ?
Κωνσταντίνος Παντός
