Tesla
How this continuation contributes to Tesla’s now and future
First, it blocks competitors from "fast-following" the 4680 production method. This patent prevents them from building factories that operate like Tesla’s. By protecting the specific "mix-then-bind" sequence and the "low-binder" recipe, Tesla ensures that its Gigafactories remain unique. Competitors cannot simply buy the same mixing equipment and run the same recipe without risking patent infringement.
Second, it secures the economics of "cheap" raw materials. By specifically patenting the use of larger (greater than 10 microns) particles, Tesla is validating a cheaper supply chain. Smaller, highly processed particles cost more. This patent confirms that Tesla’s process is optimized for standard, "bulk" grade materials. Protecting this capability ensures Tesla retains a cost margin advantage, as they can turn cheaper, commoditized inputs into premium performance outputs.
Third, it creates a legal "thicket" around dry electrode tech. This filing is a classic "picket fence" strategy. The parent patent protects the battery efficiency (90-94%). This child patent protects the binder loading (less than 2%) and the particle size. Future filings will likely protect the machinery. This layering makes it nearly impossible for a competitor to design a dry electrode without tripping over at least one of Tesla’s patents.
Finally, it validates the "micro-factory" concept. The emphasis on creating a "free-standing" film without a metal foil backing is crucial. It means the electrode film can be made in one machine and rolled up, then applied to foil later. This decouples the manufacturing steps, allowing Tesla to fit production lines into smaller, non-linear spaces, which is essential for the tight footprints of future factory expansions or retrofitting existing lines.
melina
Cargo 200
Μπλα μπλα μπλα από ανθρώπους που δεν καταλαβαίνουν τι σημαίνει δίπλωμα ευρεσιτεχνίας (ή μπορεί και να ξέρουν αλλά δεν έχει σημασία γιατί ο σκοπός είναι) να ταΐσουν μπλα μπλα μπλα ανθρώπους που δεν καταλαβαίνουν τι σημαίνει δίπλωμα ευρεσιτεχνίας.
Ndis
Titika
Ρε σεις για να πούμε καμία μαλάκια να περάσει η ώρα μπαίνουμε, όχι για να πάρουμε PhD !!
Δεν πρόκειται να τα διαβάσω αυτά να ξέρεις.
Νταξ, δες ένα βιντεάκι τότε, πιο εύκολο είναι. 🤣
Άλλωστε οι εταιρείες αυτές μοιράζονται πολλά, και η συγχώνευση είναι ήδη σημαντική, και αναμένεται και στα χαρτιά.
ΥΓ. 😡
Ως γνωστόν, η συνεισφορά σου είναι μονίμως πως κανένας δεν καταλαβαίνει τίποτα εκτός από σένα, και όλοι είναι χαζοί εκτός από σένα.
Κι ο Έλον είναι άσχετος, οι εταιρείες του είναι φούσκες - όπου να ναι θα σκάσουν, και βεβαίως ο Έλον είναι ο εχθρός, αυτός κι ο Πούτιν. Όλοι οι άλλοι είναι Άγιοι, Δόξα σοι.
Άλλωστε έχεις προβλέψει εδώ και χρόνια το ότι η Τέσλα θα φαλιρήσει, αλλά δε σου βγαίνει. Επιμένεις όμως..
Για σένα μόνο, αυτό:
Από μας που δεν καταλαβαίνουμε τίποτα, και με ευχαριστίες για τα σημαντικά σου ποστ και την ατέλειωτη συνεισφορά σου, με τόση διορατικότητα και πληθώρα πληροφοριών, ιδίως σε αυτό το θρεντ (μετά την Υγεία βεβαίως, όπου μάλλον έτοιμος είσαι για ιατρείο).
Προσωπικά κάθε φορά που βλέπω πύραυλο σε κάθετη προσγείωση ενθουσιάζομαι. Ακόμα να το χωνέψω. Ακόμη και με τα Falcon που κατεβαίνουν δύο δύο. Πόσο μάλλον με τον Super Heavy.
