EGREAT EG-M31B HDMI NETWORK PLAYER
Οι αλλαγές της version 1023 του Popcornhour A110 (λογικά είναι οι ίδιες και για το Egreat 31B !!!) :
Playback
- MKV HTTP streaming performance improved
- MKV Chapters support.
- MKV chapter key handling (follows WMP)
- use PREV/NEXT key to switch chapter
- at each chapter,
- pressing PREV once will goto start of that chapter
- pressing PREV twice will goto previous chapter
- pressing PREV twice at 1st chapter will goto previous clip if in playlist
- pressing NEXT once will goto start of next chapter
- pressing NEXT once at last chapter will goto next clip if in playlist
- Fixed ISO playback over USB occasional hang issue
- Fixed some FLAC playback at wrong sampling frequency
- Fixed certain TS substream (mostly teletext) incorrectly detected as DTS
- Fixed certain TS with mixed Hi-Def and standard audio subtracks losing audio
- Audio with new info display and ID3v2 (album art if available)
- ID3 parsing for local (HDD, USB storage) content only
- Press Info key to display
- Added filename and bitrate in video info display.
- RMVB support (requires new myiHome v5.1.0 and above to perform transcoding)
- Fixed certain microDVD SUB file will cause hang
- Fixed thumbnail display issue from WMP servers
- Moved Video Zoom option from "Preferences" to "Audio/Video" page, separating into 2 options
- Video Zoom [Actual Size | Fit To Screen | Crop | Full Screen]
- TV Type [4:3 | 16:9 | 16:10]
- Prebuffering control
- new HTML extension tag supported, "prebuf=xxx" property tag added to
anchor tag to set the size of the pre-buffer
- Fixed no dimension information displayed for certain M1V/M2V files
- display MP3 album art in actual size
- Fixed exception handling for music album art
- added handling of FLAC file with ID3 header
- DTS-core passthrough fixed
- Fixed audio switch between DTS-HD and other codec no output issue
- Video playback progressive zoom and pan
- press "Zoom" key to cycle through zoom mode, magnify mode and pan mode
- use arrow key to adjust value (only left/right key for zoom/magnify)
- moves viewport when panning, instead of the image
- added exit zoom mode
- change pan step size to 1
- save pan/zoom setting for each zoom profile (FullScreen, Actual Size etc) to RAM.
- Audio output fixes
- fixed some AVI with DTS 96/24 output
- fixed AVI with PCM output noise when set to 5.1
- fixed HDMI no DTS output when AC3 set to PCM mode
- Fixed for 24 bit encoded FLAC playback
- Fixed playback video_ts over SMB stuttering issue
- Fixed Brightness/Saturation/Contrast not applied correctly in DVD playback
- Added language selection for DVD subtitle/audio (Danish etc)
- Fixed DVD with single subtitle track cannot be displayed
- Modified Volume range to improve usable range
- Volume range -15~+15, max 15dB, min -28dB.
- red number if >0dB, indicating boosted volume
- green number if <0dB
- white at 0dB
- Fixed volume not saved when it is 0dB
- Detect .dts as DTS-WAV, starts playback with 0dB to allow uncorrupted passthrough
- Fixed WAV header parsing for certain wav file
- Fixed HD-DVD remux, DD+ track no audio downmix output
- Fixed M2T PMT detection bug
- Fixed DTS-WAV output issue when surround mode is set to 5.1
- Fixed inaccurate running video bitrate
- Rectified "repeat", "suspend" key mapping in ISO playback
- Fixed incorrect playlist OSD display when music playback from myiHome
- Fixed decoder crash when playing a MKV without audio track
- Fixed incorrect downsampling of PCM audio for HDMI output source sampling rate > 48kHz
- Fixed incorrect WAV playback sampling rate (set at 48kHz)
- DTS Stereo downmix supported
Photo app
- New Photo app
- added more information on display
- eliminate black-out gap between slides
- able to display monochrome JPEG
- auto rotation for photo (JPEG)
- based on EXIF orientation and below 2048x2048
- Brightness/contrast/saturation change ("Setup" + arrow keys)
- Slideshow fixes
- Auto rotation for jpeg 2111 profile
- Known issue: Color distortion at the bottom of picture after +-90deg rotate.
