Είναι οι νέοι ενισχυτές καλύτεροι ?
Απο όσο κατάλαβα, είναι ισοδύναμα μεν, αλλά είναι σταθερά. Δεν περιλαμβάνουν μεταβλητούς παράγοντες όπως τα καλώδια και τα ίδια τα ηχεία με ό,τι αυτά περιλαμβάνουν στο κρος τους και τις ιδιότητες των μεγαφώνων. Άρα, πάλι όπως το έχω καταλάβει, το df που ανακοινώνεται ισχύει για μια ιδανική κατάσταση, ενώ στη πραγματικότητα η κατάαταση είναι εντελώς διαφορετική.
Απο το site της Bryston:
Damping factor is a measure of the amplifier's ability to control the woofer, and is measured by dividing the speaker impedance (normally 8 ohms) into the amplifier's output impedance (usually in the range of 0.02 ohms). The lower the amplifier's output impedance, the less the amplifier's output level is affected by variations in the speaker impedance. Also, since the woofer's voice-coil can act as a generator, within its magnet structure, the amplifier needs a low output impedance to act as a method of damping the woofer's tendency to keep moving after the signal has stopped. In the example above, the damping factor would be 8/.02 = 400.
Bryston amplifiers have output impedance slightly below 0.01 ohms, and therefore have a calculated damping factor of over 800, (though we conservatively rate them at 500). This parameter is affected by the speaker cable resistance. Even heavy 12 gauge wire has a resistance of about 0.0016 ohms per foot. (Remember we need to double that for twin-lead speaker cable). Thus, it would require only 6.25 feet of 12 gauge per speaker to have a total resistance of 0.02 ohms, (.0016 X 2 X 6.25 = 0.02), cutting a damping factor of 400 in half, to 200. Bryston recommends keeping speaker lead length to a minimum for this reason.
Keep in mind that damping factor is also affected by other real-world impedances, including the speaker-cable resistance, and the varying resistance of the speaker's own voice-coil. The voice-coil of a typical 8-ohm loudspeaker has a DC resistance of between 4 and 6 ohms. This resistance increases with temperature by 0.4%/Deg. C. It would thus require only a 25-degree rise in voice-coil temperature to increase its impedance by 10%. If it started with a DC resistance of 4 ohms, the extra 10%, (0.4 ohms), would reduce the actual damping factor to twenty, (8/0.4=20)!
It is worth noting that it would probably take only about 5-10 Watts to raise the voice-coil temperature by that amount. Add in the likely speaker-cable resistance of about 0.1 ohms, (10 feet of 16 gauge. cable), and it is obvious that the amplifier's contribution to the overall, real-world damping factor of the system is close to nil.
Whether the amp measures 300 or 3,000,000 under ideal conditions, the actual damping factor of the system will almost never exceed 100 anyway.
Σωστά είναι όσα γράφτηκαν από την μπριστον, και η προφανής λύση σε όλα αυτά είναι τα ...ενεργά, ώστε ο κάθε ενισχυτής, με ελάχιστο μήκος καλωδίου, να συνδέεται με ένα μεγάφωνο, χωρίς να παρεμβάλλονται παθητικά υλικά κρος.
Καλώς ή κακώς, δεν υπάρχει καμία καλύτερη λύση.
Kαι που να δεις τί λέει στο τομέα των καλωδίων... χαχαχαχαχα!
Αστο μα"ιμού , τα ενεργά της τα ταϊζει με εξωτερικούς ενισχυτές .
Δεν είναι ενσωματωμένοι στα ηχεία , προς μεγάλη απογοήτευση του διαχύσιου.
Τα περισσότερα μεγάλα ενεργά πολυενισχυομενα, έχουν εξωτερικούς τους ενισχυτές. Το όμοιο συμβαίνει για τα περισσότερα εντοιχισμένα, καθώς απομακρύνονται οι πλάτες από τις καμπίνες. Αυτό δεν αλλάζει τίποτα, και παραμένει με διαφορά η καλύτερη δυνατή λύση.
