Μια φορά κι έναν καιρό...
Re: Απάντηση: Μια φορά κι έναν καιρό...
Δεν ανοίγει κανένα λινκ από το aca.....
επειδη απο καιρο ψαχνομαστε !!μηπως μπορουμε να μαθουμε τιμη και απο που ?
skaloumbakas
4Haris
Power isolators and frequency response curves - Genesis 300 settings
Ναι, γιατί μέσω του domain ACA.GR προωθεί το νέο A.C.A... το φορουμ new-aca.com ... :108:
Κάνω τότε copy-paste του αρχείου (αλλά θα είναι στα Αγγλικά sorry!)
written by Christos P. Skaloumbakas, 23-July-00​
When I came back from Constantinople, where we were invited by its hi fi Club, I had the chance to appreciate the use of a sound level meter an owner of a Genesis 200 Speaker system was using to correct the subs' placement in his room.
I was lucky to find a db meter by Radio Shack, but also extremely lucky to find the CD (Shefield Lab), I was going to use, in order to measure and plot the individual frequencies of my "Genesis 300 - room" system.
After using this db meter for a couple of days and drawing the first curves in my PC, Mr. Xaitas proposed me to incorporate in my system, his power isolators, one for the main amplifier and the electronics and a second one for the sub amplifier and the digital. My turntable needs nothing of these, since it is using a 12V battery p.su..
Personally, I have not great respect to any kind of power filters and the most of them I have tried are holding and thinning the soundstage. You need to thoroughly test each of these things in your system before using them.
I have almost established the appropriate settings for my speakers - Genesis offer this possibility, to calibrate the servo-sub-amplifier as far as low and high cut, phase and of course volume, and so making these speakers very versatile according to the listening room conditions. Of course for Genesis 200 and Genesis model I speaker systems, you can play with the sub tower placement as well, independently of the ribbons. I have my speakers far away from the back wall already (3.8 m. and that believe me helps a lot), so I did not need to do that anyway.
At this point of time, I am still burning in the power isolators, but from now, I can tell you that, contrary to my beliefs, they are doing a very good job by flattening the frequency curves, which are getting better and better as time goes by.
Putting the Xaitas isolator V-4 in my mid/high amplification and the preamplifier, I have noticed a better flow of the music notes, with the voice becoming more natural with absolutely no grain and fatigue. Due to the extremely analysis of the system, these improvements are quite obvious. OTOH, with the second isolator V-3, feeding the sub amplifier, the bass had become extremely controlled, tight and uniform, along the 16 to 100Hz spectrum, without any peaks, meaning I can raise my bass volume to acceptable levels and so giving the chance to the amplifier to work more effectively.
All these phenomena become clearer, as these isolators are burning in...
The figures compare frequency curves, according to different sub amplifier settings as time come by. Black thick lines are the latest ones (I have no indication that they are not going to get even better in the nearest future).
My current best speaker settings are the following:
subwoofers: bass volume 33, high cut: 16Hz, low cut: 70Hz, phase: 0
and the panels: tweeter: 0, high/mid cut: 1.
Music program highlights:
* CARDAS sweep record
* The Shefield / A2TB Test Disc "My Disc"(10045-2-T)
* MAHLER Syphony No2 (EMI, PO/Klemperer 7 69662 2)
* DISCOVERY & CHRISTMAS MUSIC, James Welch organist (Wilson Audiophile, WCD-806/8419)
* MARTHA ARGERITH in Rachmaninoff's PIANO CONCERTO No3 (Philips, 446673 2)
* POMP & PIPES (Reference Recordings RR-58)
* SAXOPHONE COLOSSUS Sonny Rollings (DCC, mono)
* Stravinsky Firebird (LSO / Dorati, Mercury reissue LP)
* Symphonic Dances (Rachmaninoff,DSO / Johanos, Athena LP)
* Tchaikovsky Capriccio Italien (RCAVSO / Kondrasin, LSC2323)
* Mahler 1st Symphony (LSO / Solti, DECCA reissue LP)
* Sinfonieta-Fanfares (Janacek, CzStPO / Serebrier, Ref.Rec. 55)
* Carmen Suite (Bizet, ROHO / Gibson, LSC2449), etc.
System:
* Genesis 300 - Rowland 8T - Consummate (line + phono) - aas gabriel - Souther TQi linear arm heavily modified - Wadia 8 transport - Wadia 15 D/A converter.
* Wiring: XLO "signature"(XLR) & XLO "lim. ed." digital cable (BNC-BNC)
* Power cables: Xaitas "black signature".
* Accessories: Radio Shack sound level meter.
* Electrical install.: 2X35A dedicated power lines + V4/V3 power isolators.
και κάπου αλλού γράφω για εκείνη την εποχή:
I have also tested and founded very suitable for my system, both power isolators V-4 & V-3, made by Nexus Acoustics - B. Xaitas. I have also replaced the Essence power cords with the Xaitas "black signature" ones. It seems they are better sounding if you place them with these isolators.
