Κάτι ψήνεται στο σπίτι μας
m1ts0s
News poster
Can Cinder, the World's Most Precise Griddle, Replace Sous-Vide?
https://cindercooks.com/
"High quality cooking appliances are precise and powerful, and Cinder is no exception. Cinder can reach 500°F quickly and hold it with the resilience of a cast iron skillet, yet is accurate to one degree increments at lower temperatures. And even though Cinder can pull 1800W when needed, on average the energy usage is more like a 60W light bulb.
Unlike your range, oven, or grill, which fluctuate wildly in temperature, Cinder delivers even heat across its entire surface to within two degrees.
Its smart sensors adjust temperature based on the cooking profile of each item—even frozen—so that steaks are cooked from edge to edge, and salmon melts like butter.
With Cinder’s precise temperature control, a few minutes of inattention no longer means the difference between rare and medium, or caramelized and burned. In other words, you’ll nail it every time."
Οι ιδρυτές της εταιρίας:
'Eric Norman, a former Product Developer at Toyota Japan, had an epiphany over a croissant, and knew his path would lead towards food. Cooking at home, he was captivated by the game-changing results promised by modern techniques, but soon found these weren’t accessible to the ordinary home cook. Jim Reich, a Sensor and Control Systems Engineer at Xerox PARC and Lockheed Martin, met Eric in the San Francisco hardware startup scene and knew he could apply his aerospace expertise to help people cook better. And so, they created the Cinder Sensing Cooker. Cinder is backed by the prestigious Silicon Valley accelerator Y Combinator and is a graduate of the hardware incubator Highway1.'
:p
Πείνασες καλή μου?:p
(Σόρρυ για το οφ τοπικ .αλλά τι σας έπιασε όλες τις μεγαλοκοπέλες και αλλάξατε τα username σας?)
Γενικά ψάχνουμε νέες επιλογές στην καριέρα μας...:p
ΑΠΟΣΤΟΛΟΣ ΣΕΛΒΗΣ