Μάλιστα σε πολλές περιπτώσεις, η καλωδίωση μεταξύ των εξωτερικών ενισχυτικων βαθμίδων και των μεγαφώνων, συμπεριλαμβάνει έξτρα αγωγό για ανάδραση πάνω στο μεγάφωνο, βγάζοντας εντελώς από την εξίσωση την καλωδίωση. ;)
Decembered
Μαϊμού
σ'γνωμη δεν γνωριζα (δεν ειχα στο νησι μου τετχοια) ... μια βολτα απο το μενου εκανα..
ενδιαφερον εχει ο Καναδεζος..
υποπσιαζομαι δε οτι οι τιμες ξεπερνανε ομως την ακσια της (ανακσιας) δισκοθηκης μου οποτε αι ντοντ γκιβ ε πενι.
Η υβριδική τοπολογία ADH (Analog Digital Hybrid) της Devialet περιλαμβάνει αναλογικό στάδιο εξόδου γραμμικής ενίσχυσης σε τάξη Α, σε παράλληλη λειτουργία με ένα διακοπτικό στάδιο εξόδου ισχύος τάξης D. Ο αναλογικός ενισχυτής καθορίζει την τάση εξόδου στο φορτίο, ενώ η παροχή του απαραίτητου ρεύματος διεξάγεται από τον διακοπτικό ενισχυτή ισχύος.
Μεταξύ των δύο αυτών σταδίων υπάρχει βρόχος ελέγχου. Ένας μετατροπέας DAC, τυπικά PCM1792 της Texas Instruments οδηγεί απευθείας το στάδιο ισχύος. Όλες οι λειτουργίες προενίσχυσης (ρύθμιση στάθμης, κτλ) διεξάγονται στο ψηφιακό πεδίο.
Στον αναλογικό ενισχυτή τάσης, δεν υπάρχει παθητικό εξάρτημα στη διαδρομή του σήματος. Τα ενεργά εξαρτήματα που συναντά το σήμα στη διαδρομή του έχουν μηδενική ικανότητα αποθήκευσης φορτίου. Ο αναλογικός ενισχυτής λειτουργεί σε συνθήκες σταθερής κατανάλωσης ισχύος, ανεξάρτητα από τις μεταβολές του σήματος. Το φασματικό του εύρος (bandwidth) εκτείνεται μέχρι τα 5 MHz, για τη βέλτιστη απόδοση των μεταβατικών χωρίς ολίσθηση φάσης. Το πραγματικό φασματικό εύρος είναι αυτό του εισερχόμενου σήματος, πχ 22.05 kHz για συχνότητα δειγματοληψίας 44.1 kHz, 48 kHz για για συχνότητα δειγματοληψίας 96 kHz, κτλ. Το δυναμικό εύρος του αναλογικού ενισχυτή επιτρέπει τάσεις μέχρι και 120 V, διατηρώντας χαμηλό θόρυβο σε επίπεδο μη ακουστότητας.
Ο ψηφιακός ενισχυτής αποτελεί πολυφασική, πολυεπίπεδη σχεδίαση, που λειτουργεί στα 1.6 MHz. Τέσσερις φάσεις λειτουργούν μαζί σε πέντε επίπεδα (στάθμες) ανά κανάλι ή οκτώ φάσεις σε 25 επίπεδα σε διαμόρφωση γεφύρωσης. Η μετάδοση ισχύος επιτυγχάνεται χωρίς καθυστέρηση και με ακρίβεια, μέσω ελέγχου από έναν μικροεπεξεργαστή για κάθε κανάλι, εξασφαλίζοντας προστασία από υπέρταση, υπερφόρτωση, υπερθέρμανση, κτλ. Ο ψηφιακός ενισχυτής δεν διαθέτει πυκνωτή εξόδου, με αποτέλεσμα να διατηρεί 90% ενεργό βαθμό απόδοσης με εξαιρετικά υψηλή πυκνότητα ισχύος.
Η υβριδική τεχνολογία ενίσχυσης ADH επιτυγχάνει εμπέδηση εξόδου σταθερά <1 mΩ, σε ολόκληρο το φασματικό εύρος, με ικανότητα οδήγησης οποιουδήποτε ηχείου της αγοράς.