επειδη απο καιρο ψαχνομαστε!! μηπως μπορουμε να μαθουμε τιμη και απο που?
Εχω ένα Xaitas V-3 προς πώληση - κοίτα τις αγγελίες, αν θες)
skaloumbakas
4Haris
isolators vs. p.su...
Να επαναφέρω μία φωτο
Τα ιsolators βρίσκονται πίσω και εκατέρωθεν του rack. To V-4 (αριστερα) το χρησιμοποιούσα για προ και τελικό Rowland και το V-3 (δεξια) για τα ψηφιακά και τον servo-ενισχυτή των χαμηλών.
Εχει σημασία να τονίσω ότι τα isolators μπήκαν στο σύστημα ΠΡΙΝ αλλάξω/ενισχυσω/βελτιώσω τις τροφοδοσίες των: phono stage, line preamplifier, DAC και servo-ενισχυτή των χαμηλών... :126:
μαλλον επειδη ξεκινησα αναποδα θα πρεπει πρωτα να μαθω εαν στο δικο μου συστημα θα παιξει ρολο (yamaha as2000-yamaha soavo-1
v-dac+marantz 52mkii-hiface m2+lap-top )
Re: isolators vs. p.su...
και πουρκουα παρακαλω εαν επιτρεπεται δεν τα χρησιμοποιειτε πλεον ?
skaloumbakas
4Haris
Απάντηση: Re: Μια φορά κι έναν καιρό...
Δεν τα χρησιμοποιώ γιατί οι τροφοδοσίες πλέον αρκούν (να φανταστείς την ισχύ του τροφοδοτικού του phono, αλλά και του προενισχυτή, θα την ζήλευαν τελικοί ενισχυτές... :137:)
Συγκεκριμένα για το θέμα αυτό γράφω στη σελίδα μου http://aca.gr/pop_skal.htm (δεν δουλεύει το είπαμε...)
Removed both high current amplifiers from the 2 Xaitas isolators. (June 2005)
Here is why some times they say that... 'The best tweak is when you remove your last tweak'...
Well, not exactly but removing those 'high current consumers' from the xaitas isolators (I had my main amplifier on the one and the servo-amplifier on the other) left the sources breath; I mean literally breath and perform like having a very stronger power supplies. Music got more open and dynamic, if I want to put it simple. Great improvement with no money...
Removing both Xaitas Isolators from the power line. (Feb 2009)
Well, I do not know what to say about that! I have written a paper, when I first incorporated them to my system and now I am damn sure that acoustically helped when I removed them... This is one of the things that happen in our audio history and depends on the strength and quality of the p.su's, the quality of the voltage at the time, the break-in condition of the speakers etc., etc. You never know...
Στη περίπτωση σου, αν επιπλέον η ΔΕΗ δεν στα λέει και τόσο καλά στη περιοχή σου, το πιό πιθανον είναι να σου κάνει ένα isolator... Αλλά θέλει δοκιμή...
skaloumbakas
4Haris
Clearaudio Goldfinger on the Clearaudio TQi Master
Είμαστε στο 2007 και έχω ακούσει πολύ καλά λόγια για την κεφαλή Goldfinger. Εχει μαλακώσει "λιγο" και η ανάρτηση της ιnsider :143:, έχω βαρεθεί τόσα χρόνια και τον Souther TQi, οπότε προτείνω να επιστρέψω (αποσύρω) κεφαλή και βραχίονα στην Clearaudio και να αγοράσω στο 50% Goldfinger και TQi Master...
Αγάπη μου ΑΥΤΟ ΓΙΑ ΣΕΝΑ!!! :136:
skaloumbakas
4Haris
1600 gr extra weight on top of the arm
Και βέβαια δεν θα μπορούσε να ξεφύγει και αυτός ο βραχίονας από... κάποιο modification και αυτό έίναι ένας κύλινδρος από ανοξείδωτο χάλυβα επάνω στο διαφανές κάλυμμα του βραχίονα...
... καθώς και ένα πανάκριβο κάλυμμα για προστασία από τη σκόνη (για να μην έχει κόκο ντε!!!)...
... από χαρτόνι... :143:
Μαζί με το φτιάξιμο του κυλίνδρου, αναγκάστηκα να λεπτύνω και το record clamp, για να μπορεί ο καινούργιος βραχίονας να κατεβαίνει...
skaloumbakas
4Haris
Και το πικάπ φαίνεται έτσι από το παταράκι μου...
Τα isolator δεν έχουν βγει ακόμα, (έχουν όμως βγει οι ενισχυτές από αυτά...)
Απάντηση: Clearaudio Goldfinger on the Clearaudio TQi Master
Ελπίζω να της είπατε και την τιμή της κεφαλής εν αστεϊσμό....
"Σιγά να μην έχει και 8000 ευρό βρε αγάπη μου":143::143:
skaloumbakas
4Haris
Μη λές ονόματα...