Τώρα έχω και άλλα θέματα. Η γυναίκα έχει τρέλα με τα αστέρια και θέλει τηλεσκόπιο. Και από ότι βλέπω κάτι της προκοπής (με search app και που να μην συνεχίζεις να βλέπεις την κουκίδα σαν κουκίδα) θες τουλάχιστον χιλιάρικο. :biggrin:
ΥΓ. 😡
Ήρθε η ώρα να μιλήσουμε και για τα τούβλα - απλά με πίεση - απο ρεγόλιθο στον Αρη για να φτιάξουμε σπίτια με τοίχωμα ενός μέτρου και νερού που θα σταματούν την κοσμική ακτινοβολία ; Πάντως εάν αποτύχει το 3D printing τους να ξέρεις θα φταίει... ο Πούτιν σίγουρα. :D
θα το κάνουν οι κινέζοι, αν δεν το έχουν κάνει ήδη,
και το patent infringement θα το γράψουν στα τέτοια τους,
τι θα πάθουν; θα τους απαγορέψουν την εισαγωγή των οχημάτων που έχουν φτιαχτεί με κλεμμένη τεχνολογία;
Ναι, δεν είναι καθόλου απίθανο.
Μάλιστα κάποια έχουν ήδη γίνει.
τι θα πάθουν; θα τους απαγορέψουν την..
Η Τέσλα Κίνας δεν αστειεύεται.
Βγάζει δόντια, και παίζει εκ των έσω, αφού Κινέζοι την διαχειρίζονται. 😎
Και δεν θα είναι η πρώτη φορά. 😎
Για παράδειγμα θα σου πω ότι είναι γνωστό πως η "Tesla Shanghai" (θυγατρική της Tesla Inc.) έχει προχωρήσει σε νομικές ενέργειες (με πολύ δυνατό team δικηγόρων) κατά διαφόρων κινεζικών εταιρειών για ζητήματα σχετικά με κλοπή τεχνολογίας και παραβίαση πνευματικής ιδιοκτησίας. Ενδεικτικά:
Μήνυση κατά της Bingling Intelligent Technology (2023): Η Tesla Shanghai κατηγόρησε την εταιρεία αυτή, η οποία ειδικεύεται σε σχεδιασμό τσιπ και ανταλλακτικά αυτοκινήτων, για παραβίαση τεχνολογικών μυστικών και αθέμιτο ανταγωρισμό. Η υπόθεση αφορούσε κλοπή τεχνολογικών μυστικών της Tesla, και η δίκη έγινε στο Δικαστήριο Πνευματικής Ιδιοκτησίας της Σαγκάης τον Οκτώβριο 2023.
Μήνυση κατά της BYD (2025): Η Tesla ξεκίνησε πέρσι δικαστική διαμάχη κατά της κινεζικής BYD για παραβίαση πατεντών σχετικά με τεχνολογία στερεών μπαταριών (solid-state batteries) και συστήματα θερμικής ρύθμισης. Μπορεί να αργούν τα δικαστήρια στην Κίνα, αλλά μην νομίζεις ότι θα σταματήσει η Τέσλα.
Επιπλέον, η ίδια η Tesla Inc. (όχι μόνον η θυγατρική στην Κίνα) έχει εμπλακεί σε αρκετές δικαστικές διαμάχες με κινεζικές εταιρείες, όπως η Xpeng Motors, αλλά και προς πρώην υπαλλήλους για κλοπή κώδικα Autopilot και μεταφορά του στην Xpeng, υποθέσεις που διεκπεραιώνονται είτε σε αμερικανικά δικαστήρια, είτε σε κινέζικα.
TGD
Thread Gravedigger
Το χόμπι θέλει πολύ διάβασμα. Και θέλει εκδρομές σε σκοτεινές περιοχές. Πράγμα που συνεπάγεται ότι θα κουβαλάς μαζί το τηλεσκόπιο, θα το στήνεις, θα περιμένεις να έρθει στη σωστή θερμοκρασία (τον χειμώνα αυτό παίρνει ώρα). Αν πάρεις μικρό θα το κουβαλάς μαζί παντου, αλλά μην περιμένεις να δεις πλανήτες. Αν πάρεις μεγάλο θα το σκέφτεσαι.