- Color settings to follow preset value
- changed pan to moving viewport, instead of image (same as for movies)
- fixed mis-aligned position when performing zoom
- Fixed decoder crashed when displaying certain GIF file through HDMI
- Fixed certain JPEG rotation will crash decoder
- Known issues:
- for GIF/BMP/PNG, will clear screen when manually switch previous/next slide
- color distortion at bottom of photo when panning.
- no rotation for BMP GIF PNG
- no rotation for JPEG >= 2048x2048
- JPEG > 15MB cannot be displayed through HTTP
- BMP > 2272x1712, PNG > 4000x2400 cannot be displayed - checking
- Note: myiHome will transcode and scale-down BMP/GIF/PNG to JPEG
System/Browser
- Atheros WiFi WEP issue fixes
- added HDMI/DVI colorspace Setup option
- fixed wrong navigation flow after adding network share
- Modified Web Services UI pages
- Fixed when USB drive added/removed, issue with media source page refresh
- Turkish, Danish translation added
- Browser caching to harddisk
- Browser codepage conversion
- Various translation fixes
- WiFi graceful teardown during reboot/shutdown to avoid crash.
- Browser modification
- pressing SOURCE key at "Media source" page will goto "Web Services"
- fixed browser using wrong cached image
- added "new folder" and "rename" functions in File Operation menu
- faster fileplayer sort
- Fixed garbled text at network share -> username/password page
- Various new libs to resolve crash issue Usenet download under certain condition
- Fixed CD-ROM folders not sorted on top of file list
- Fixed occasional inaccurate WiFi auto-scan list
- Workaround inaccurate width calculation for some fixed-width character
- Cut Browser parsing time to about half (reduce about 0.2s)
- Fixed ISO file does not support relative path on fileplayer
- Fixed NMT apps start/stop status shown incorectly
- Fixed NMT apps status refresh in SEtup page and "Reset Factory Setting" handling
- Fixed failure to access Clutch interface
- Fixed broken browser history
Network
- NFS servers browsing supported
- SMB client fixes, additional checking to prevent from redirect to invalid/stale share folder
- Handling when network lost - proper unmount and page redirection
- NFS client fixes, reduce the retry time on NFS mount from 2 mins to 1 min
- Revert network IP checking for SMB/NFS share before mount attempt
- Fixed reset to factory settings occasionally failed after network configuration changed
Subtitle
- Fixed extended character misaligned in MKV embedded subtitle
- Fixed bi-direction issue in Hebrew *.SUB
- Subtitle menu re-ordered and text modified
- "Time"->"On/Off"->"Color"->"Size"->"Position"
- Fixed Subtitle from myiHomeLite bug (QA#495)
Casgle client
- changed Casgle client name from "Casgle Client" to "Casgle iDVR"
- opened Casgle client service for SD mode too
Known issues
- PNG/TIFF support over myiHome broken
Και οι αλλαγές στα νέα applications:
1. Minimum firmware version to use this NMT App is 00-17-081023-15-POP-403-000
2. Casgle services added
- For more information on this feature, please visit http://www.casgle.com/pch.php
- Note that by default Casgle iDVR will be subscribed to some
default channels and will do downloads in the background.
This may take up some of your HDD space, and network bandwidth
during the download.
