Μια φορά κι έναν καιρό...
skaloumbakas
4Haris
System - room - records description
Να κάνω μιά ανακεφαλαίωση της περιγραφής του ηχητικού συστήματος μου, όπως είναι σημερα:
SYSTEM
Turntable: AAS Gabriel heavy mass Swiss made & DIY improved:
* Platter: 44lb/20Kg high quality alloy, with a ring magnet inserted on the bottom and a custom aluminium spindle bearing a small ring magnet.
* Chassis: 84lb/38Kg high quality alloy, on a lead base, bearing a ring magnet on the top.
* Arm base: Outboard, standalone, from high quality alloy, on a lead base and add-on 'surgical grade solid stainless steel 316' cylinders, weighting 57lb/26Kg in total.
* Motor: High quality German made DC, with a polished metal motor spindle (no groove).
* Motor Housing: Outboard, standalone, on a 33lb/15Kg lead base, placed on a dedicated 48lb/22Kg tripod.
* Power: Outboard, standalone p.su., with extra strength and 12V battery removed. High quality micro speed adjustment knobs for the 33 and the 45 rpm's.
* Flywheel: Outboard, standalone, from 'surgical grade solid stainless steel 316'; 25lb/11.1Kg - 180mm OD bell, rotating at 375rpm via 6 drives, floating on a 35lb/16Kg chassis, placed away from the platter.
* Drives:
- 1 x 45mm. OD drive, using 1 x 2mm Polyurethane flat belt f/ motor to f-w
- 5 x 27mm. OD drives, using 5 x 2mm OD Polyurethane round belts f/ f-w to platter.
* Suspension: Platter and f-w floating by magnetic repulsion.
* Bearings - Magnets - Oil: Details in audio paper#37...
* Disc-'O'-Ring: 3.5lb/1.6Kg nickel coated brass, custom made.
* Record clamp: 1.3lb/0.6Kg 'surgical grade solid stainless steel 316', custom made, with a small ring magnet on bottom for extra push.
* Placement: No plinth/base provided. Motor - 450 (± 10mm) - flywheel - 600 (± 30mm) - platter on a straight line, with platter & f-w on the rack (different shelves) and motor on a tripod. Area needed for the whole set-up (phono stage incld): 1500 x 500mm.
* Total weight (tripod incld but not p.su. & phono stage): 330lb/150Kg.
Arm:
Clearaudio TT2, replacing Clearaudio TQi Master linear (improved with 1600gr extra weight), replacing Souther "TQi" linear arm (improved with extra weight, supporting spring & new track/arm-holder)
Cartridge:
Clearaudio 'GoldfingerD', replacing 'Goldfinger', replacing 'insider reference' wood, replacing 'insider gold'
Phono stage:
DacT CT100 w/ dual mono ultra fast 800w custom p.su., replacing JRDG consummate.
Digital:
Wadia 8 transport / Wadia 15 Decoding computer, updated with ClockLink (for minimizing jitter) & better capacitors in p.su.
Preamplifier:
Jeff Rowland "consummate" w/ custom ultra fast p.su. (600+100VA toroidal & 40,000 µF )
Amplifiers:
(a) Jeff Rowland "model 8T" (2x400w @ 4 Ohms, for the high/mid ribbons - dual mono p.su. w/ 640,000 µF capacitance!)
(b) Genesis 300 4-channel servo-amplifier (4x375w @ 2 Ohms, for the 2x6x8" woofers, improved w/ 160,000 µF capacitance)
Speakers:
Genesis 300 (with new mid ribbon & crossover)
WIRING
Phono cable:
Clearaudio sixstream (1.25m), replacing DARA custom silver arm cable: 0.8m. f/ cartridge to phono stage, no jacks in between, (replacing Clearaudio Litz type flexible arm cable & XLO "signature" phono cable)
Digital cables:
DARA custom silver: 2 pcs of 1m. BNC-BNC, (replacing XLO "limited edition")
Interconnects:
DARA custom silver (XLR all): (a) 0.7m. f/DacT phono stage + (b) 0.85m. f/Wadia 15 + (c) 2 pairs of 1.6m.(main-XLR) & 1.05m.(lows-RCA) f/JRDG 'consummate preamp to amps, (replacing XLO "signature" & Transparent "reference")
Speaker cables:
DARA custom silver: (a) 1.6m. to ribbons + (b) 1.6m. (4-channel) to sub, [replacing Nordost "SPM" & Transparent "reference" (to ribbons) + Audioquest (to sub)]
LISTENING ENVIRONMENT - RECORDS
Surface: 120 m2
Volume: 400 m3 (estimated)
L x W x H: (11.4-5.5m)x(4.4-8.2-11.7m)x(3.0-4.15m). Tilted roof. Lowest Room Frequency: 15Hz!
Amplifiers on: 3-piece sandwich shelve placed on the floor
Speakers placement:
speakers apart: 2.65m.
f/back wall: 4.90m.
f/side wall: 0.68m.
f/sweet spot: 2.65m.
sweet spot to back wall: 3.85m.
Floor/Furniture: Wood / Classical
Electronics on: Extra heavy DIY rack - 500Kg with equipment details here. T/T's motor placed separately on a dedicated heavy tripod. All p.su.'s placed on the floor.