Μόνον ποσοστά (σε % του ΑΕΠ... :135:)
skaloumbakas
4Haris
Broken cantilever...
Δεν πέρασε καλα-καλα ένας χρόνος με την Goldfinger και με μια απότομη κίνηση του αγκώνα μου συνθλίβω το cantilever, το οποίο μετά από μία ώρα ψάξιμο το βρίσκω στο πάτωμα! :124:
Να ανοίξει η γη να με καταπιεί ήμουνα!!!
Ξανα μανα το ίδιο σκηνικό - η Clearaudio αποφεύγει το re-tipping και έτσι την έστειλα για αντικατάσταση με μία αλλη που εν τω μεταξύ ήταν πλέον to καινούργιο μοντέλο Goldfinger D, ηχητικά βελτιωμένη με πιό flat response πιό ζεστή και λίγο μεγαλύτερη έξοδο.
skaloumbakas
4Haris
Clearaudio TT2 ...
Οσον αφορά τον βραχίονα τώρα... :143:
Μετα την αγορά του Master TQi άρχισαν να βγαίνουν φήμες (μα τη σκέψη μου διαβάζουν αυτοί οι άνθρωποι:139:) ότι η Clearaudio στους παράλληλους βραχίονες της (αρχίζοντας από τον Master) θα τους έκανε
... τα τρία δύο... :142:
... τις ρόλες εννοώ που πανω εκεί κινείται ο βραχίονας (κατ' απομίμηση του βραχίονα TT1 του Clearaudio Statement, της ναυαρχίδας των πικάπ της.)
Επέστρεψα λοιπόν τον Master TQi και μου ήρθε το νέο μοντέλο (με μικρη διαφορά) o TT2, όπου ήταν και άλλα πράγματα αλλαγμένα.
Εκτός από την κύληση σε 2 ρόλες, ο βραχίονας είναι από ανθρακονήματα και ελαφρύτερος από τον προηγούμενο (από χαλαζία) και το όλο σύστημα εχει επιπλέον προβλεψη για ευκολότερη ρυθμιση.
Εδώ μου έχει σηκωθεί... ο βραχίονας (τα βέλη δείχνουν τα NM purifiers που έχω τοποθετημένα)
Εδώ ο Αλέκος του Orpheus Audio μου ρυθμίζει την Goldfinger D στον καινούργιο βραχίονα.
skaloumbakas
4Haris
κορυφή ισοσκελούς τριγώνου και συγχρόνως nearfield listening...
Στο επόμενο ταξίδι προς την Ιθάκη... (πάλι στα πολιτικά τό 'ριξα... :143:) θα μας απασχολήσει:
- η αναβάθμιση (εις διπλούν) του παράλληλου βραχίονα της Clearaudio,
- η αλλαγή της κεφαλής (εις διπλούν και αυτή λόγω ζημιάς),
- η κατάργηση των Xaitas isolators από την τροφοδοσία και
- η μετακίνηση των ηχείων ακόμα πιό μπροστά...
Αφησα τελευταίο το πιό σημαντικό στην αναπαραγωγή της μουσικής, το οποίο δε κόστισε και τίποτα... δηλαδή την μετακίνηση των ηχείων αρκετά πιό μπροστά από το rack και έτσι ώστε να μην "βλέπουν" καθόλου πλαινούς τοίχους, αφού από ένα σημείο και μετά, ο χώρος ακροάσεως ανοίγει...
Συγχρόνως τα απομάκρυνα μεταξύ τους, ούτως ώστε η θέση ακρόασης (η μπροστινή) να ειναι στη κορυφή ισοσκελούς τριγώνου και nearfield.
Για διαστάσεις, αποστάσεις κλπ, η παρακάτω κάτοψη είναι πιστεύω κατατοπιστική:
see detailed view
τα 16 καρεκλοπόδαρα... είναι από ένα συγκριτικό που είχα κάνει σπίτι πριν 2 χρόνια:
skaloumbakas
4Haris
simply, NO comparison...
Μια άμεση συγκριση μεταξύ του παλιού set-up και του καινούργιου φαίνεται κοιτώντας τις 2 παρακάτω φωτογραφίες
Αναγκαστικά - και καλύτερα εδώ που τα λέμε... έχει βγεί εκτός rack και είναι στο πάτωμα και ο σερβοενισχυτής (στη συγκεκριμένη φωτο επάνω του είναι και τα 2 τροφοδοτικά πικαπ και το line) και τα καλώδια ηχείων έχουν περάσει μπροστά από το rack.
Τι αλλο παρατηρει κανείς στη δεύτερη φωτογραφία? :142:
...οτι εχεις βγαλει τον βραχιονα για να του ραψεις κουστουμακι απο cool wool, καθοτι το χαρτινο εδινε εφτελεις μεσαιες!
ασε που η καθαροακουστικη σε απειλησε, ωστε να μην αναγραφεις το ονομα της σε κατι που ουτε γυαλιζει, ουτε διαφανο ειναι!
intergrale
