Dolby Atmos: Εν αρχή ην.. ενα ζευγος dali 7
τα phantom 80 ειναι οτι πρεπει. Τεσσερα ιδια εννοειται. Για σαμπ θα το συζητήσουμε εκτενέστερα ποσα θες και γιατι σε αλλη φαση.
Τα ηχεια, για να μπουν στην οροφη, τι απαιτησεις εχουνς? Απαιτειται καποιο ειδικο υλικο στην γυψοσανιδα πχ? Η απλα λεω στον γυψοσανιδα "βαλτα ακριβως σε αυτο το σημειο!" και τελειωσαμε?
deleted user 10898
Mounting considerations If the chosen overhead speakers have a wide dispersion pattern (approximately 45 degrees from the acoustical reference axis over the audio band from 100 Hz to 10 kHz or wider), then speakers may be mounted facing directly downward. For speakers with narrower dispersion patterns, those with aimable or angled elements should be angled toward the primary listening position. The overhead speakers should be at a height (shown as H3 in Figure 2) between two and three times the vertical position of the listener-level speakers. The angle of elevation from the listening position to the left top front/right top front and left top rear/right top rear overhead speakers in a 7.1.4 reference layout should be 45 degrees. This may be adjusted between 30 and 55 degrees if needed, as shown in Figure 2. Figures 3 and 4 show the preferred locations of the four overhead speakers as seen from above. The horizontal width should be about the same as the horizontal separation of left and right speakers placed at ±30 degrees. If this guidance is followed, the overhead side-to-side separation should be 0.5 to 0.7 of the width of the overall layout, depending on the distance to the screen and the front three speakers, relative to the surrounds. It is best to keep the overhead arrangement centered, front to back, over the listening area, even if the front speakers and screen are at a greater distance than the surround speakers.
Tι εννοεις ποσα??? Θα χρειαστει πανω απο 1? Μιλησα χθες στη γυναικα για τα 4 ηχεια οροφης (πιο πολυ σε φαση αστειου το ειπα) και ειχα γκρινιες..
Αντε να τα εξηγησεις αυτα στον γυψοσανιδά!!!
Ξεκινα οπως ειπαμε και για σαμπ μιλαμε αργοτερα.
Οχι, με ενδιαφερει για να ξερω το συνολικο μπατζετ που θα χρειαστει...
Εχουμε και λεμε.
Θα χρειαστω
1 dali zensor vocal (240 euros)
2 ζευγη dali phantom E-80 (416 euros)
1 ζευγος dali zensor 1 (220 euros)
και μας απομενει το κοστος του sub
Εχουμε και λεμε.
Θα χρειαστω
Ποσα τ.μ ειναι ο χωρος σου και αν μπορεις βγαλε μια φωτο. Επισης τι μπατζετ εχεις για σαμπ;
Ο χωρος ειναι αυτος στη φωτογραφια (κρυβονται λογω 2 μετρα αριστερα απο το αριστερο ηχειο ενω δεξια απο το δεξι ηχειο της φωτογραφιας, ακολουθει -χωρις τοιχο αναμεσα- η κουζινα). Για να οπτικοποιησω καλυτερα το δωματιο, να αναφερω πως η οθονη ειναι 55'.
Επισης, πρεπει να πω πως πισω απο τον καναπε (στο μπρατσο του οποιο ειναι ακουμπησμενο το ποτηρι), υπαρχει 1.5 μετρο αποσταση απο τον πισω πισω τοιχο.
Το υψος του δωματιου ειναι περιπου 3 μετρα περιπου αν το υπολογιζω καλα με το ματι.
Οσον αφορα το μπατζετ για το sub, ειλικρινα δεν ξερω.. Δεν γνωριζω καν ποσο βασικο ειναι το sub στο ολο συστημα που θα δημιουργησω. Με βαση ομως τον υπολοιπο εξοπλισμο που εχω και που σκοπευω να παρω τι μου προτεινετε?
Τι μπατζετ περιπου εχεις και ποσα τμ ειναι συνολικα ο χωρος που ακους.
[DOUBLEPOST=1526238504][/DOUBLEPOST]Γενικα μπορω να σου πω ενα svs pb2000 πιθανοτατα θα ειναι αρκετο οπως βλεπω το χωρο. Αλλα πες μας ακριβως τα τμ και μπατζετ.
Το δωματιο ακροασης ειναι 20τμ αλλα ενωνεται απο δεξια με την κουζινα η οποια ειναι 25 τμ μονη της. Βεβαια δε νομιζω να υπαρξει μεγαλο θεμα αν τα ηχεια μπουν σε καλη θεση.
Δεν ξερω σε τι τιμη παιζουν τα sub αρα δε μπορω να μιλησω για μπατζετ. Αν πω 400 ευρω ειναι λιγα?? Δε ξερω, ειλικρινα.
Αν σε περνει να δωσεις το χιλιαρικο το pb2000 ειναι κομπλε....
Αρχικα, οφειλω να σε ευχαριστησω για την διαθεση σου να με βοηθησεις φιλε μου.
Η αληθεια ειναι πως ΔΕΝ με παιρνει για ενα τοσο μεγαλο ποσο αν βιαστω να φτιαξω το συστημα συντομα. Αν ομως κανω υπομονη και το χτισω σιγα σιγα τοτε ειναι πιθανο να καταληξω στην λυση του συγκεκριμενου sub.
Επιλογες με λιγοτερα χρηματα υπαρχουν? Γυρω στα 500 δεν βρισκω κατι αξιοπρεπες?
Το pb1000. Θα χρειαστεις δυο που ειναι και καλυτερα απο ενα αλλα μπορεις να παρεις το δευτερο αργοτερα.
[DOUBLEPOST=1526240339][/DOUBLEPOST]Το pb1000. Θα χρειαστεις δυο που ειναι και καλυτερα απο ενα αλλα μπορεις να παρεις το δευτερο αργοτερα.
Επισης το presonus temblor t10 στα 350 ευρω αλλα θες δυο σιγουρα....
Τοτε θα κανω υπομονη κ θα παω στο ακριβο..
Δεν χρειάζονται οκτάρια woofers στο συγκεκριμένο σύστημα.
kspirit