Προτείνω να εγκαταστήσεις το Stellarium στο κινητό, να πάρεις το βιβλίο Binocular Astronomy, και ένα ζευγάρι κυάλια νυκτός σε τρίποδο. Μέχρι να εξαντλήσεις το βιβλίο θα έχεις μάθει αστρονομία και τον ουρανό και θα ξέρεις τι σε ενδιαφέρει για παρατήρηση ώστε να διαλέξεις τον σωστό συνδυασμό σωλήνα και προσοφθάλμιου.
Εναλλακτικά, χωρίς διάβασμα και κούραση, πάρε ένα ρομποτικό Seestar, στήσε το σε ένα τραπεζάκι, ζητά από το tablet τι θέλεις να δεις και σε 15 λεπτά θα έχεις εικόνα.
Ουτε καν. Δεν υπάρχει λόγος
Δεκτό.
Είναι ας πούμε έξω από τα ενδιαφέροντά σου.
Τότε όμως, εφόσον δεν κάνεις κανενός είδους διάλογο, παρά μόνον πετάς ανυπόστατες δήθεν εφυολογίες, δεν υπάρχει λόγος να συμμετέχεις εδώ, με ποστ που αμφισβητούν πεπραγμένα της Τέσλα πχ για (μπλα μπλα μπλα) καινοτομίες, ελάττωση κόστους κατασκευής, αλλά και πατέντες στις μπαταρίες, διότι μπαίνω (και θα συνεχίσω να μπαίνω) στον κόπο να δείξω ότι αυτά όλα (που αναπόδεικτα αμφισβητείς) ισχύουν, ενώ στη συνέχεια δεν τα διαβάζεις και δεν ασχολείσαι με τίποτα από όσα αφορούν την Τέσλα (σταματάς σε κορόλα μάλλον).
Οπότε, ναι, συμφωνώ, δεν υπάρχει λόγος να τα διαβάσεις, αλλά ταυτόχρονα, αυτό συνεπάγεται πως δεν υπάρχει λόγος να ποστάρεις κι εδώ πέρα. 😎
Έχει τελειώσει αυτό. Οι δύο εταιρείες συμφώνησαν να δώσουν τα λογισμικά τους σε ανεξάρτητο φορέα να ελέγξει αν υπάρχει αντιγραφή, συμφώνησαν και στο ποιος θα είναι αυτός, και δεν προέκυψε αντιγραφή. Είναι διαφορετικά.
Stellarium
Αυτό το app έχει στο κινητό της. Εγώ δεν πρόκειται να ασχοληθώ. Απλά έκανα μια έρευνα, και με την βοήθεια των AI, και κατάλαβα πως θέλει τουλάχιστον χιλιάρικο για να αξίζει κάπως. Το Celestron Dobsonian 8" που έβαλα έχει βάση κινητού, κάνεις calibration και με το app της Celestron γράφεις τι θες να δεις και σου δείχνει που πρέπει να πάει ο φακός με ακρίβεια. Καλή φάση αλλά δεν ήμαστε τώρα για χαβαλέ που θέλει χιλιάρικα. Ευχαριστώ για την απάντηση. Είμαστε και εκτός θέματος.
Όχι δεν κατάλαβες, ειναι έξω απο το γνωστικό σου πεδίο, είναι σα να μου λες για μπαταρίες στην ποντοπόρο ναυτιλία, δεν έχει νόημα.
Εδώ είμαι γω για σένα.
Τέκνοκινγκ. Επίσημα.
Και "Master of Coin" ο Chief Financial Officer (CFO), Zach Kirkhorn, από το ηρωικό 2021 παρακαλώ! 🤣😂😁
stavros.vatistas