To disable this service, you can Stop this service under
Setup->NMT apps->Start/Stop OR you can unsubscribe all channels
on Casgle
3. Fixed Casgle when start from index page link, unable to add channel
4. NMT apps page will generate for every access to get latest status
5. Added Casgle UI with help
6. Restart NMT apps after restore factory setting
7. Automatic restart NMT app that fails to start
8. Samba server, remove server information when server is stopped
9. Samba server, upgraded Samba server from 3.0.26a to 3.0.32.
αν ξερει καποιος ..να βοηθηση γιατι πηρα σημερα το egreat 31b και μετα απο αρκετη ταλαιπωρια ..κατι καταφερα...αλλα..
1-πως γινεται εγκατασταση του usb stick wirelles.....εννοω στο cd υπαρχουν τα αρχεια πως τα περναμε στο egreat ??
χωρις αυτο δεν μπορω να εχω δικτυο ...δυστυχως....
Γενικα το προβλημα η μαλλον τα προβληματα ειναι αρκετα..
πως κανουμε εγκατασταση του ασυρματου stick usb..
πως συνδεομαστε στο δικτυο...
manual δεν υπηρχε στη συσκευασια ......
το pdf αρχειο απ την εταιρια μαλλον απευθυνεται σε προχωρημενους....τι να πω...
δεκτη οποια βοηθεια....
Παιδια πως κανω ρεσετ?Γιατι κατι εκανα στις ρυθμισεις και μου βγαζει οτι δεν υποστηριζεται
Δεν εχω εικονα.Loadαρει και μετα χανεται η εικονα.Αν κανω αυτο που γραφεται στην σελιδα 11 θα μου στρωσει?
έχω μια ερώτηση που μάλλον μπορείτε να την απαντήσετε. Έχω το egreat 31B και το μόνο που δεν κατάφερα να κάνω είναι μεταφορά με ασύρματο δίκτυο στο σκληρό που του έχω βάλει. Μπαίνω, τον βλέπω κανονικά αλλά δεν με αφήνει ούτε να σβήσω ούτε να γράψω. Ο δίσκος είναι φορμαρισμένος σε NTFS ( το partition που αποθηκεύω). Το έκανα γιατί όταν το δούλεψα με usb δεν μπορούσα να κάνω copy paste τις ταινίες μου. Καμιά συμβουλή κανείς? Η πάμε για format πάλι?
Καλησπέρα σας.
Παρέλαβα το Σάββατο το συγκεκριμένο gadget έχοντας διαβάσει αναφορές χρηστών στο Internet και το άρθρο του τελευταίου Hitech.
Οι εντυπώσεις μου...απογοητευτικές!
Το κέλυφος της συσκευής είναι τόσο φτηνιάρικη κατασκευή, που αδικεί κατάφωρα το υλικό που περικλείει. Όταν έβαλα έναν εσωτερικό δίσκο και τον στερέωσα με τις παρεχόμενες βίδες η συσκευή άρχισε να κουτσαίνει καθώς το πάτωμα είναι οριακά λεπτό για το βάρος του δίσκου. Με λίγο adjustment στο βίδωμα αυτό κάπως διορθώθηκε.
Μετά το power on ήρθε το δεύτερο shock. O θόρυβος του ανεμιστήρα! Γι΄αυτό υπήρχε αναφορά απο αρκετούς χρήστες αλλά ομολογουμένως τον περίμενα λιγότερο. Μετά την εγκατάσταση, την σύνδεση με την τηλεόραση, την δικτύωση και τις πρώτες δοκιμές η απογοήτευση μετριάστηκε καθώς η συσκευή κάνει πολύ καλά αυτό που υπόσχεται.
Κάποια στιγμή αργά το απόγευμα διαπίστωσα ότι ο φωτισμός των μπροστινών led της συσκευής είναι πολύ έντονος σε βαθμό που να γίνεται ενοχλητικός. Πλησίασα την συσκευή και με έκπληξή μου διαπίστωσα ότι είχε ξεκολλήσει το (ψεύτικο) καπάκι που καλύπτει το εμπρόσθιο τμήμα της συσκευής και είχε πέσει κάτω!