Speakers on: Elastic pads
Music:
Jazz Lp's/Cd's: 410/300
Classical Lp's/Cd's: 670/460
Other Lp's/Cd's: 200/400
Power cords:
2 power distributors (1 w/Audioquest 3.3 cord and 1 Audio Agile) + Xaitas "black signature" power cords (all equipment), replacing Essence power cables.
Electr. install.:
2 dedicated phases of 35A/phase, [one for the preamplifier, phono stage & t/t & main amplifier] and [the other for the digital & the servo-amplifier]. Xaitas isolatros V-3 & V-4 in-line with the dedicated power lines have been removed
Accessories:
NM sonic purifiers (52 pcs) for complete EMF absorption, DIY record clamp & disc-'o'-ring, Daruma RollerBlocks, Clearaudio diamond cleaner, Kontac cleaner, sound level meter by Radio Shack, Zerostat3 gun, Cardas sweep record, Bedini ultra clarifier, Metroline PM52 3-phase volt/freq. meter, etc.
Απάντηση: Μια φορά κι έναν καιρό...
Χρηστο, μια ερωτηση απο σκετη περιεργεια.
Τι ηταν αυτο που σ' εκανε να διαλεξεις τα Genesis 300 για ηχεια σου τελικα?
Και πριν τ' αγορασεις, ποια αλλα ηχεια ηταν στην τελικη σου λιστα των πιθανων? :107:
skaloumbakas
4Haris
Φίλε Θανάση,
Είχα τα Martin Logan Questz και ενώ μου άρεσε η αραχνούφαντη ηχητική απόδοση του μεσουψηλού της μεμβράνης, κάτι δεν μου καθόταν με το χαμηλό...
Εκείνη την εποχή η Genesis (του Arnie Nudell και του McGowen) έκανε μια νέα σειρά ηχείων:
Τα Genesis 300 και τα Genesis 200 (με woofer towers) σε αντικατάσταση των Genesis 2 και Genesis 3.
Προβληματιζόμουνα λοιπόν και μάλιστα σκεφτόμουνα και το Dunlavy εκείνη την εποχή, το οποίο είχα ακούσει και με είχε εντυπωσιάσει η χειρουργική στερεοφωνική του εικόνα.
Τελικά με κέρδισε το ribbon και η σερβοενισχυση... :126:
να κάνω κι εγώ μια ερώτηση; γιατί κάθε φορά που "ξύνεσαι" και θες να αλλάξεις κεφαλή, σπας την προηγούμενη;
Nick Arvanitakis
Audio Pro
Mια φορά κι εναν καιρό ,τα Genesis II με είχαν τρελλάνει...
skaloumbakas
4Haris
Κάτσε να θυμηθώ τι απαντάω σ' αυτή την ερώτηση..... χμμμμ Α ναι!!
Η πρώτη χάλασε στη μετακόμιση,
η δεύτερη της μαλάκωσε η ανάρτηση και
η τρίτη της έσπασα το cantelever με τον αγκώνα!
Ο φούστης πως τα θυμάμαι... :143:
Οποιος πληρωνει παντα θυμαται!:142:
skaloumbakas
4Haris
Εχεις δίκιο! Σε αντικατάσταση των Genesis 1.5 και Genesis II βγηκαν τα Genesis 300 και 200.
δεν είναι σωστό όμως να είναι στημένα έτσι!!!
ΑΜΑΝ!!Γεμισε ο τοπος κρελ,που εισαι Βλασση να κρελλαθεις!!!Χρηστο και το ενα πανω απο το αλλο να τα βαλεις....ειναι σουπερρ!!Δεν νομιζω να κατασκευαζονται τετοια αριστουργηματα σημερα.:139::111::111:
skaloumbakas
4Haris
Ελα τώρα Αντώνη, μεσοβέζικες λύσεις!!! Εσύ θα πάρεις αυτά:
Infinity IRS V (6 x 12-inch front firing woofers per channel!, 1988!)
vlasis
Φωτογράφος!
Nαι ρε μαγκα μου.....τα ειδα και κατι με ηρθε βρε παιδι μου.....αραγε....εχουν μπασο????:143:
skaloumbakas
4Haris
Μέ 6 Χ12'' ήταν τα GENESIS I...
Και τα IRS και τα Genesis I, αργότερα...
Δείτε και το Infinity IRS από πίσω:
Το πανελ των μεσουψηλών
Τα Genesis I εφάρμοσαν τα ribbon tweeters (24 τον αριθμό σε κάθε πάνελ μπροστά και 12 back firing)
Οχι αλλα ειναι υπεροχα!
skaloumbakas
4Haris
Οχι, ξέρω 2 με Genesis II και ένα IRS εχει ο Βασίλης Χατζάκος στην Ηλιούπολη.
Nick Arvanitakis
Audio Pro
Ο ενας , πήρε αυτά που ηταν demo στην Lyric, o άλλος απο που τα έφερε?
skaloumbakas
4Haris
Ο ένας λέγεται Νίκος Κοντόπουλος και μένει Διονυσσο πρόσφατα έβαλε κι αυτός το καινούργιο mid-ribbon, ο άλλος το ονομα του τελειώνει σε ....ιδης δεν το θυμάμαι.
No more info available... (θα μας πιάσει και ο ΣΔΟΕ... :135: )
  • rose.athens
Quantic