Η κυκλωματική σχεδίαση Magic Wire της Devialet εξασφαλίζει τη βραχύτερη δυνατή διαδρομή του αναλογικού σήματος, μόλις 5 cm, μεταξύ DAC και ακροδεκτών εξόδου για τα ηχεία. Με τον τρόπο αυτό, αποφεύγεται η απομείωση του σήματος μέσα σε ολόκληρο το φασματικό εύρος, εξασφαλίζεται η προσαρμογή των αντιστάσεων για τη διατήρηση του θορύβου και της θερμικής παραμόρφωσης στο ελάχιστο.
Μέχρι και τον DAC (179x της Texas Instruments), η εφαρμοζόμενη επεξεργασία bit-perfect των δειγμάτων καθιστά δυνατή την ακριβή αναπαραγωγή του αρχικού σήματος. Στη συνέχεια όμως, το σήμα επηρεάζεται σε κάποιο βαθμό, οπότε είναι απαραίτητη η όσο το δυνατό αργότερα μετατροπή των δειγμάτων σε αναλογικό σήμα. Έτσι, ο DAC έχει μεταφερθεί πολύ κοντά στους ακροδέκτες εξόδου των ηχείων, ακριβώς στο σημείο της ενίσχυσης ADH.
Τα συνήθη συστήματα περιλαμβάνουν κατά σειρά κάποιο μετατροπέα ρεύματος εξόδου, έναν τελεστικό ενισχυτή μετατροπής ρεύματος σε τάση (διαγωγιμότητας), προενίσχυση και τελική ενίσχυση ισχύος. Καθένα από τα στάδια αυτά καταστρέφει την ακεραιότητα του σήματος. Στο Magic Wire, η διαγωγιμότητα, το φίλτρο anti-aliasing και το συνολικό κέρδος συστήματος διεξάγονται συγχρονισμένα. Το Magic Wire λειτουργεί σύμφωνα με μοντέλο πρόδρασης (feedforward model), μηδενικής ικανότητας αποθήκευσης φορτίου, διατηρώντας αυτόματα σταθερή ισχύ και αντισταθμίζοντας το σκεδασμό του μετατροπέα. Το αποτέλεσμα ισοδυναμεί με άνα απλό καλώδιο με κέρδος.
Ω χαίρε αλληλούια .
Δεν εχω δεί σύγχρονο μηχάνημα με πυκνωτή σύζευξης. Εδω και 40 χρόνια.
Δεν θα σχολιάσω τα υπόλοιπα λεχθέντα γιατί θα υποπέσω στην τοιάυτη κατηγορία , του κυρίου που γράφει αυτές τίς μπούρδες.
Ελεος , λυπηθείτε μας . Πόσα να αντέξουμε πια?
Τόση τεχνολογία , όλη σ ενα μηχάνημα ? μένω γάτσου 7 , (εκθαμβος) .
Ω χαίρε αλληλούια .
Αυτά ισχυρίζεται η εταιρεία... οπωσδήποτε είναι υπό την κρίση μας όλα
Επίσης διαθέτει το σύστημα SAM (Speaker Active Matching). Χρησιμοποιεί ένα μαθηματικό, ηλεκτροακουστικό μοντέλο των ηχείων (για πάνω από 900 συγκεκριμένα ηχεία), ώστε να προσαρμόζει με ακρίβεια σε αυτά το μεταφερόμενο σήμα και να παράγεται το ακουστικό σήμα που ταιριάζει με το εγγεγραμμένο.
Δεν το έχω δει αλλού αυτό
Ακριβό μηχάνημα .. και με προηγμένη ισοστάθμιση RIAA (ΜΜ/ΜC) στο ψηφιακό πεδίο ....
Decembered
Μαϊμού
αυτοι εβγαλαν μια διασταυρωση μπαλας μποουλινγκ με φορητο bluetooth speaker .. 🐒
στα ενισχυτικα εχει ενδιαφερων η προσεγγιση.
Ναι ρε ! δεν έχει. ! πάρτο απόφαση.!
Με τα χρέπια τα class d.
Ούτε 15 κιλά δεν ζυγίζουν.
Ενω ο σωστός ο βαρβάτος ο τελικός , που για να τον σηκώσεις θέλει παπαγαλάκι είναι άλλο πράγμα.
38 , 46, 60, 30 κιλά είναι οι δικοί μου.
27 κιλά μόνο ο prepro denon, 21 κιλά ο προ sansui.
Η μόνη υποχώρηση που έκανα είναι ο JBL class G μόνο 30 κιλά.
2xwria