Το συμπέρασμά μου είναι ότι η κατασκευή του E-great είναι τόσο φτηνιάρικη που σε καμμία περίπτωση δεν θα άφηνα αυτή την συσκευή σε λειτουργία (power on) ενώ λείπω απο το σπίτι! Το κόστος της συσκευής δεν δικαιολογεί τέτοια κακή ποιότητα κατασκευής. Κρίμα γιατί από δυνατότητες είναι πολύ αξιόλογο gagdet.
Εχεις κανείς εμπειρία απο επιστροφές προιόντων στο e-shop? Αξίζει τον κόπο να μπώ στην διαδικασία αλλαγής για την πρόσοψη που δραπέτευσε?
Ευχαριστώ,
Θόδωρος.
ΤΕΛΙΚΑ ΦΟΡΜΑΡΑ ΣΕ ΕΧΤ 3. ΑΛΛΑ ΔΕΝ ΜΠΟΡΩ ΝΑ ΜΠΩ ΣΤΟ ΔΙΣΚΟ! ΕΒΑΛΑ ΤΟ ΕΧΤ2IFS ΑΛΛΑ ΔΕΝ ΚΑΝΕΙ MOUNT TO ΔΙΣΚΟ ΣΩΣΤΑ. ME TO MOUNTDIAG ΜΟΥ ΒΓΑΖΕΙ ΜΥΝΗΜΑ ΟΤΙ ΕΧΕΙ ΚΑΠΟΙΑ ΑΝΟΙΧΤΑ COMMUNICATIONS ΑΠΟ PREVIOUS USE ΚΑΙ ΔΕΝ ΚΑΝΕΙ MOUNT ΓΙΑ ΠΡΟΣΤΑΣΙΑ. EXEI KANENAS ΚΑΜΙΑ ΙΔΕΑ ΤΙ ΝΑ ΚΑΝΩ?
Το εγκατέστησα και το firmware και το applications. Έχει αρκετές διαφορές…
Θα το ψάξω και θα ενημερώσω
lakiss51
Απάντηση: EGREAT EG-M31B HDMI NETWORK PLAYER
Αποθηκευσα σε usb την αναβαθμιση (εννοειται ξεζιπαρισμενη), την βλεπει το egreat αλλα δεν την ανοιγει με καμια απο τις επιλογες. Καμια ιδεα;
tm
Καλησπέρα σας.
Ευχαριστώ,
Θόδωρος.
το σιγουρο ειναι πως δεν εχεις τιποτα να χασεις αν και με προβληματιζει το γεγονος οτι το eshop συμφωνα με την ανακοινωση που ειχε αναρτηθει στο egreat.gr δεν υποστηριζει πλεον τη συσκευη...
EDIT: μολις τωρα κοιταξα.. φαινεται οτι τα .. ξαναβρηκαν!
Καλησπέρα σας.
Ευχαριστώ,
Θόδωρος.
Εγώ είμαι ευχαριστημένος από τη συσκευή.
Εντάξει δεν είναι ότι καλύτερο από ποιότητα κατασκευής αλλά δεν μου παρουσίασε τα προβλήματα που αναφέρεις.
Για το θόρυβο που λες μάλλον δεν θα έχεις HTPC. Αυτοί που έχουν καταλαβαίνουν τι λέω.
Αφού όμως δεν είσαι ευχαριστημένος εγώ θα έλεγα να το γυρίσεις πίσω.
Πιστεύω οτι θα σου δώσουν καινούρια συσκευή αν θέλεις αν όχι μάλλον θα σου δώσουν επιταγή να αγοράσεις κάτι άλλο.
Πράγμα που για μένα δεν είναι και η καλύτερη λύση.
lakiss51
Απάντηση: Re: EGREAT EG-M31B HDMI NETWORK PLAYER
το firmware προσπαθεις να περασεις ή τις εφαρμογες?
Το νεο firmware
Πως κανουν αντιγραφη με esata απο το πισι στο μηχανακι;
Christos Kourmouzoglou
